Question about Acer Aspire 3690-2196 Notebook
I was using my laptop last night when it just shut down on me, then when i went to turn it back on it goes to the acer "start up" like page before skipping to a black screen and displaying the following message: Broadcom UNDI PXE 2.1 v11 . 4.1 Copyright (C) 2000-2008 Broadcom Corporation Copyright (C) 1997-2000 Intel Corporation All rights reserved. Broadcom Base Code PXE- 2.1 v1.1.0 Copyright (C) 2000-2008 Broadcom Corporation Copyright (C) 1997-2000 Intel Corporation PXE-E61: Media test failure, check cable PXE-MOF: Exiting Broadcom PXE ROM. Operating System not found this has happened once before and when we sent it away the tech people from acer said it was a software problem or something along those lines. what do i do to get it to start up as i have lost an entire years worth of school work as well as pictures, music, and other files?
  • ashstephens9 Sep 04, 2010
    also - my acer model is an Acer Aspire 5536/5236 series model number MS2265 if that helps at all.
  • 300 Answers
If you have a BOOT CD then try to boot and go to windows.
Or you can use windows setup CD but go for repair only.
For the future it is a good idea to INSTALL WINDOWS in a USB mini drive and boot the computer from USB. You have to go to BIOS and set USB default drive.
It is a good idea to clone your HD in a CD.
Posted on Sep 04, 2010
  • 11 more comments
  • ashstephens9 Sep 05, 2010
    will this erase all my files as well though? if so, is there any way that i can retrieve them first?
    will this erase all my files as well though and is there any way that i can retrieve them first?
    is the boot cd like the disc that i used to back stuff up? and is this going to erase all my other files, if so how do i retrieve them first?
  • global1207 Sep 05, 2010
    If windows are corrupt and fail to boot, you have three options to recover the data:
    Create boot disk to an identical computer, get into the windows, and retrieve the data.
    Create and use a recovery disk to get in the windows, and retrieve the data.
    Use windows SET UP CD, only in "REPAIR MODE", this will not format the HD, will repair files, and the data will remain intact.
    Send PC or HD in a lab to retrieve the data, but you have to pay.
    Details for option 1 and 2 you can get to:http://www.addictivetips.com/windows-tip...
    If windows are corrupt and fail to boot, you have three options to recover the data: Create boot disk to an identical computer, get into the windows, and retrieve the data. Create and use a recovery disk to get in the windows, and retrieve the data.
    If you have access to another computer then:
    Remove the Hard Drive from your computer and retrieve the data with another computer.
    This is similar with what LABS DO. If you are patient and pay attention to details, then you may get your data back. You can find step by step procedure at this link. http://www.fonerbooks.com/laptop10.htm
  • cutiefcis Sep 14, 2010
    i have tried to remove th HD from my laptop and use the USB Shelll as u mentioned but i can't find my drives yet
    the HD appeared as there's a usb mass storage device attached but in the explorer i can't find my drives and i still can't copy my data!!!
    n.b when i attached my HD in the disk managment window i found that the HD is defined as "unallocated" area!!
    is there's a way to get my data back
elix0411
  • 3530 Answers
SOURCE: Broadcom UNDI PXE-2.1 v11.0.11 Copyright (C)
change your boot priority. press power button then keep on tapping F1 key until your reached to setup utility. go to boot menu and set your boot priority 1 to your HDD. if compute wasnt able to detect your HDD . then there is a problem wth your HDD, you need to call you manufacturer for HDD replacement if unit is still under warranty
Posted on Apr 04, 2010
  • 162 Answers
Hi. I think the problem on this one is its either your Harddrive has already failed or your Optical Drive has a cd inside, so double check your Optical drive if there is a disc inside it. If not this issue is also with the operating system, you can try to restore your system by pressing the One Key recovery(OKR) button found beside the power button which has a logo of an arching arrow, but remember to plugin first the ac adapter on your laptop before pressing the One Key Recovery Button and also do not press the power button to turn on your computer because when you press the OKR button it will automatically turn on your computer and proceed with the recovery process. When it gives you some option you should choose One Key Recovery and then choose System Recovery, then factory default and from there it will guide you to the whole process of recovering your machine. If this doesnt fix the issue you could also try using the Recovery disc to restore your sytem t its original settings just like the OKR. Lastly you can contact the tech support dept. of Lenovo, they are open 24/7 and this the number to contact:
US/Canada: Available 24/7 1-877-4LENOVO (1-877-453-6686)
Australia: Available 24/7 1300-557-073
New Zealand: 9am-9pm Mon-Fri 0800-446-833. Hope this helps
Posted on Jun 03, 2010
parrotheadpc
  • 2600 Answers
SOURCE: Broadcom UNDI PXE 2.1 v11 . 4.1
This is showing because the computer is not seeing the hard drive that contains the operating system. In some cases this is because the hard drive has come dislodged from the interface on the motherboard. Dells are good for this because the hard drive slides into the side of some models. Try reseating the hard drive and reboot. Your worse case scenario is that your hard drive has failed. The reason you are seeing the PXE-MOF etc. is that the laptop ias now looking for a network hard drive to boot from. It can't find the intenal hard drive so it is searching for other means to boot.
