Question about Singer Vacuums
Singer sewing machine... model 290C.. how to thread the bobbin
SOURCE: sewing machine won't pick up bobbin thread
open the bobbin case and see if the hook is turning, if it is it is just a timing problem with the hook and needle, if it isn't tuning you may have a broken gear or timing belt.....It eill need to be looked at or adj by someone who repairs them....Daniel
Posted on Jan 07, 2009
SOURCE: my singer 4166 sewing machine won't pick up the bo...
I had the same problem straight out of the box. I decided to buy a new machine and came across the 4166. It had more than enough functions and seemed to run smoothly. I too have problems with the bobbin not threading so I took it back into the store thinking I was doing something wrong. The saleswoman had the same problem. I was going to exchange it for another but before leaving I wanted to check to see if it worked. Again, same problem so I left without a machine. I spoke to the owner only to be told that 30% Singer machines are lemons and have to be returned for servicing because they don't work from the start. This is a waste of money and time.
The only suggestion I can offer is to either forget about the machine or take it into be serviced.
Posted on Jun 26, 2010
HansPP
  • 2510 Answers
SOURCE: Thread and bobbin both threaded
Check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out.
Posted on Mar 16, 2011
  • 1833 Answers
SOURCE: Just got white E-Z sew
The thread should be going counter clockwise. You probably have to pullabout 3 inches of thread out of the bobbin to be safe, and pull that up overthe plate and drape to the left. Then pull about 5or 6 inches of thread outfrom the needle. Try holding that thread somewhat taught and lower your needleup and down with your side dial and see if it finally loops the bobbin thread. Hope this works.
Posted on Jun 25, 2011
hunter19_46m
  • 7482 Answers
SOURCE: Can not locate my manuel
Hi rose13olive...
Go to the following webpage and download your user manual for your sewing machine.
Please take time to rate me
http://search-pdf-books.com/kenmore-sensor-sew-70-model-385-sewing-machine-users-manual-pdf/
Posted on Aug 16, 2011
What can you do to stop squeaking when I'm winding bobbin
Spray wherever the squeak is coming from with a dry silicone lubricant called 'Jigaloo' or WD40 Dry Silicone Lubricant. It is also great for sliding windows.
WD 40 300014 Specialist Water Resistant Silicone Lubricant Spray 11 oz...
Jan 13, 2016 | SewShop.com Singer Model CE200 Quantum...
My machine flashes C4 when i want to sew
Clean the bobbin case area thoroughly, and probably the feed dogs, too. Start all seams by holding the top and bobbin thread ends together behind the presser foot for the first few stitches. If you have lost your manual, pick up a new one, free, at http://www.singerco.com
Mar 21, 2014 | Singer 7256 Fashion Mate Sewing Machine
I got this for my daughter in law. The machine bunches thread up underneath material. I have tried moving the upper tension, rethreaded (with pressor foot up) the needle & bobbin. I have changed...
the tension at bobbin seems to be the problem, make sure bobbin thread is in placed in bobbin CORRECTLY...then it should not be loose but loose enough to pull out with the slightest pull, top tension should be set on around 4,,,,,
Feb 28, 2014 | Singer 4411 Heavy Duty Sewing Machine
Bobbin Not Winding Correctly
The machine seizes suggest thread wrapped around the shaft.
Jan 21, 2014 | Singer 7463 Confidence Sewing Machine 7463
I received singer sewing machine 2623 machine and I do not have the manual. How can I get it and how do I fill the bobbin
Singer has manuals for most of their sewing machines available at their site. For the 2623, the manual is only available as a bound copy for $15. Go to http://www.singerco.com/accessories/instruction-manuals and enter the model number then click Search.
I believe on this model, you fill the bobbin with it on the metal pin on the top right of the machine. With a metal presser foot in place, bring the thread up and around the guide that pin. Wrap the thread a few times around the bobbin. Set the lever to the bobbin winding position and begin winding. Stop and trim the excess thread from your initial wraps after it is fully caught. Then complete winding the bobbin.
(On other Singer machines, you fill the bobbin in place with the bobbin cover moved halfway open.)
I hope this helps.
Jul 08, 2011 | Singer Vacuums
I have a Singer Imperial sewing machine, the bobbin winds in the machine, no manual with it. I have been trying to figure out how the bobbin is supposed to wind, I got it to do it one time trough trial and...
Does the bobbin have a metal "peak" on it? If so, drop it in the machine with the peak up. Slide the cover only about half way till the 2 arrows on the left match up. Thread the top as normal, put the machine in straight stitch. Thread the needle, then put thread under the foot and wrap thread around the post on the left. Leave foot up. Hold onto the end of the thread and start your machine. The bobbin should be winding now. After a few wraps you can let go of the thread and it should have broken off as you continue winding till the bobbin is full.
Jan 05, 2011 | Singer Vacuums
Kenmore YM-40-35 R Sewing Machine Manual (or copy) wanted. If a manual is not available, I'd be OK with instructions for threading the needle and bobbin and any additional details that an expert may...
Please go through the below document which will give you the help you wanted:
http://www.ehow.com/how_4798790_thread-bobbin-kenmore-sewing-machine.html
http://www.ehow.com/how_5839_thread-sewing-machine.html
http://www.youtube.com/watch?v=1j8e8FvwUlQ
You will also find additional information on every page at the left hand side (Ehow.com) and on the right hand side(Youtube).
Please let me know if you need any additional information or have any information that you would like to share with me.
Jun 10, 2010 | Vacuums
Top thread does not pick up bobbin thread, also clicking sound when needle is down under plate, as if it is hitting something. Please help I have a job to do! This machine is new it's a Singer Inspiration...
indicates needle /hook timing is off check/ adjust or take it to a repair shop for adjustment
singer have a very good manual on how to set timing so download a pdf version from the singer site
Nov 05, 2017 | Singer Vacuums
Vacuums Logo
401 people viewed this question
Top Singer Vacuums Experts
vince
Pieter Vleeshouwers
Pieter Vleeshouwers
Vernon Taylor
Are you a Singer Vacuum Expert? Answer questions, earn points and help others
