Question about Car Audio & Video
What type of box port does a 1200 watt sony xplod subwoofer need
  • 83 Answers
SOURCE: Subwoofer Ground Wire Problem
there is also the possiblity of a ground potential problem you could try running a wire from the ground point of the amp to the rear of the head unit, in this way both components have the same ground potential....second , I would take the ground loose a the point you have connected to the vehicles chassis , i then would prepare the surface by sanding a quarter <25 cent piece> area and using two washers and nylon insert lock nut, and a bolt to securely fasten your ground ,,,,also I would use a grounding wire equal too or 2x teh ga you are using for your power < battery > cable.....and lastly I would reduce the input sensitivity to your amplifier, because if u have them turned up < more sensitive> the amp will amplify abient electrical noise present in your vehicle... if this helps let me know , if it does not let me know...
Posted on Apr 04, 2007
  • 13 Answers
SOURCE: What size is the voice coil in my 1100w 10" sony xplod sub?
go to the sony website or any dealer website and look at the model number of your sub, punch that in and get the measurement.. mostly gonna be inches.. but then go to google and convert it to mm
Posted on Apr 08, 2009
Lexdiamonzz
  • 203 Answers
SOURCE: i need a wiring diagram for sony xplod active
Hello ml3ray, you might want to check the following link i actually dont have the wiring diagram for that specific subwoofer if there is any technical support you may need just email me at usmclex@hotmail.com or write back at my fixya profile.
http://audio.manualsonline.com/manuals/mfg/sony/xsaw200x.html
Posted on Oct 18, 2009
  • 171 Answers
SOURCE: what wattage amp do I need to get good sound in a toyota corolla
Make sure it's a RMS 1200 wats not MAX watts also the Ohms of this speakers and them you can buy any amp. with the same RMS watts of your speaker and same Ohms of resistance.
Posted on Jan 27, 2010
Testimonial: "Thanks alot, that helped."
MNfisherman
  • 11896 Answers
SOURCE: what size of box in need Pioneer TS-W307D2 12
Length (L) = 31.9 cm = 12.6 inches (approximately 12 1/2 inches)
Width (W) = 51.5 cm = 20.3 inches (approximately 20 1/4 inches)
Depth (D) = 19.7 cm = 7.76 inches (approximately 7 3/4 inches)
Posted on May 04, 2010
Ive got an sony xplod 1200 watt amp thats bridgeable ive got two dual 4ohm subwoofers how do i wire this up to get the countinued bass with no cutting off
wire each sub in series inside the box, this makes them each 8 ohms, then run them parallel from the box to the amp bridged. this will give you 500 watts at 4 ohms
Apr 07, 2012 | Sony Car Audio & Video
What watt amp would be best for my 1100 watt 10 inch xplod?
I have a 1100 watt sony xplode the silver one 4 ohm rms 3 00 with a 3000 watt 400 rms pyle amp? 8 ohm
Sep 16, 2011 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
I have two sony xplod 12" speakers wich can hold
You only gave us the model of the amp so I will make an assumption that your 12" subs are the Sony XS-GTX120LW. First, they cannot hold 1200 watts a piece. They are meant to be powered with 350 watts RMS. They will hold 1200 watts peak. That means that 1200 watts for a few seconds will be ok. Past that and kiss them goodbye!
Next you indicated that bridged the amp. Since the subs are both 4 ohm single voice coils did you wire them in series or parallel?
It sounds to me like you wired them in parallel resulting in the amp seeing a 2 ohm load. The amp you referenced is only stable when bridged at 4 ohms.
Has the amp begun working again once it cooled down? If not you could have fried the outputs by having the resistance too low.
Dec 21, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
What wattage amp do I need to get good sound in a toyota corolla
Jan 27, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Amplifier For Powering Sony Xplod xs-l121p5
Pump the brakes!
You need to know the RMS power rating of the sub you are powering.
Dont exceed the RMS power rating of the sub by more than 25%.
If you see a peak power rating on either the sub or the amp, ignor it, means nothing. Always compare RMS ratings.
Example: a Sony 12" Xplod sub, boasting 1200 watts, will only handle, 350 watts RMS, so the amp you choose to power the sub should be 350 watts RMS as well, and should not exceed more than 25% of the RMS power handling (487.5 watts).
Bottom line, know your RMS numbers, not Peak.
Byron
www.distinctbeat.com
Dec 06, 2009 | Sony Car Audio & Video
Car audio question
first thing first the speakes u have are to powerful for those amps and u need at least a 5.2 fared capaciter and u should run 2 gauge or 0 gauge u have a good set of speakers there but i was u i would use a alpine v12 2500 watts rms
Sep 29, 2009 | Car Audio & Video
Settings for a Sony Xplod 1200 watt amp, with two 12 inch subs
What kind of subs are you running? Meaning what brand, what are the ohm, spl and wattage? I'll look up your amp while you get that info to me. Looking forward to helping you:) Thanks!
Apr 08, 2009 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
Car Audio & Video Logo
44 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
