Question about Hunter 52" Ceiling Fan With Light And Remote Control
One of the Hunter ceiling fans in our house (Hunter 84678-300) rubs a one pont as it rotates. How do we center it so that it does not rub? Thanks.
SOURCE: ceiling fan
hi you have a problem with your fan do you have the remot book how to operate the fan remote we lost the booklet for the instruction maybe you can send me a copy of your booklet instruction for the fan is your fan is from the compagny home collection and the brend or model tampa thank you
Posted on Nov 25, 2007
muttandjeff
  • 359 Answers
SOURCE: wiring connection ceiling fan
copper to green , white to white , seperate the black and the black with th white tracer you wired together connect the black to the black and the black with white tracer to the red in ceiling , without looking this is my best advise ,good lk
Posted on Nov 27, 2008
johnny5846
  • 379 Answers
SOURCE: ceiling fan remote will not turn on light
common problem , i went to home depot and bought a new remote for my hunter fan , and it worked again , salesman was very knowledgeable and helpful . thanks. explain the problem to him , he can help .
Posted on Dec 30, 2008
clyde2j2
  • 137 Answers
SOURCE: Light not working-hunter ceiling fan need part number 85112-01?
"Google" ----"replacement parts for ceiling fans"
there are dozens of sites that may be of help.
Posted on Mar 02, 2009
SOURCE: we have a hunter type 2 ceiling fan installed on a bedroom ceilin
Okay. Turn off circuit breaker. Take the bottom off the fan. Mark how the wires are connected. Remove switch by unscrewing the sleeve you mentioned. Take the switch to Home Depot (or the like) -- buy a replacement.
If you have to turn the breaker back on during this process, make sure you have a wire nut over the end of each of the loose wires you disconnected from the switch.
After you take the switch out, you'll know how to reinstall it, so I won't go thru that.
Charlie
Posted on May 12, 2009
Hunter fan #22441 makes clicking /rubbing noise,all speeds,blades are tight & and balance is good. what next???
the plastic cover retainer screw above the blades
.if the noise is there when spinning at all speeds
check its clearance with the blade motor center
may have dislodged it is quite possible to rub and click
even if it has a reverse direction switch there....
this is the hunter typhoon 48 in
Jun 18, 2016 | Hunter Dryers
My hunter ceiling fan remote batteries went dead. I replaced them and the light went out now i can turn the fan on but not the lights
Here's what you do. I just fixed mine. I had the same issue. Over time the rubber on the buttons will wear down and block the contacts. Take the remote apart. There should be two screws, take them out, the back should come off. you will see the electric board, one screw you take off. Flip it over and you will see the contacts on the back of the board. If there is a build up of rubber all you do is take a pencil eraser and lightly rub the contacts. This will clean them and then you should have no other problems. Hope this helps..
Oct 13, 2011 | Hunter Ceiling Fan Light Remote Control
We got 4 HUNTER ceilin fans in one room. Model 27185-060 with remote FCC ID:IN2TX11 Two of them are runing clocwise another two in opsite side Wat can we do to run all in one direction?
Your Hunter ceiling fan is equipped with a small switch that changes the spin of the blades from clockwise to counter-clockwise. Regardless of the make or model of your ceiling fan, this switch is typically located on the center motor housing where the fan blades are attached. good-day!
Aug 19, 2011 | Hunter 52" Ceiling Fan With Light And...
Rubbing noise heard when fan is on sounds like metal against metal
hi there, you need to replaced bushing, due to loose of shaft to the bushing the stator is mis align. thats why you heard a cracking sounds. thanks
Apr 30, 2011 | Hunter Fan Low Profile III Plus 20801...
My ceiling fan rotates anticlockwise but not clockwise. What do I need to do?
There is a small switch on the side of the fan that will reverse the rotation of the blades.
Thanks for your quesiton @ FixcYa.com
Feb 11, 2011 | Hunter Ceiling Fan Control Switch
Need to oil Hunter Ceiling fan, Tyep G model 25539. Cannot find the place to insert oil. THANKS!!
There are only two places to lubricate a ceiling fan, the top and bottom of the armature that goes through the center of the motor. The blades in turn hook to this and rotate with it. The top of the armature, closest to the ceiling, is probably a little difficult to get at. The bottom of the armature is probably easier to get at. To do a complete job of lubricating both ends, the fan must be taken apart and cleaned of old lubricant which is then replaced with new. However, I have found that using a can of WD40 with the red extension nozzle is the best way to do it without taking the fan apart. Spray some WD40 at the lowest part of the armature supported by the motor housing. WD40 is better than oil because it penetrates better and it is less likely to cause a build up of dust and dirt that would cling to the oil.
Oct 13, 2010 | Hunter Dryers
Remote control won't work any more
Have you tried to replace the batteries in the remote? Have you tried to clean the IR sensors with rubbing alcohol and a cottons swab or windex?
May 14, 2010 | Hunter (25417) Ceiling Fan
Wiring connection ceiling fan
Mar 24, 2008 | Hunter 20531 Vista Brushed Nickel Ceiling...
Fan blades rub on housing
The fan is not level.
You will have to relevel the fan. One "trick" we use until a fan can be releveled is to stick a wieght on the top side of the blade. You will have to find which blade will weight back to level. Usually the one on the oposite side of the one that rubs. Tape some quarters or fishing weights on the top side and keep adding until it quits.
Once you get a chance to relevel it get yourself a foot long level and loosen the connections and redo the mountings.
Feb 03, 2008 | Hunter Ceiling Fan - 281
Dryers Logo
1,121 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
