Question about Dell Latitude C610 Notebook
The sound is not coming loud and is the left spk that is coming small
    President:
  • 2,291 Answers
Open the Control panel 2. Open the "Sounds and Audio Devices" icon. 3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document. 4. If you were able to check this box, click ok and close out of this window and the Control Panel. 5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Check Windows services. Right Click My Computer and Manage. Choose Services and Application > Services. Choose "Windows Audio" and set to Automatic and Start. Now next you can do is If you open control panel & click device manager the window that opens will show a list of all installed hardware. Look for anything with an exclamation mark beside it, or to do with sound. If you see anything, right click it, check it isn't Disabled then select "Properties." The next window should have some tabs along the top, the one you are looking for is "Driver," you should now see an "Update driver" button. Check ur sound card information by doing this Click on start menu Click on Run Type dxdiag, enter Click on the sound tab There is button of test direct sound click on this check if there is sound Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reg in out to scan for errors.
Posted on Sep 24, 2010
I can not find out the color meanings. Power, ground and such please help!
Ok,
Power 12V + : Yellow
Ignition Switch : Red
Amp Turn on : Blue / White stripe
Antenna : Blue
Ground : Black
Illumination :Orange/White
Dimmer : Orange
Left Front Spk + : White
Left Front Spk - : White/Blk
Right Front Spk + : Gray
Right Front Spk - : Gray/Blk
Rear Left Spk + : Green
Rear Left Spk - : Green/Blk
Rear Right Spk + : Purple
Rear Right Spk - : Purple/Blk
Hope this is helped you,
Good luck.
May 21, 2010 | Pioneer AVIC-N1 Car DVD Player
Needinfo on what wire does what on the Kenwood Excelon DDX7015, on the main harness and the little 3 wire harness near the center,
yellow-constant
red-accessory
if there is a light green,pink,or brown one is is us for brake ,
purple/white -camera or green/white
green/black-left rear- spk-
solid/green-left rear-spk+
purple/black-right rear-spk-
solid/purple right rear spk+
gray/black-right front spk-
solid/gray-right front spk+
white/black-left-front spk-
solid/white-left front spk+
brown or orange if any phone mute
black -ground
pink/white or purple/white or green/white-reverse camera''
Jul 10, 2009 | Kenwood Excelon DDX-7015 Car DVD Player
I need the diagram for 1993 honda accord for radio i am installing a jvc cd player and i dont have the right adapter so i cut the origanal plug and now need to know the color codes for the wiring
this the wiring for that car--
constant power-white/green
ignition--white with red
ground-black
dimmer-red/black
left front spk-blue with green-+
left front spk-ghray/black -
right front spk-red/gree-+
'' spk-brown/black-
right rear spk-red/yellow-+
'''''''''''''''''''' spk-brown/white-
left rear spk-blue /yellow-+
'' spk-gray/white -
antenna you done need you antenna is in your window
Jun 25, 2009 | Car Audio & Video
No sound from speaker
Isolate the wiring, too. It's a binary problem. Should be easy. Or try running your suspected speakers on other channels to eliminate amplifier bugs.
Jan 02, 2009 | Onkyo TX-DS595 Receiver
The speaker on my HP pavilion dv 2610us just stopped working suddenly. If you plug headphones or speakers into the computer, sound still come out
chk the spk on a mp3 player or cd player if its working if its not then the spk has to be replaced
Regards
Samson Ved
Dec 04, 2008 | HP Computers & Internet
Jvc 6500v no sub signal on soround sound
Hi, I had the same issue but if you change the front spk and center spk settings to "small" rather than large, the lower frequency is sent to the sub instead
Oct 11, 2008 | JVC RX-6500V Receiver
Grounded sound
It sounds like the 4 speakers wire out put on the radio it self has failed so the best thing is to replace the unit
Jul 16, 2008 | Alpine CDA-9847 CD Player
Dialogue vs. background music and sound
The on-screen menu appears only when the selected source is DVD or VCD on the DVD/VCD/CD player and the disc is in the slot and NOT PLAYING. On the remote control ONLY: 1. Press CHOICE (it should work now) LANGUAGE menu appears. 2 Press Cursor to move to the menu you want? which is AUDIO Selected item changes its color to green. THEN: 1. Display EXPERT SPEAKER SETTING menu. 2. Press Cursor to select ?TEST TONE,? then press ENTER. ?TEST TONE? changes its color to green and test tone comes out of in the following sequence?left front speaker, center speaker, right front speaker, right rear speaker, and left rear speaker. ? Test tone is output only when the tray loaded with a DVD is selected, but not playing. 3. Press Cursor to move to ?C.SPK? LEVEL? or ?R.SPK?LEVEL,? then press ENTER. 4. Press Cursor to adjust the output level, then press ENTER. ? You can adjust the output level from ??6 dB? to ?+6 dB.? 5. Repeat steps 3 and 4 to adjust the other speaker output level. 6. Press Cursor to select ?TEST TONE,? then press ENTER. Test tone stops. 7. When finished, press Cursor to move to ?EXIT,? then press ENTER. EXPERT SPEAKER SETTING menu disappears. I hope this helps you, please let us know. Best regards, nightdiver
Jun 13, 2006 | JVC MX-DVA9 Shelf System
Dell Latitude C610 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
