Question about Intel DG31PR Motherboard
I have intel mother board dg31pr . It was working ok till today , problem is that when i press power button it starts but it shows intel icon at the bottum right corner of the screen & nothing is happening after this . Means it not going to bios . it appears option at the top of intel icon like press F2 to enter in BIOS etc but now its not appearing . Kindly help out with this .
  • Intel Master
  • 27,725 Answers
Try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
replace them they are probably old and faulty ?
good luck
Posted on Sep 05, 2010
Sir i hve intel DG31PR mother board and
Did u fully formated ur pc? if u get virus also u get this problem n when u install the os dont use the same os cd what u have already used ok coz maybe the virus is in ur os cd files ok do agin and let us knw what is happening
May 22, 2010 | Intel Motherboard
DG31PR MOTHER BOARD I BYIED THE LAST 2 YEARS NOW
DG31pr 001
MumBai 0020
Woeking,Mass
069-56981
Don't foget Postageeeeee
Nov 19, 2009 | Intel Computers & Internet
Intel dg31pr mother board why dont show display?
First check your num lock led if it on and off when you press num lock key then your cpu is ok.
Then therer is issue with monitor to cpu loose connection
or
Screen resolution problem.
For that when you power up press F8 key then enter in enable vga mode.then go to control panel and dispaly then settings then change screeen resolution to 1024*768 then apply and ok.
Aslo reconnect connection from monitor to cpu vga port.
Also check in bios some times your harddisk is not detected proeprly.
If problem still remains open cpu cabinet and reconnect data cable and power cable to harddisk.
Refix RAM memory.
Pull cmos cell for 15 minutes then check.
Thanks for using fixya.
Pls rate solution if it help you .
Jul 18, 2009 | Intel DG31PR Motherboard
Problem in DG31PR
ok
when upower up the computer press "del" or F2 or F3 to enter i n bios settings then go to exit menu u see load optimal defaults settigns give enter on it then save and exit.
Feb 07, 2009 | Intel DG31PR Motherboard
Mother board DG31PR (SL-BTPR81500RH2) SOUND Drive not working...?
here is the link to your motherboard drivers.
once you click on the link you will need to choose your operating system and download the driver for your audio.
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2839&lang=eng
Please do not forget to rate and comment about your experience with fixya today.
Dec 16, 2008 | Intel DG31PR Motherboard
How can i disable built in audio and add creative live value in mother board?
hi salu
check the book that comes with the motherboard , it should show the location of the small jumper switch on the motherboard which enables/disables onboard audio. if there isnt one press the "delete" key at start-up and enter the system BIOS you may be able to disable it there
Oct 25, 2008 | Intel DG31PR Motherboard
Intel DG31PR not supporting 2 dimm each of 1gb
Memory for Intel motherboards require the memory to be compatible with, Serial Presence Detect (SPD). Its suggested when upgrading memory for Intel boards or increasing memory to do you're search for the total memory you wish & include the Intel mother board model. Example: http://www.google.com/search?hl=en&q=Memory+for+Intel+DG31PR&btnG=Google+Search
This first link shows what brands works with the DG31PR MB.
Intel Tested Memory for DG31PR MB link:
http://www.intel.com/support/motherboards/desktop/dg31pr/sb/cs-027918.htm
You're Intel board is well within the Intel warranty. If you find this information not helpful please call Intel tech support. It is possible you're board needs higher attention. Please check & install the latest bios. Intel's link for bios, manual & drivers link:
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2839&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21
If you are not using WinXP click this link & pick you're current operating system.
Mike
Aug 08, 2008 | Intel DG31PR Motherboard
Intel DG31PR Motherboard Logo
116 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
