Question about Clarion MAX385VD Car DVD Player
CANT FIND REAR AV INPUT ON CLARION MAX386VD - Clarion MAX385VD Car DVD Player
I have clarion max386vd radio but the problem is the radio has been reset,but now the radio cannot been use because i forgot the password.can u help me. ??
you have to contact the manufacturer.give them the model # and the serial # and they should be able to help you.
Oct 11, 2013 | Car Audio & Video
Hi i trying to figure out how to wire up my rca's i have a pionner deck in on the back of it it has front output,rear output,sub output ,and also a audio output .now im trying to up it to a clarion eq that...
The "Front output" from the Pioneer deck would connect to the "Main In" on the Clarion EQ. I'm assuming that your Clarion EQ can only deal with one input, and will send the adjusted (equalized) signal out both of the outputs.
The "Front output" from the Clarion EQ should go to the "Front Input" on the 4 channel amp.
The "Rear output" from the Clarion EQ should go to the "Rear Input" on the 4 channel amp.
The "Sub output" from the Pioneer deck would connect to the Left/Right Input on the Epicenter. The Left/Right Output on the Epicenter would need a Y-splitter for each side, so that you could connect each amp separately. One suggestion would be to use one sub amp for both subs.
Feb 18, 2011 | Clarion Car Audio & Video
Wich video format supported
Released 2 years ago Included Units Stand-Alone Monitor, Amplifier
Supported Audio Formats MP3, WMA
TV Tuner Without TV Tuner
Radio Tuner AM, FM, Satellite, XM Ready
Aspect Ratio 16:9
Input Connectors AV x 1
MPN MAX685BT
Monitor Size 7 inch
Output Connectors AV x 1
Power Per Channel 50 Watts x
Supported Media Types DVD Video, DVD+R, DVD+RW, CD-R, CD-RW
Supported Video Formats DVD, DivX
Dolby Digital / AC3
I found all of this at http://wize.com/car-dvd-players/p469604-clarion-max685bt
Good luck.
Hope this helps!
Jan 21, 2011 | Clarion MAX685BT Car DVD Player
I would like to add a tv tuner to my max386vd is it possible?
for me it cannot be.in pc it can be, but in car it cannot be.
Jun 19, 2010 | Clarion MAX385VD Car DVD Player
Unable to find and store radio stations
Go to a web site named clymer mannuals
Apr 21, 2010 | Car Audio & Video
I CANT UNLOCK MY CLARION MAX8700DT
only way is to find out who had the radio first and get the code from them. No other way. Sorry!
Jan 15, 2010 | Clarion MAX675VD Car DVD Player
Have a clarion max386vd dvd incar and would like to know how to disable the dvd from turning off when car is started I have selected the product as 385vd as my model wasn't available the 386vd :)
you have to disconnect the grass green wire from the handbrake and connect it straight to ground then presto u will be able to watch dvd's whilst u drive
pls rate because noone has been rating
Dec 29, 2009 | Clarion MAX385VD Car DVD Player
Clarion vrx485vd wont play videos from iphone when connected
You need a composite video cable to the Clarion Video input. The usual ipod adapter is for audio only. If you have an AV ipod adapter and you still don't have video, the signal is not strong enough for the clarion to see it and you need a 12volt pre amp. you can find them online starting around 25. Hope this helps
Jun 19, 2009 | Clarion VRX485VD Car DVD Player
Clarion MAX385VD Car DVD Player Logo
77 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
