Question about Numark BATTLE PAK v.4 Turntable
What needles are compatible for the technics 1200 m3d
  • Numark Master
  • 5,455 Answers
All you need to do is look at the cartridge. It should have a number on it. Put that into google and you should find the answer!
Posted on Sep 05, 2010
I just purchases a Technics 1200 turntable for $70.00. I have found a problem, at the end of the album, the arm does not auto return, but just stays on the album. Could this be a simple problem,...
First off, Congratulations on such a excellent deal! That's a $500.00 turntable. I know I own a pair and I've been a DJ for 18 years.
Second, the Technics 1200 does not have an auto return. You have to pick up the needle and bring it back manually.
Feb 03, 2011 | Technics SL-1200 Turntable
SL-1200 Turntable: I own two Technics SL-1200mk5 turntables. My probl...
Hi, could just be platter not fitted hard down on spindle. I suggest you remove the platter and place it upon a dead flat surface to check to see that the platter is flat. If it is flat refit to turntable ensuring it is hard down on the spindle. If bent discard and replace with new platter.Platters can be ordered for all model 1200/1210 from styluscity@gmail.com
May 16, 2010 | Technics SL-1200 Turntable
I have a technic sl 1200 m3d with a broken tone arm, which arms are compatible?
HELLO
Have a look at Originlive on the net. They do an armboard which should fit your turntable easily and enable to put a Rega RB250 or RB300 arm on your machine - it will improve audio quality too!
Apr 29, 2010 | Technics SL-1200M3D Turntable
There is not a signal going from the turntable (technics 1200 m3d) to serato on my computer. when I analayze it there is nothing
i got my turntables repaired by these guys www.technmics1210repair.co.uk
i did they made my setup work like new so im going to spread the word.
give them a shot
Jan 16, 2010 | Technics SL-1200M3D Turntable
Is a Vestax VR-3S cartridge compatible with a Technics 1200 turntable?
HI!
I understand the Vestax VR-3S cartridge is moving magnet (magnetic). Provided it is wired correctly there should be no problems. Any magnetic cartridge will be compatible.
CHEERS :-)
Aug 09, 2009 | Technics SL-1200 Turntable
Needle for Technics mk5
Ok, the needle is just a small portion of everything required to get up and running. Here is a diagram of what your going to need:
The stylus, also known as the Needle, is what you are asking for. As you can see it's only 1 of 3 items you need:
1) Headshell
2) Cartridge
3) Stylus / Needle
If you already have 1 and 2, and you need to replace #3, then we would need to know what model #2 is?
You'll need what's called a STANDARD Mount cartridge, (aka Half-inch). In addition, that cartridge will need to be mounted to a Standard Mount Headshell.
Here is a collection of Standard Mount Cartridges that will fit this model.
Try to stay away from those all-in-one configurations that look like the Concorde airplane. Over time they will damage your tonearm due to a poor design flaw. Stick with a set up similar to the image posted. You can't go wrong, and you'll have more options.
- OPTiC
The ORIGINAL 1200 TECHNICIAN.
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Feb 15, 2009 | Technics SL-1210MK5 Turntable
Turntable skips during playback
The only thing I can say is to make sure you set up your cartridges correctly - click HERE FOR INSTRUCTIONS on BALANCING YOUR TONEARM properly.
If, you've balanced your tonearm, and set up your cartridges correctly, then you should not have any problems. Unless, your tonearms are damaged. But this is highly unlikely. I just think you need to balance properly.
Another note, Ortofon Concorde have a design flaw, in that they don't connect very well to the Technics tonearm. The Concorde's, have short and stubby connections on the rear, making for poor connections to the tonearm. Ortofon has addressed this issue by releasing the Ortofon OM series cartridges, and mount them to standard Technics Headshell.
If you still can't figure this out, feel free to give our techs a call 24/7 @ 1.866.668.1596 ext 1 - they can walk you through setting up, and properly testing your tonearm to see if it's damaged or not.
- DJ PRO LAB
www.DJPROLAB.com
May 12, 2008 | Technics SL-1200MK2 Turntable
Tone arm is hard to move and when it's placed on a record the needle sticks at on spot on the record. the same needle and record plays fine on other technics 1200 mk5. seems like the arm has resistance in...
You have a bad tone arm. I have the same tables. You need to get it repaired if under warrenty. Or there is a service manaul online you can get from ebay. Service center for our tables is Panasonic.
I had the same problem on mine. But while it is in the shop they recalibarte it
Feb 13, 2008 | Technics SL-1200 Turntable
Numark BATTLE PAK v.4 Turntable Logo
147 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
