Question about Ovens
How to replace halogen light in ceiling of convection microwave?
  • 787 Answers
It depends on the model. Which one is yours?
Posted on Sep 06, 2010
  • Ovens Master
  • 3,083 Answers
Here is a website that shows how to replace the bulb:
http://www.instructables.com/id/GE-Advantium-Microwave-Halogen-Lightbulb-Replaceme/
In case you need more specific information to your model, go to this site:
http://howtomendit.com/search.php
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 04, 2010
HOw to replace light bulb microwave KEMS308
Unit has to be removed from wall top panels removed to replace if can live with out it great bulb is cheap labor 100-150
Jan 24, 2014 | KitchenAid Architect II KEMS308S 30"...
Replace light in KEMC378KSS microwave
The oven lights are 12-volt, 5-watt maximum halogen bulbs. They
will come on when the oven door is opened. On double oven
models, both upper and lower lights will come on when either
door is opened. The oven lights will not work during the Self-
Cleaning cycle. When the oven door is closed, press OVEN
LIGHT to turn them on or off.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
Feb 04, 2013 | KitchenAid KEMC378KSS Electric Double Oven
The bracket which holds the ceiling heating element up in the microwave broke so now the heating element is hanging down into the microwave cavity. How do I get a replacement part and is it easy to...
The brackets are usually made of heat resistant plastic, or bakalite, you can search for parts at www.whitegoods.co.uk but you will need model and serial number, a word of caution, the microwave oven may have to be dismanteled to fix new element holders, you can still get shocks from them even though the mains power has been disconnected, depending on the age of the appliance and availability of parts, it may be a replacement is required.
Hope this has been helpful
john
May 19, 2011 | KitchenAid 27 in. Built-in...
Have a microwave oven Litchenaid model # KEMC307. The light bulb doesn't go on anymore and we would like to replace it. I assume it is a halogen with 2 prongs that pulls out but it is very hard to get a...
Ok, pull the oven out, remove the 2 screws on side trim of oven, remove the screws from trim under oven, now above the oven, remove the other 2 screws behind the grill. This should give you enough room to pull the unit forward. The bulb is on top. Hope this helps.
Jan 04, 2011 | KitchenAid KEMC307 Electric Double Oven
Convection works but Microwave does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
duid
May 26, 2009 | GE Monogram® ZMC1095BFBB /...
try using a voltage stabiliser .it may just solve ur problem..
May 17, 2009 | GE Monogram® ZMC1095BFBB /...
Need to replace light bulb in kitchen aid microwave
KitchenAid wants $58 for the replacement bulb. I bought it for $1.99 from www.lightbulbsdirect.com and it works just fine. The Item number is Q5G412V. It is a halogen 5-watt, 12-volt bipen G-4. Replacing the bulb requires some dismantling of the microwave. At first I was nervous about removing so many parts to get to the bulb but in the end it really wasn't so bad. The only tool I needed was a Phillips screwdriver. I surfed the net a eventually found instructions left by a friendly Blogger that guided me through the whole process. KitchenAid engineers were so STUPID when they designed this microwave. It takes two hours to replace a bulb that should take 5 minutes. Oddly enough, replacing the bulb in the normal oven below the microwave oven is a piece of cake.
Jan 19, 2009 | KitchenAid KEMC308 Electric Double Oven
Can't change light bulb
yes you wilkl need to remov ethe micro from the oven mountingin order to access the light bulb (dumb-design) but no way around it
Nov 16, 2008 | KitchenAid Architect Series KEMC308KSS...
Ovens Logo
74 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
