Hi I have a Simpson Delta 402 Washing Machine and it won't spin. It does everything else but as soon as it's drained it switches off and I can't get it to complete the cycle.
    Brigadier General:
  • 3,917 Answers
Hi
Please check this link thoroughly to have a detailed idea regarding your query:-
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itdoesntagitate
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 05, 2010
Hi i have a 9.5kg simpson washing machine error code PU31 what does that mean as my machine is not spinning out washing
Pump error. It means drain pump is either blocked or faulty. Water is not draining out or very slowly. Water has to all drain away before the machine will spin. Get the water out by lowering the drain hose down into a bucket. When machine is empty then remove and check the drain pump.
Dec 24, 2016 | Simpson Washing Machines
Hi my simpson esprit 550 has suddenly stopped spinning,does everything else fine,any suggestions wod b much appreciated,thanku
Has it pumped out? It wont spin if still full of water. Check for blockages etc in hoses and the pump. If its pumping out, there could be a problem with the brake release or it may be the lid switch. It wont spin if the machine thinks the lid is open. Older 550,s had a switch that was operated by a lug that stuck out of the back of the lid, newer ones have a magnetic switch under the top of the machine.
May 19, 2015 | Simpson Washing Machines
My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
Jul 14, 2012 | Simpson Washing Machines
My Simpson Esprit 655 washing machine is not the spinning the clothes dry. Everything seems to be ok.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 07, 2011 | Washing Machines
What is the weight capacity of a Simpson Delta 402 Washing Machine?
The information should be on the manufacturer's plate on the back of the machine and in the manual. If you no longer have the manual you will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You can also try the manufacturer's web site direct ;-0)
Good luck,
John C.
Apr 06, 2011 | Washing Machines
I have a simpson EZIset 750 7.5kg washing machine, model # 22s750m When the machine fills up and start it cycle everything is fine until it comes time to do the first drain and spin, the lid lock light...
Hi There, I have the same machine with the same problem. I replaced the lid lock switch with the new upgrade kit, though you might need a tec to install it! approx $100.00
Jan 02, 2011 | Washing Machines
Simpson esprite 650 front loader washing machine. Electricity trips on programs b & h wash, can't complete cycle. Spinning and draining cycles OK. Why ? thanks sally
Hi Sally.Now in your posting you mentioned the machine trips the safety switch during the main wash.Is this correct?Does it trip as soon as the barrel stars to turn or a little later.Could you explain what b& h wash is.If the machine spins and drains and fills but trips during the cycle then from working on this model of machine I think the fault is your heating element.Have you tried a cold wash without any temp setting?Please reply with additional information on the questions and I am sure I can help you.Looking forward to your reply.
Sep 12, 2010 | Washing Machines
Hi I have a simpson Delta 402 washing machine and it wont drain? I have manually drained it and checked to see if it is blocked at all, and tried to put it only on the drain cycle but nothing works, any...
if u can see the pump has it got a fan attached to it? it should b white or black. if has got a fan try turning it to loosen the object jamming it. if it is firm to turn and it doesnt get loose then u may have to strip the pump.if it has no fan then your pump is a syncro type. please reply with additional information 4 more help.
May 08, 2010 | Washing Machines
Simpson Aquarius washing machine 7kg: water
SOUNDS LIKE A PLUMBING PROBLEM WITH DRAIN PIPE .YOU COULD FIT NONRETURN VALVE TO DRAIN FROM WASHER BUT THAT WOULD NOT STOP SINK FROM OVER FLOWING
Jan 08, 2010 | Washing Machines
Washing Machines Logo
135 people viewed this question
Top Washing Machines Experts
