Question about Pride Health & Beauty
It is an older 3 wheel Action Cat scooter. It has worked wonderfully for years. It recently had a flat rear tire that I removed and brought to be fixed, when I put it back on the scooter would not move
280zlvr
  • 126 Answers
SOURCE: rear wheel
does the van shake or vibrate? does the van have tires on it ?start by switching the left rear with the right rear test drive and listen for soun if no sound then the tire has a bad steel belt replace tire if the sound is still present. jack up van and spin tire if no sound is heard replace wheel bearing and if there is still a sound look into brake drum for possible springs or clips that may have fallen into drum causing noise but i would say its more than likely the rear wheel bearing to change that u must buy a new bearing and follow instructions on replacing good
Posted on Jun 30, 2008
  • 51 Answers
SOURCE: I have a 2006 Mitsubishi Eclipse with a flat rear
just keep kicking it mitsubishi wheels are nortorious for corrosion seizing wheels to the hub and make sure you clean the corrosion off before you put the wheel back on or you could have problems.
Posted on Mar 16, 2009
  • 32 Answers
SOURCE: Reverse on 3-Wheel scooter won't work.
throttle pot, cheap fix
Posted on Apr 03, 2009
dennymulford
  • 1055 Answers
SOURCE: Can not remove rear tires after removing lug nuts, wheels are jamed onto hub.
spray pentrating oil around where wheel meets hub and also around lug bolts let set for about 15 min then take a sledge hammer and hit from underneath make sure the truck is blocked up good for safty
if that doesnt work take a small sissor jack between the rim and the fram and put a lot of pressure on it then hit it with the sledge from underneath
Posted on Jun 03, 2009
  • 39 Answers
SOURCE: Have Zoom 220 HMV 3 wheel scooter. Charged battery
It is possible the the battery could be damaged after being stored for that length of time. If it was wasn't completely charged before storage, or if it was exposed to extreme temperatures (even for a short amount of time) you may need to find a replacement battery. http://www.batteryinternational.com/electric-scooter-batteries.html should have the battery you need.
Posted on Jun 23, 2009
How to remove the rear wheel from a Kymco Movie 150@
Hi, Keith for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kymco, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Replace Rear Tire Kymco People 150 Scooter
SCOOTER TIRES PT 1
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
Kymco Scooter Parts ATVs Scooter Parts Performance Scooter Parts...
KYMCO MOVIE 150 Owner Manual
Oct 17, 2017 | 2005 Kymco Movie XL 150
How do I replace a tire on a pride maxima sc900v 3 wheel scooter?
Hi. Ring monster scooter parts the rear wheel assembly cost $132 dollars there is no mention on the front wheel assembly they might help U with more information 800-798-0325. ... Cheers
Sep 28, 2016 | Pride Luxury Line Maxima Scooter - 4 Wheel...
2007 Honda SCV 100 Lead repair rear wheel flat tire
Hi, Anonymous for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
How to replace scooter rear tyre inflate tubeless and remove exhaust
How To FIX FLAT TIRE on HONDA SPREE Scooter REMOVE the REAR Wheel on moped
https://www.partsfish.com/page/oem-parts-for-honda
Honda SCV100 Owner Manual
Nov 30, 2012 | 2007 Honda SCV 100 Lead
I bought an older Amigo scooter it is blue and has rear wheel drive with four on the rear two of them are flat and we don't know how to get them off to fix them.There must be a secret.
look on the inside of the wheel there should be bolt and nut going thru the wheel and axle you'll need a long Allen wrench and nut driver to remove and the wheel pulls off
sorry not sure what size wrenches
Aug 07, 2011 | Amigo HD450 3-Wheel Scooter w/33AH...
Honda Aero 50 how to remove the rear wheel
Hi, Jerry174 for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
How to fix flat tire on scooter HONDA SPREE REMOVE the rear wheel on moped
http://qt50.net/wp-content/uploads/2016/01/hondaaero50manual.pdf
Honda 1985 NIFTY 50 Owner Manual
Aug 20, 2010 | Honda Motorcycles
My scooter is making loud clicking sounds as though something has come loose & hitting something in the rear wheels as it goes around. The repair tech rotated the rear tires last week & this helped...
Its quite common for Pride scooters to be assembled using little or no grease on the rear axle. If the noise is like a stone stuck in the tyre, its probably a 'Dry Axle' as mentioned above. Try just removing the rear wheel(s) and greasing the axle. This normally cures the problem. When removing the wheel, be careful not to lose the hub key which slots into the axle and wheel to stop the wheel spinning freely on the axle. Hope this helps.
Jun 29, 2010 | Pride Go Go Elite Traveller Plus HD 4...
Back wheels make a loud clicking noise
Hi. Loud clicking noises from the rear wheels are usually caused by movement of the square steel key that fits into a groove on the axle inside the wheel hub. This is what drives the wheels.
You will probably get a click for each revolution of the wheels.
To fix it, remove the rear wheels and wipe a thin smear of grease on the key and axle, then replace the wheels.
The grease will allow the key to move slightly without making a noise, and help stop it from wearing.
It sometimes helps to also remove the front wheels, and wipe a thin smear of grease onto the front stub axles. There is no key in the front hubs, but the grease helps to prevent the bearings siezing on to the axles.
Good luck. Neil.
Jun 24, 2010 | Pride New Mobility Legend 4 Wheel Scooter
Have a flat tire on a Chauffeur Scooter rear wheel.
I just removed the right rear wheel from my Chaffeur scooter. I first removed seat, plastic cover and batteries. Then removed wheel center bolt, set scooter on it\'s side and used a short 2x4 and rubber mallet to drive the wheel off. A shot of penetration oil helped. It is an extremely tight fit.Can\'t figure the two piece rim out though. Anyone have suggestions on why it is a two piece and how to remove tire from rim?
Apr 28, 2010 | Health & Beauty
The scooter is about five years old or so, batteries are two years old. Faithfully charged,and well taken care of unit, but, just recently the charger started heating up...very, very hot to the touch...why...
hi, the charger unit is breaking down, Sometimes the batteries can cause this problem but I think you find it the charger, when batteries get older they simply don't hold the charge as much as when new, also the way they deliver power can drop off quicker.
Regards
GeWiz.
Jan 15, 2010 | Pride Mobility Products Hurricane PMV...
Clicking, first noticed on carpeted surfaces. Sounds like it is coming from rear end. Scooter has been used outdoors mostly over some rough terrain. No leaks visable. Was recently purchased used from a...
Clicking from the tires is usally due to one of two things. First, check to see that the nuts holding the wheel onto the axle are tight by removing the plastic cover and tightening them as hard as you can. Drive and see if it quit clicking. If not, check the air in the tires; they should be kept at the stated range on the tire. If they are foam-filled, flat-free tires, these can often click when the tire chages against the wheel. It doesn't affect the safety of the scooter but can be annoying. Spraying some WD-40 around the rims inside and out will often clear it up. If not, you'll need to pull the tire and tighten the 4 bolts that hold the split-rims together.
Oct 07, 2009 | Invacare Supply Group Health & Beauty
Health & Beauty Logo
80 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
