I have a York Diamond 80 air conditioner/heating unit. How do I stop the water from leaking every where?
    Problem Solver:
  • 8 Answers
The condensate line from the coil must be blocked. Use compressed air to clear the lines. Or possibly a crack in the condensate pan where the fitting goes in or not sure if it is old enough but the older coils had steel condensate pans that will rust through
Posted on Sep 06, 2010
York diamond 80 manual
where is the air filter located on a York diamond 80?
May 03, 2013 | Dayton Gas Furnace Heater
I have a york 80 diamond heating and air conditioning unit. When it is turned on air comes out of the vents but it does not feel cool at all. When I check the unit outside it sounds like it is on but the...
Hello, if the compressor is running on the outside unit and the fan is not either you have a bad capacitor or a bad fan motor, if the fan starts with a push then your capacitor is bad, if it does not the motor is shot.
Jun 16, 2011 | Heating & Cooling
I have a York Diamond 90, the air is on and it works fine, but there is a blue box attached and it is leaking water-alot.
This could be a humidifier. Is there any small water lines attached to it and does it have a shutoff on it?
Apr 29, 2011 | Heating & Cooling
My central AC is a York Diamond 80 (also my furnace). Thermostat set on Cool, isn't cooling. and when i shut thermostat off, it continues to blow air. red light flashing inside unit code = Limit switch...
One of the limit switch in the furnace is tripped or went bad....
Try to find all of the reset switches and push the little red button on the top to reset them...
If that don't work you will need to take an electric meter and test each switch to see which one is bad...
heatman101
Aug 23, 2010 | Heating & Cooling
When the unit stops running water is leaking down through the filter.
Either the drain tube is blocked or the drain tray has a hole rusted in it. My unit is a York and I replaced the condensate drain tray.
Sep 23, 2009 | Ruud UBHC Air Conditioner
York dual system. Upper level Diamond 80 never seems to cool, slow blowing air, attic tubing installed. What are my options?
i would get a contractor who specialzes in york to clean and inspect your system you could be low on refrigerant or dirty filters its hard to tell but systems do need yearly maitenance so it wont be a waste of money and you will get answers from the technician
Jul 29, 2009 | Heating & Cooling
York
I have an old York outside compressor/coil/fan unit, CDHF36-6A, that I need to replace as it is no longer repairable. What is the capacity of this unit and what Carrier unit would be a good replacement?
Adair
Oct 31, 2007 | Heating & Cooling
Heating & Cooling Logo
460 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
