Question about Eagle Cuda 242 Fishfinder
My Eagle Cuda 300 does not want to display the correct depth. It goes from 20 feet up to 80 feet, up and down. When I first purchased and installed it, the depth reading worked great. HELP!!
SOURCE: depth finder problem
Try adjusting the trim or get the boats nose up even to the point of porpoise (I think thats how you spell it) if the signal improves with the nose up you may need to lower the transducer more than the manufacturer recommends. the slight looking foward will also help. My current sounder works pretty well up to about 25kn
Posted on Jul 03, 2007
SOURCE: Eagle Cuda 250 Fishfinder / GPS combo
Don't buy - go to Eagle web site and download it.
Posted on Jun 03, 2008
  • 4 Answers
SOURCE: Lowrance x96 does not function after 20 feet depth
Your transducer needs to be adjusted so the return signal can be picked up. Some of these have to be super tuned to receive the signal. Also the transducer may be moving ever so slightly when the boat is traveling at speed. You may have some water turbulence interference all contibute to signal return.
Posted on May 27, 2009
  • 508 Answers
SOURCE: Eagle Cuda 168 has no display over 30 feet of water
Try good alakaline batterys(duracell or energizer)alot of those rechargables dont hold amperage and dont stay recharged long!!!! :)
Posted on Jul 05, 2009
SOURCE: Eagle 640c Fish Finder dosen't read corectly.
I had the same problem and got the transducer changed. It now works perfectly. That could be the problem you are having... bad transducer.
Posted on Jul 22, 2009
Need manuel on operation of eagle cuda 300. is there a download for this
It is located on their website.
http://www.eaglenav.com/upload/Eagle/Documents/Manuals/Cuda-300-0143-96A-120808.pdf
Sep 10, 2010 | Eagle Cuda 300 Compact Fishfinder
Have a Cuda 300 It shows 62 ft on water or land. This is my second new unit, the first one did the same thing. Tried factory reset.
The transducer for the unit might have junked out, or else you have a floor model that is programed for that depth. lol
Apr 14, 2010 | Eagle Cuda 242 Fishfinder
When I turn on my Eagle Cuda 300, it goes straight to silulator mode. When I turn off the simulator, it won't display the bottom and the depth reads way deeper that actual. I've tried changing settings,...
Try this, hard reset-FYI-This will delete saved data
1. Turn unit OFF-Press and hold the UP arrown key
2. Press power, unit will enter production keyboard test mode
3. Release the buttons
4. Press PWR/CLEAR key 7 times. (SYSTEM INFO SCREEN)
5. Press MENU/DOWN and unit will shut off
Hope this helps
Jul 12, 2009 | Eagle Cuda 242 Fishfinder
Jul 05, 2009 | Eagle Cuda 242 Portable Fishfinder
Erratic depth and does not indiacte any fish
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Go to sensitivity set to manual then go up one on the menu and set it to 95 – 97 this will clear up the rapid change now set zoom to manual. Your back and running.
Mar 31, 2009 | Eagle Cuda 242 Portable Fishfinder
99% of the time when i power unit up, it gets stuck on 54.8 feet
After testing everything out, I went out and bought the new Eagle Cuda 300 model. I hooked that up and made sure it worked, then tried the Cuda 242 unit on the new transducer. That did it, it worked fine. The problem was a bad transducer. Might have been that -30 deg weather last winter, I'm taking that off the boat this winter. Transducer cost about $50-$60, new Cuda 300 cost about $80.
Mar 22, 2009 | Eagle Cuda 242 Fishfinder
Eagle Cuda 128 does not read water depth
Hi Chris, Did you get a fix for this issue? My Dad's Eagle Cuda 128 is also having the same problem - constant reading of 60ft. I'd love to hear if you have a solution. Many thanks,
Mar 14, 2009 | Eagle Boating
Eagle Cuda 242 Fishfinder Logo
102 people viewed this question
Top Eagle Boating Experts
Steve
Steve
ray gallant
Al Toledo
Are you an Eagle Boating Expert? Answer questions, earn points and help others
