Question about Cameras
Hello I have a problem with the olypmpus stlylus tough 6000. when i turn on the camera sometimes it went to the internal memory, and when i turn off and turn on again it went to the memory card. how do i set it so that everytime when i turn on it will be in the memory card setting? thanks
  • 3,083 Answers
When the memory card's in the unit, pictures should automatically go to the memory card, so that makes me suspect that the card isn't getting detected. I'm thinking that there may be a slightly corroded contact in the internal contacts in the camera. You can take some electrical contact cleaner and try to spray them, or use a qtip, gently, soaked in isopropyl alcohol. It could also be a cracked trace going from the memory socket to the main board, and that would take disassembling the camera to identify and try to resolder it. Try the cleaning, since that's usually what causes problems like this.
Good luck, thanks for using FixYa, and hope this gets it working.
Posted on Sep 04, 2010
Testimonial: "very helpful"
  • night_archer Sep 05, 2010
    oh thank you so much. Since you mentioned about the corroded contact in the internal contacts in the camera, i figured there might be something wrong with my micro sd card, so i switched to a new one, and now its good, on and off goes straight to the memory card.
  • Tom Carson
    Tom Carson Sep 14, 2010
    Glad you got it working! Good job! You might be able to clean the contacts on the bad memory card and get it working again...good luck!
I have a digital camera and when I try to take a picture it says my internal memory is full what doi I do to delete this
Delete/ or move some pictures from internal memory or if the camera has external memory set your camera storage option to external memory/memory card.
Good Luck
Mar 05, 2014 | Cameras
I took some photos on my tough TG 310 with no memory card, i can view the images on the camera when the card is not in the camera but i can't see the images on my computer and can't upload them, is there a...
You have two options. If you normally transfer your photos by connecting your camera to your computer, remove the memory card before making the connection. This will allow the computer to see the photos in the camera's internal memory.
If you normally transfer your photos by putting the memory card into a card reader, use the Backup command in the Settings-1 menu to transfer the photos from the camera's internal memory to the memory card, then transfer the photos from the card to the computer as normal. See page 48 of this manual: http://www.olympusamerica.com/files/oima_cckb/TG-610_TG-310_Instruction_Manual_EN.pdf
Aug 31, 2013 | Olympus TOUGH TG-310 Digital Camera
Olympus stylus tough 6000
There's a low chance of it after the camera started getting hot during the recharge. It sounds like water got past the internal seals, and to dry it out properly will require opening the camera and essentially opening all of the seals to get the water to evaporate. If you leave it closed up, the circuitry inside will corrode.
Meanwhile, there is at least one circuit that already shorted and caused the camera to heat up. There's no way to determine whether anything actually burned out or whether it just needs the water to evaporate.
Jul 14, 2013 | Cameras
Copy between internal memory and SD card on olympus TG-1
Use the "Backup" command in the settings-1 menu. See page 45 of this manual.
Jan 14, 2013 | Olympus Tough TG-1 iHS Digital Camera...
Olympus 6000 tough wont take pictues but shows old pictures
The problem is in the camera lens, the image sensor or shutter is the issue, it will need the attention of a camera technician.
Mar 29, 2012 | Olympus Cameras
I have a Polaroid a310 I recently bought a card for it it is a Sony 4GB. I put it in and started taking pics, they went to the internal memory. Then I went to the menu to copy to card it said no files...
Hello!
I have had the same problems with Sony memory cards before. I found out that most Sony memory cards work only with Sony Cameras. This is because most drivers used to manage these memories are licensed by Sony.
Try getting another kind of memory card for your camera. I recommend Kingston memories.
Good Luck!
May 04, 2011 | Polaroid a310 Digital Camera
I just finished copying the memory card to my usb and now the camera is not functioning...it says write protected.....what do i do? is an olympus 6000
There is a small switch on the left side of the memory card. Slide it up and the card will work. On my SD card it is yellow.
And then insert it back and check Let me know if this will help
Nov 29, 2009 | Olympus Mju Tough 6000 Digital Camera
Fisher-Price Kid-Tough Camera won't stay on
digital cameras have always "eaten" batteries. tho there may be an internal defect in the camera i would suggest purchasing a good set of rechargale batteries and charger for them.
Robert
Jan 10, 2009 | Fisher-Price Kid Tough Digital Camera
Cameras Logo
32 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
