Question about Garden
I need to know what the fuel to oil ratio is on my Stihl mini boss chainsaw
    President:
  • 2,220 Answers
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
Your OM can be found here:
Stihl Product Instruction Manuals
http://www.stihlusa.com/information/info_product2.html
If you want to verify my recommendation.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Sep 05, 2010
Farm boss starts runs great until hot then stops dead let it cool and it runs what do I try?
Most likely needs to be torn apart, the cooling fins on the engine need to be cleaned regularly, also you have carbon build up inside muffler, there is a screen inside muffler, if not clean, you will eventually get a scored piston and cylinder wall, then you will need much more to fix the issue, also make sure you are using the correct ngk plug
Sep 27, 2017 | Stihl Farm Boss Chainsaw 18"
Stihl saw leaking chain oil?
Chainsaws can become messy even if the oiler is working correctly. Check the oil level frequently during a cutting session. If frequent refills are necessary, the oiler may be defective
Jun 02, 2013 | Garden
Stihl chainsaw 210 owners mannual
Fuel needs to be mixed with 2 stroke oil at a ratio of 50:1
50 parts fuel to 1 part oil.
Also it requires 'chain oil' used as a lubricant and bar coolant, this goes in the tank beneath the exhaust.
Jan 16, 2012 | Stihl Garden
Echo chainsaw 16in. model 280 E(P) or 290 EVL(P) \r\nLooking for the correct oil and gas mixture ?
The mixture for most echo products is 50:1 ratio. You can use the Stihl fuel mix in this unit .. The Stihl fuel mix is also a 50:1 ratio.
Mar 29, 2011 | Echo Garden
Need to know the oil to gas ratio for a 056 stihl chainsaw?
Stihl chainsaws are 1:50 oil to gas ratio. Make sure you use good high-quality 2-stroke oil, preferably that which is made by Stihl.
May 21, 2010 | Stihl Chainsaw 045 056 Clutch Chain Saw...
I was given a mini mac 30 chainsaw. it ran great ...
Most chainsaws in the United States operate on a 50:1 oil to unleaded gasoline ratio. Some manufacturers recommend a 40:1 mixture.
May 18, 2010 | Garden
I need to know a fuel oil ratio.
Regardless of what the manual says once adjusted your saw will perform better with this mix.
Do you need bar oil? Available at any Hardware or Home Center.
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL suppliers recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine. HTH
Lou
Dec 27, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Need to know gas oil ratio on poulan micro xxv deluxe
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Oct 08, 2009 | Poulan Garden
Garden Logo
512 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
