I have a Panasonic lcd th-37px50uand after 20 minutes or so the picture becomes fuzzy with horizontal lines from both the top and the bottom. Audio is fine, all channels are affected and when I unplug and let sit for a few hours, it goes right back to normal just to start again in 20 minutes.. I was told that it was the t-con board which on the back of my tv is TNPA3621AB It looks fine, but wanted to know if that is the board that I should replace first? Please help!
  • 4 more comments
  • jph2 Sep 05, 2010
    I understand that its thermal, but how do you know that its the main board and not an additional board like the t-con?
  • jph2 Sep 05, 2010
    http://cgi.ebay.com/PANASONIC-TH-37PX50U...
  • jph2 Sep 05, 2010
    uuuuugggg. It is a plasma. Sorry, I just looked again. Would you agree that I should replace the main or the t-con board because of the thermal problem. Also, would you use a can of spray freeze to spray on during the "problem" with the picture to know which board it is?
  • jph2 Sep 05, 2010
    This is a really good idea. So I hit with this spray all the IC's, one board at a time. if there is improvement after spray, clearly How will i know what the "main" board looks like?
  • jph2 Sep 05, 2010
    I was told that since its a thermal related issue, that I should spray this "cooling" stuff on each of the IC's during opperation to see if the problem goes away and then replace the board that is the one in question. What are your thoughts on that?
  • jph2 Sep 05, 2010
    I did this and it was great. Knew exactly which board it was. Have already ordered it and will install when I get it.
    Genius:
  • 1,112 Answers
Hi:
This a indication of a thermal problem on the main sys control board, problem like this should only be board replacement..Replace the main system control board.
Posted on Sep 05, 2010
  • 1 more comment
  • Lavell Turner
    Lavell Turner Sep 05, 2010
    Hello:
    There is only to boards that will cause this type of sympton, and the T-Con board is one of them, it is the cheaper of the two boards to replace, one way to be sure is to purchase a can of freeze spray from a local electronics store, and open the back and wait until the sympton comes back, spray the largest IC's on each board, starting with the main board, when sympton goes away that is the board giving you the problems. Dont worry about spraying all areas of the board because the spray is non conductive so the unit can be on while you try this..
  • Lavell Turner
    Lavell Turner Sep 06, 2010
    Ok:
    This is a plasma unit, then your problem lies in the digital board or main system control, this will be the board with the tuner attached to it, sometimes these board are one unit, but in some they are seperate,one would be call the analog board. which is the one where inputs goes in. if the type with one board then replace the entire board, panasonic boards are not that expensive. In most cases replacing the digital board will solve the problem.
  • Lavell Turner
    Its ok to use the freeze spray even during operation as the spray is non-conductive
  • 4,889 Answers
Are you sure this is a LCD? Our database says that this is a Plasma?
  • 1 more comment
  • eagle338
    eagle338 Sep 05, 2010
    Plasma tvs do not have a t-con board. It sounds like an issue with buffer boards or sustain board. Possible failed component : Electrolytic capacitors . Component level repair may be possible. So I don't think you have to replace the entire board.
  • eagle338
    Spray? WHat spray? Who is giving you these weird suggestions?
  • eagle338
    Does not sound like it but if you want you can give it a shot.
Element 55' flat screen
Sounds like T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 12, 2016 | Televison & Video
TH-42PX75U horizontal lines (flickering black and white)
The controller board for the screen is going bad. check shopjimmy.com for replacement parts. It's not a difficult job to do. Once the back of the TV is removed, you'll see it near the center of the screen.
Feb 21, 2014 | Panasonic VIERA Televison & Video
Horizontal lines shadowed / blured picture after 20-30 minutes
There are some semiconductors or capacitors that are leaky. Might need thorough check up inside the TV.
Jul 07, 2012 | LG 55LH40 55 in. LCD HDTV
5 year old panasonic viera LCD works great until tonight, screen turned into vertical and horizontal rainbows, can see vague picture behind all the lines like looking through thin black horizontal venetian...
make sure your speaker to your sheron sound isnt to close to it .also if dvd player is the source then move away from tv will demagnatize the tv theres a magnet in them
Jul 05, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
My Toshiba 46XV540U LCD TV. Has ghost image plus many white vertical and horizontal line when it is turned on. These lines and the ghost image stay for 20 to 30 minutes and than the picture becomes clear....
Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish board that call T-CON board to do a replacement.This T-CON board sit in the middle at the bottom of the tv LCD screen panel.This T-CON board control all the picture pixels going throught to the tv LCD screen panel.
Jun 11, 2011 | Toshiba 46XV540U 46 in. LCD HDTV
I have owned an emerson tv for two years now. All of a sudden the picture has become very blurry and white. It is not the cable connection and a DVD is also white and blurry. Even the input channels are...
you must open the back cover of tv, and then things you should do is set "SCREEN" adjustment on the flyback transformer. you must turn it counterclockwise to reduce and decrease the level of screen brightness. turn screen adjustment gradually until the horizontal blanking lines disappear from the screen. and blurred images will be sharp again
Aug 11, 2010 | Emerson EWF2004 20" TV
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
