Question about Bose Lifestyle 48 System
I appears that the amplifier is not working - no speakers are working and the error message says speakers not connected. Have changed power cord, amp isn't warm. any suggestions? Fuse locations? where to go for reasonable cost repairs? Thanks!!
I HAVE A BOSE, THE PROBLEM IS AMPLIFIER IS NOT WOR
RKING. I NEED DIAGRAM
Posted on Sep 08, 2010
I have a pioneer vsx 07 11 and it says amplifier error
You see, the error message is coming from the power protection circuit which is constantly monitoring current being drawn from the receiver power supply. When the current exceeds the trip level it shuts down and give the error message.
power amplifiers has been shorted and the output transistors (one or more) have gone into breakdown and causing the excessive current drain. This will happen even though the speakers may not be connected to the amp outputs.
Jun 05, 2012 | Pioneer Audio Players & Recorders
Protection
The message appears when there's a short at the amplifiers. Disconnect all the speaker cables and try again:
  - if the message is gone then one of the speakers is shorted ; connect them one at a time till the message comes back - junk that speaker and get another one.
  - if the message is still there then one of the amplifiers has failed - take to unit to a repair shop, that amplifier must be replaced.
Sep 02, 2010 | Samsung HT-DS400 System
Changed Radio - now speakers don't work. I took out the Chrysler radio that had a CD and cassette in it and replaced it with an aftermarket radio. Now the speakers don't work. I got the adapter from a...
Sounds like your Gr Caravan has the premium sound package. You likely haven't hurt anything - but you may need to modify the wiring a bit. The speakers have a tweeter speaker in the center of the main speaker and the wiring goes through that. However, it only worked with the premium package. Go in to the speakers and move the wiring connections from the tweeter to the main speaker. Your other option is to replace the speakers.
Jan 19, 2010 | 1994 Dodge Grand Caravan
I dont know how to set it up. I put the green cord in the computer..but theres one black cord and i dont know what to do with it.
There should be ONE stereo miniplug to be connected to the headphones output of the computer, and one power supply plug to be connected to the AC adapter. These speakers do need a power supply, since they have an internal amplifier.
Dec 26, 2009 | GE HO98010 Computer Speakers
I have a str dg820 only about 2 months old. Recently went to power up and I get PROTECTOR message and it shuts down. I checked all speaker connections and they appear to be fine. It worked well for two...
Try disconnecting everything (all inputs, outputs and speakers, make sure there is no cable plugged into your unit except the power cord), turn it on, if it still shows the protect message, you have an internal short or a burnt out component inside the unit, possibly a desoldered contact on one of the connectors which generates internal noise of such intensity that it sends the unit into the protect mode.
If, after trying the above mentioned, there's no message, some other possibilities are:
- a bad speaker or speaker cable
- a bad signal interconnection cable
- a fault in any of the other units connected to your reciever/amplifier
Hope you cand find something out...
Good luck
3rq8 (Triarcuate)
Jul 15, 2009 | Sony STR-DG820 Receiver
Power will not stay on
Activated protection circuitry means that the amplifier is seeing conditions it does not like and is shutting down the power to prevent further damage.
Either you have a short in your speaker wires, in your speakers, or a blown amplifier.
Disconnect both speakers and turn on the amplifier. Does it still give the error message? If it does, your amp is blown. If it does not, carefully inspect your speaker wires and their connection. Make sure all looks good and reconnect the speakers and try it again. Still get the error message? You likely have a problem in your speaker cabinet(s).
Apr 21, 2009 | Onkyo HTR500 Receiver
Power protector on sony surround sound system
Power protect is an error message that some thing is wrong in your sound system and requires qualified tech.
Normally that error message appears when unit got problem in amplifier output section, either it is speaker problem or some output chip is fried.
Feb 25, 2009 | Sony DAV-S400 System
Alpine mrd-m501 amp
Disconnect the speaker wires from the amp, then try it again. If the error message doesn't appear, try connecting the speaker wires back to the amp one by one.
The error message is due to some sort of overcurrent in the amp. If the error does not go away when the speaker wires are disconnected, the issue is most likely with the amp itself and will need professional repair.
Mar 18, 2008 | Alpine MRD-M501 Car Audio Amplifier
Fuse at power cord blows
first check your speaker cabels for short circuit and speaker for  short coil .after you confirm there is no shotr of cabel wires by checking with avometer in ohm postion.connect speaker if the problem excit your speaker is guilty - change it with same configuration.about switches put it in low order and chech for sound level and you can go up after that.
Mar 05, 2008 | Krell KAV-300i 2-Channel Amplifier
Error code
This error msg appears when the speaker cord is shorted When the speaker output is in contact with the vehicle ground
Jan 26, 2006 | Kenwood Excelon KAC-X811D Car Audio...
Bose Lifestyle 48 System Logo
107 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
