Question about RCA P52939 52" Rear Projection Television
Cable works no channels found in channel search
  • wildwillie19 Sep 05, 2010
    THE TV IS SET TO CABLE BUT NO CHANNELS FROM AUTO SEARCH. THE AUTO SEARCH STARTS AT CHannel 15. what does SAP STAND FOR WHEN YOU HIT INFO ON REMOTE? DON`T RECALL SEEING IT THERE.
    ehat is SAP on my screen
  • RCA Master
  • 17,130 Answers
If you meant that the cable was tested working with another TV but is not tuning to your set, it is possible that the Tuner is faulty and must be changed.
Alternatively in this case you can go for the digital box and get your cable converted by the digital box to composite video and audio signal that will go into the AV of your TV using RCA cords.
when replacing Tuner, take care to desolder with a good desodering station so as not to damage the PCB
Posted on Sep 05, 2010
  • RCA Master
  • 5,807 Answers
Determine if the Ant Input is properly connected direct
( visual needed ) to the TV built in Tuner.
Or have the option of utilizing a separate tuner like
from VCR or a set top Box and connect it how you
connect your DVD player.
Going back to your TV Ant Input,
these problem can also be from succeeding VIF
circuits and Microprocessor that goes hand and hand
with the proper applied voltages on the Tuner.
Should you feel to DIY, you may need tools and
knowledge to troubleshoot these kind of symptoms.
on a component level troubleshooting.
  • Rommel Cana
    Rommel Cana Sep 05, 2010
    SAP or Simulated Audio Program,
    as the name implies, refers to Audio only, not the programs ( channel frequency )
    you are searching, when it is activated you can still see pictures but necessarily
    have audio or sound depending on the broadcasting channel
    Guru:
  • 374 Answers
Is your TV set up to "cable" rather than antenna in the settings before you do a channel search?
It sounds simple but It is something most people would overlook. Let me know and I will get back to you as soon as possible.
  • Robert Dahmen
    Robert Dahmen Sep 05, 2010
    S.A.P. stands for secondard audio programing. It is fof changing the language to Spanish or French.
    Come to think about it some cable networks are changing their networks to all digital so this could be where the problem is. Comcast has sent out recievers to all customer (even with newer tv's) to let them recieve stations. This could be it. Have you called and spoken with your cable company yet?? also, what is your service and what area are you in and I could see if I can get info.
How do I get channels
ok,if you have a subscription to cable,you will have a cable box,you will only need to put your tv on cable and ch 3 or 4 on your tv,you dont need to search for channels,if you dont have a subscription,then you are trying to pick up over the air channels,they are called digital channels,you will need a digital tv antenna and your hdtv,you will change the settings on your tv to air or antenna,then you can search for digital channels,there are no more analog channels like we had when we are kids,they are all digital and dont need to be tuned in,if you still cant get channels please have someone help you.
May 19, 2015 | Polaroid TDAC-02212 22 in. LCD HDTV/DVD...
Lost channel 3 to watch tv on uverse
you need cable box on when you search so the tv can find it
Feb 16, 2015 | Westinghouse SK-32H640G 32" LCD HDTV
Is there a reset default setting?
Do you recieve any channels if you run the cable directly from the wall to the TV and do a channel search? You may have to switch your TV over to a different input source if you are using a box. Please email me at tina-AT-suddenlink-DOT-com for more information. Thanks!
Oct 15, 2009 | RCA Televison & Video
Auto search through
Tested and verified solution:
  1. Set Tuner Mode to "antenna".
  2. Run a channel scan. Should get zero channels found.
  3. Set Tuner Mode to "cable".
  4. Run another channel scan.
  5. Celebrate!
Aug 16, 2009 | Vizio VX37L Television
No signals found when searching for channels at setup
you need to press the channel up button 3 times if yo get message as please connect av sources. then do the manual channel search for 2 times. it should solve the problem.
Oct 13, 2008 | Sanyo DP32746 32 in. LCD Television
Channel issue
Do you have a lot loose connection inside tunner. Need be re solder. Do this and TV will be ready!!.
Apr 17, 2008 | RCA F27442 27" TV
TV not finding Digital Channels from Cable Box
I don't know where you're located but you may want to double check with Time Warner on the availibilty of an HD box. I have TWC with an HD tier package and have an HDMI out on the box that runs directly into HDMI on this TV. Hope that helps!
Jan 17, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Programming
can you enter channel 4 manually and get picture
Nov 19, 2007 | Zenith Z19A11S TV
No channels
i had the same damn problem for 3 long hours but i found a solution i have olevia 32 inch tv (720). all you gotta do is go to menu>setup>tv>auto channel search> cable> standrad search
Sep 21, 2007 | Olevia LT32HVE 32 in. LCD Television
RCA P52939 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
