I need a power cord for VG700b monitor. - Office Equipment & Supplies
  • 1,684 Answers
We carry the power adapter in stock at: http://www.ccl-la.com/catalog/product_info.php?products_id=48 This ships from Louisiana in the US not from Honk Kong.
I hope this helps you out.
CCL_Tech
Corporate Computer
www.ccl-la.com
Posted on Sep 04, 2010
How disassemble vg700b monitor backlite not working
I suggest you connect the VGA cable from the computer to another monitor or a laptop, just to make sure that your monitor's back light is faulty. If it does show on the other monitor or laptop, then the back light is really faulty. And i suggest that you get a computer technician to open it up for you if you can not do it yourself. Or you can get a sharp-flat object and open the monitor starting from the bottom of the monitor working your way round to the top. You will notice finger-like structures that hold down the monitor covers together. Make sure you do not break any of those. When you open it, check on the circuit board where you connect the power cable. Check for any bulged or leaking capacitors. Capacitors have a job to hold down the power from the source long enough for your display. For faulty capacitors, the monitor will either remain black with the orange light blinking, or it will display for at least between 2 to 8 seconds and then goes black. Buy the same type of capacitors and replace the damaged ones. Please not the polarity as you replace the capacitors.. Good luck
Feb 21, 2012 | Samsung Viewsonic VG700B Monitor
Speakers on the VG700b View Sonic do not work. can you help
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 14, 2011 | ViewSonic VG700b 17" LCD Monitor
Hello the speaker on my viewsonic vg700b are not working is there anyway to fix that?
Yes. It probably is, but you need to take the monitor to a specialized workshop to check the buzzers and all the speaker components. It is not a thing to do it alone at home. If you need further assistance or have further questions please leave a comment. Cheers
Aug 26, 2010 | ViewSonic VG700b 17" LCD Monitor
I have a viewsonic VG700b monitor. Everything is fine for the screen but the built in stereo speakers don't work. I'm pretty sure the wires are in the right place so can anybody help me????
First make sure that you are using the mini stereo male phome jacks on both ends, one end is connected to the Green audio line in of the monitor, the other end should be connected to the Green audio line out of the PC, also need to set the volume controls at the PC and the monitor, starting at 1/2 level. You can also verify that the monitor amplifier is wprking or not by feeding it with an MP3 player or some kind of audio source to see if you do get the sound OK.
Mar 14, 2010 | ViewSonic VG700b 17" LCD Monitor
Is this right for my broken view sonic VG700B ?? Size: 2.6mm x 342mm Part Number: 26342 Starting Voltage: 1500 Running Voltage: 650 Current: 5ma Wattage: 3.35 Intensity: 34,000 cdm2
Is this information from LCDPARTS.NET? I always remove the old lamp assembly and take an actual measurement of the lamp dimension before I place the order. The diameter is correct, but you should measure the length of the lamp, I know LCDPARTS.NET does give you some idea how to estimate the lamp size.
Are you sure that the lamp is bad, the common symptom of bad lamp is that it has pinkish light color wwen it first start up and slowly turning to normal white color light after warm up.
Jan 21, 2010 | Samsung Viewsonic VG700B Monitor
Viewsonic vg700b lcd monitor screen turned black
there's an internal hardware problem in your lcd monitor - cold soldered / defective electronic part/s. I suggest to bring the unit to an authorized service center for proper diagnosis & fix the problem. best regards
May 21, 2009 | ViewSonic VG700b 17" LCD Monitor
Viewsonic VG700b bug
The light turning to orange means the monitor is not getting a signal from the computer. Check your monitor cable at both ends and make sure it is in very tight and secure at the computer end as well. Also check to see if the computer stays on when the light goes to orange on the monitor. The power cord for the computer might be loose.
May 20, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
My viewsonic vg700b turns on but the screen is black
Have you found a solution?
I have the same problem
Apr 01, 2009 | ViewSonic VG700b 17" LCD Monitor
Monitor Colour
for whatever reason you have lost your blue gun. it could be a matter of an adjustment or a defective component in the blue video driver. take it to have it serviced.
Jun 20, 2006 | ViewSonic VG700b 17" LCD Monitor
26 people viewed this question
k24674
jasbo
jasbo
