FixYa.com
Tags:
BenQ FP737S-D  17
Benq FP737 LCD Display
posted by nemimanam on May 12, 2008
When I power off the system by wall socket, The display (Benq FP737) of my PC also off. But the problem is, when I on the system again, the display not on automatically.
So, I need to on it by power switch each time.
I want to on it automatically when I on the Wall soket.
Comment by nemimanam, posted on Jun 02, 2008
Thank's for Ur help. But My monitor worked as I said by an accident. At the time I'm on the power by wall soket, the monitor was lit and displayed a dialog box containing "No signal Input" while changing it's color. Some how, after several days it has disabled.
I think there is a way to re-set this function.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 30, 2008
Thanks for Trying (70)
viziks
Rank:Wiz Wiz
Rating: 84%, 128 votes
This is how the original Design logic works.You cannot change it.
Samir
Rating Locked! (?) nemimanam has rated this solution as Thanks for Trying
Can you Help with these Monitors problems?
Monitors
monitor flashing from power...
monitor flashing from power... Answer This...
BenQ FP737S-D (Black, Silver) 17" LCD Monitor
Benq monitor
only displays the benq for a... Answer This...
advice
thanks for help, i dont think... Answer This...
found them
ah found them....so if i change... Answer This...
Vertical lines intermittantly...
Remove mains and reconnect,... Answer This...
Repair Service
Find Monitor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
