Question about Fisher and Paykel Washing Machines
Washer model GWL10us doesn't cycle Thur wash cycles. does not agitate completely. just groans & moans.
  • 6 more comments
  • Jack Sep 05, 2010
    It starts, goes to 1st wash cycle. it drains water, but doesn't move to next wash cycle. u can advance it to spin & it spins ok and stops. u can start again and advance to next wash cycle and its the same thing. any suggestions on parts to replace.
    Thanks.Jack
  • Jack Sep 06, 2010
    I did as instructed. but no lites came on. the only lites lit were the hold & slow spin. do u have any other suggestions?
    thanks Jack
  • Jack Sep 06, 2010
    did as directed in removing agitator. Nothing under it. Still no lites come on when in dianostic mode.
    When I first go in to dianostic mode (with machine off, I hold down the wash Temp switch, & then depress power on. at that point low water lite comes on. When we go to Detailed Fault code. No lites come on.
  • Jack Sep 08, 2010
    I went into the Diagnostic Mode, when I ck the hot
  • Jack Sep 08, 2010
    didn't know if u got my comment on coldwater not working. but it doesn't fil tub when set on cold wash. Also, in diagnostic setting, when u test for "cold water" no water runs into tub. but testing Hot water, water runs into tub.
    think replacing 'cold water' soldinoid would be the answer?/\\
    thanks
  • Jack Sep 09, 2010
    Is there a certain trick to taking the wiring harness off Cold or Hot water valve?
    I didn't want to breake anything.
    thanks for ur help.
    Jack
  • Jack Sep 09, 2010
    Switched wiring, Hot to cold, cold to hot. when I did the test, it was as u suspected, When I pressed hot I got no water, when I pressed cold I got hot. I will order the cold valve. when they send the valve, will there be instructions on how to install it?? Hope so, it looks a little complicated for the average "bear" like me.
    Thanks,
  • Jack Sep 10, 2010
    Thank u veery much for your time & patience. I will order the
    replacement cold water valve.
    President:
  • 1,554 Answers
Some of the Wash Progress LEDs flash when the machine stops due to a fault. The 8 Wash Progress LEDs stands for the binary digits and by indicating the digits, the fault code number is determined. The fault code can be shown by activating Diagnostic Mode if none of the Wash Progress LEDs are lit.
Turn machine OFF on the front panel then hold down the Water Temp Down button and press the POWER button until the machine gives 2 short beeps and lights up. Release buttons and you are in Diagnostic mode. Press the Spin Speed Up button until the Hold and Slow LEDs are lit. Write down the LEDs which are lit across the Wash Progress LEDs and post it back.
Please make sure to accept the solution you find the most helpful. Failure to do so will automatically give credit to the first solution no matter how unhelpful it is. Accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Sep 05, 2010
  • 6 more comments
  • Jahn27
    Jahn27 Sep 06, 2010
    Unplug the machine for at least 30 minutes then redo the procedure in activating the Diagnostic Mode.
  • Jahn27
    Jahn27 Sep 06, 2010
    Make sure you follow the instructions carefully and correctly.
  • Jahn27
    Jahn27 Sep 06, 2010
    Sometimes small garments can get caught under the agitator and prevent proper agitation. Pry the agitator cap off then remove the screw under it securing the agitator to the drive shaft. Once the screw is off, lift the agitator off and see what's under it. Lift the basket if you have hard time lifting the agitator off the drive shaft. Lifting the basket also lifts the agitator.
  • Jahn27
    Jahn27 Sep 07, 2010
    There may be no fault detected at all but the groans are likely to be coming from the basket drive hub and the drive shaft hub not fully disengaged during the agitation cycle. As water fills in at the start of the wash cycle, the basket floats and the hubs should disengage to allow the agitator (impeller) move freely in both directions. The hubs re-engage at the end of the agitation cycle after water is drained allowing the basket to spin.
    Check for this condition by running an empty cycle and with the lid open for you to have a view of what is going on. But in order to achieve these, you have to place a strong magnet over the reed switch. The reed switch serves as a lid switch and it is activated by a magnet on the lid when it is closed. The reed switch is located under the right hand side of the top cover, approximately 5 inches from the front. A protrusion can be seen on the underside of the lid where the magnet is located.
    There is indeed an issue of incomplete disengagement between the basket hub and the drive hub if the basket moves with the agitator. You should take the basket out and clean the cylinder where the drive drive hub moves up and down. Complete disengagement may not be possible if the drive hud restricted.
  • Jahn27
    Jahn27 Sep 08, 2010
    Please state your message clearly...
  • Jahn27
    Jahn27 Sep 09, 2010
    "I went into the Diagnostic Mode, when I ck the hot"
    That is the only message I got.
    The cold water LED should flash when no cold water is detected by the motor controller module. Swap the cold and hot water valves harnesses and redo the tests for both. The cold water valve is indeed not working if still no cold water enters the machine now that the hot water valve harness is used on it. Furthermore, hot water should fill in when the machine calls for cold water if there's power in the cold water valve harness.
    The machine will definitely not work to agitate with the cold water valve not working. Replacing the cold water valve is a must, if it is not working, before any other faults can be detected, especially the agitate functions.
  • Jahn27
    Jahn27 Sep 09, 2010
    No tricks needed. Simply pull the connectors off,not the harness itself, while holding the coil.
  • Jahn27
    Jahn27 Sep 10, 2010
    Remove the screw securing the Motor Controller Module to the cover then lift the Motor Controller Module up at the pressure sensor end and ease away from the inlet chamber. When the Motor Controller Module is separated, a small quantity of water will discharge from the Inlet Chamber and heatsink. This must be dried off before refitting. When reassembling, ensure the console area is dry. For easy assembly lubricate the sealing grommets with soapy water or liquid detergent.
    Turn off faucets and remove the inlet hoses. Take care extra not to spray water into the console area. Remove the two screws located between the inlet valves and remove the screw from the top of the inlet chamber. Lift the inlet chamber and remove water valves. Lubricate the seals with soapy water and reassemble the valves in reverse order.
    Brigadier General:
  • 3,917 Answers
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
GE Top Loading washer doesn't aggitate properly.Model # WJSR4160DW
Reach into the washer and try to turn the agitator by hand and if you can turn it freely the agitator coupling (sometimes called the air bell) is stripped out. If that isn't the problem let me know. Here is the part should you find it bad.
Nov 02, 2012 | GE Washing Machines
Noise during wash cycle & got even louder on spin cycle then washer stopped completely
Could be bad belt, or agitator sleeve cracked / or broken. Not catching.
Aug 08, 2012 | Maytag HAV3460AWW Top Load Washer
I have a Maytag Model A412, series 11 washing machine. After the machine fills with water the machine appears to start its cleaning cycle but the agitator doesn't work. The water starts & the...
if this is a two piece agitator,it should behave like a ratchet turn freely clockwise and catch counter clockwise if it doesn't catch the agitator "dogs " are shot this is a verry inexpencive repair
Jun 08, 2011 | Washing Machines
Kenmore Model 22722 will not drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 01, 2010 | Washing Machines
Both drum and agitator spin during wash cycle. Is this normal?
What is the age and model number of the washer? It could be as simple as a problem with a part inside the agitator or it could be a bad transmission. A complete model and serial number from the washer not the book.
Jan 10, 2009 | Washing Machines
Kenmore series 80 washer only works on heavy duty cycle.
bad transmission,,check voltage...below 110 with load and water pressure switch or hose defective..
Dec 24, 2008 | Kenmore 24902 Top Load Washer
Washing Machines Logo
85 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
