My LG WD(m)16225fd will not turn on. I have checked the plugs, fuses, circuit breaker but cannot find anything wrong.Help please
  • dawn258 May 13, 2008
    I have been told it is the processor, but I am having difficulty finding the part in the uk. Can anyone help please
  • Anonymous Mar 22, 2014
    wont spin
  • 101 Answers
Check the door switch, the door switch which completes the circuit and tells the machine that is safe to turn the machine.
Posted on May 12, 2008
My lg ms3949cs microwave tripping the breaker when I press start button but was working before.Please help
More than likely the klystron tube is defective, that draws a lot of current. Best path here is a new MW
Oct 18, 2016 | LG Microwave Ovens
The hot tub pump blows the power everytime I turn it on tried changing the fuse and had a look inside but can't see anything wrong please help!
Definitely a short circuit on the pump. Check that it is not wet - it might look dry but can be wet inside. Pump motor can be stuck due to worn bearings or overheating at some time. Get a electrician to test the circuit if not found to be wet. Be careful when fiddling there and switch of the mains before touching anything even with the fuse blown/circuit breaker down.
Jun 02, 2015 | MCM Lazy Man Push-Button Spark...
The power won't turn on, how can i fix that?
The possible causes for this unusual behavior may be if 1) electrical power cord may not be plugged in or connection or may be loose. To make sure this is not the problem see that the plug fits tightly in wall outlet.
2) House fuse is blown, circuit breaker tripped, or a power outage has occurred. Reset circuit breaker or replace fuse. Do not increase fuse capacity. If problem is a circuit overload, have it corrected by a qualified electrician.
3)Water supply tap is not turned on. Turn on water supply tap.
If all the above methods doesn't work, please call at 1-877-714-7486 to locate your nearest LG service center.
Feb 05, 2011 | LG WM-2277HW Front Load Washer
Renting old house with old power box uses 'plug in fuses' , doesnt have cut off safety switch ,i heard that i can by circut breakers to stop any surges and plug them into fuse box ,does that sound right ?...
Wow, all due respect, but someone would really be negligent to offer you a solution to this problem. An electrical panel isn't something to mess with, especially if you're asking these type of questions. Contact a professional electrician in your area or run the risk of electrocuting (that's DEAD by electricity) yourself. Good luck, and please be safe.
Aug 10, 2010 | Eaton ARC FAULT CIRC BREAKER
LG front load washer WD-8074FHB the circuit board exploded into little bits during a cycle. I bought a new board but when I connected it up there is no power or display on the new circuit board. What else...
if the curc bord exploded i would blame either power overload. or water in the curc the lg- wd units have both internal p.c.b bord fuses as well as in line fuses try checking them
Jul 07, 2010 | LG Washing Machines
No electrical power
You must find the reason the main breaker is popping ...
I'd start by unplugging everything and remove all breakers. Turn the main on ... does it pop? If it pops here look between the breaker panel and the end of your cord. Turn the power off - reinstall the first breaker - turn power back on. What happens ... keep doing this until the main or individual breaker pops - investigate that circuit to find your short.
If you get all breakers back in with out popping anything ... start plugging stuff back in. Something is shorting somewhere.
Let me know what you find please.
thanks
a
Oct 06, 2009 | Hilltop Rv 60 AMP CIRCUIT BREAKER CARDED
LG Front loader Electric Dryer want heat but will run and spin
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
This link will show teardown illustrations: Parts and more help available on other pages of the website.
http://www.repairclinic.com/0100_16.asp
Hope this helps.
Illeagle
Aug 27, 2008 | LG DLE2532W Electric Dryer
Washing Machines Logo
Top Washing Machines Experts