Posted on Jun 16, 2010
yuvamibar
  • 170 Answers
SOURCE: Hi, When I turn on my
usually, this message means that when your computer is booting it is trying get the operating system files from a network location (shared folder)
what you need to do is to make sure your BIOS is not set to boot from network.
1. when the computer starts, there is a message like "to enter BIOS press Esc" or any other key like F2 or F10
2. in the BIOs settings, make sure the order of the boot is: DVD/CD then hard disk. make sure there is no Network booting in the list
Posted on Oct 26, 2010
  • 34 Answers
SOURCE: went to shut down comp. and screen said, and still
A "media test failure, check cable" means your hard disk failed. The bios can not locate the boot sector of the hard disk to begin loading the operating system.
"Operating system not found" means windows can't load because the Bios can not find the operating system (because the hard disk failed).
This is pretty much an unrecoverable error in terms of fast fixes. You can take the hard disk to a data recovery service if you need to retrieve important data or files.
Posted on Dec 05, 2010
My laptop wont turn on, last night it got hot and shut off cud i have fried it?acer model#nal10
It is unlikely that you have fried anything. When they begin to overheat most computers will turn themselves off to protect themselves to prevent this happenning.
If you leave the laptop to cool down completely while un plugged and then plug it back in it should be fine!
Regards,
sjstore2
Dec 19, 2010 | Acer Aspire 5500 5570-2609 Laptop
Acer aspire 3610 graphic or battery problem?
It sounds like your backlight is damaged. On some units this can be replaced on its own. On others, it requires the entire LCD to be replaced. I'll see if I can find out which this is, in your case, and find you a part number.
Sep 01, 2007 | Acer Aspire 3610 Notebook
Acer 110 boot problems
This could majorly happen because of sp3 conflict with one of your hardware drivers
log in into safe mode and rollback the last software or hardware driver update
Jan 01, 2010 | Acer Aspire One Netbook 8.9" Notebook
Problem with the Acer One 110: System hung-up
Do you have a backup disc i.e. an operating system disc! as it sounds like you may have to reload the complete operating system. If restore cant be accessed then you will undoubtedly will have to do a clean install!
I was using mu Acer Aspire 7720G last night while
either plug in the back of the laptop is shot or you need a new hardrive
Nov 05, 2009 | Acer Aspire 7720 Notebook PC
Download not complete Leopard not working
Try to boot your computer with the Recovery disc, by turning on your computer and slot in the disc, and pressing the C key. If it succefully boot in, try to restore the Mac software.
Feb 06, 2009 | Apple MacBook Pro Notebook
Laptop worked fine the other night went to shut it down and it then said that an update was needed before it turned off so it done that and then turned itself off.went to turn it back on the next morning...
boot up computer and as screen starts up keep tapping F8 to go into safe mode and then go to system restore and restore to a date before the update and it should work for you ..... it may have not been a real update or it just didnt load right / larryyb
Nov 28, 2008 | Acer Computers & Internet
Cannot start up my laptop since in done an update
Try booting into "Last known good configuration" it is on the same screen as Safe Mode, if that does not work, you can try to run CHKDSK /r from the windows install CD, just choose "Repair" in the option, if this does not work I suggest removing that hard drive and slaving it into another computer to get your data off and then reload Windows onto it. It is missing a .dll
Nov 28, 2008 | Acer Aspire 1642WLMi Notebook
On shutting down my laptop it gave the message, "installing 1 of 1" do not turn off your computer. It did not turn off all night. I turned it off by using the on/off button then shut it down...
When you start your laptop, press F8. You will get a menu (Normal boot, Reboot...). Choose Last good known configuration (something like that).
Aug 20, 2008 | Acer Computers & Internet
My computer keeps restarting itself
  1. Start laptop
  2. When the laptops Logo page closes, start to press F8
  3. You should get a Windows Start screen
  4. If you get a Windows Logo page (the kind you normally get when Windows loads, then reset it and start again.
  5. On the Windows Start page select "Last known good configuration" and press enter twice
Hope that solves it for you =)
Apr 12, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 3690-2196 Notebook Logo
434 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
