Question about Schumacher & Fast Charge Starter Charger
My Shumacher se 4020 wasn't working right so I took the front cover off and some of the wires are unhooked and i don't know where they connect.
2 Suggested Answers
SOURCE: schumacher se 4020
I would check Mcmaster Carr online and search for part # 7178K14. This is a pair of 200 amp clamps for around $8.00. I use this business all the time. They ship really really fast. Good luck
Posted on Apr 25, 2010
Tip
Craftsman belt drive garage door opener intermittent
My opener was flaky- intermittently going on and off. I could bang it and it would do the same thing so this suggested a loose connection somewhere. This wasn't a unit with the battery backup.
Safety note- don't take apart unless you first unplug the entire unit!!! I took it apart and there were two circuit boards- a logic board and a power supply board (latter was smaller of the two). I took out the power supply board and examined the solder joints on the back. I found one that was cracked (this soldered a connector pin), and another that looked like it wasn't good (not shiny). I resoldered and this fixed the problem.
Another time my wall control acted up (this has the IR sensor and buttons). There is not much room around the screws on the backside for connecting the wires. One of the wires was a little long and shorting out to a nearby component.
Hope this helps someone with similar problems.
on Aug 26, 2015 | Building Materials
Wiring diagram se-4020 battery charger
try this web site
http://www.manualslib.com/manual/523935/Schumacher-Se-2254.html Schumacher SE 2254 Owner Manual
Feb 08, 2014 | 10/40/200 Amp 6/12-Volt Manual Battery...
Sometimes loses power
Hi ring monster scooter parts about you're key 800-798-0325 cheers
Jun 02, 2017 | Invacare Health & Beauty
Water fills and stop
Chances are the lid switch is bad. Sometimes you can see the switch located on the left or right side of the top where the lid closes but sometimes its located under the heading. In either case the lid switch is attached to the cabinet. To remove the cabinet
1) Unplug the machine. 2) At the head, or control panel, find the two screws that hold it to the case. Some are on the left and right front lower corners of the panel, and some are vertical facing s on the rear left and right side. Also on some models they are in the front but you have to pull the end caps off the sides of the control panel. Further more in some of the newer models you have to take a thin paint scraper and slide under the left and right normers to press the clips in to release. 3) Remove the 2 screws and then pull the panel from the lower part of it towards you and roll it backwards. 4) Disconnect the lid switch connection in the the middle where the two grey wires and the green wire block connects to the body of the machine, usually near the middle under the panel. 5) with a flathead screwdriver pop out the two brass retainer clips on the right and left side. 6) Open the lid slightly where you can grab the case, not the tub, just the case, and pull forward and surprise!!! You just took the complete top, sides and front of the machine off.
7) get a jumper wire and find the block that you disconnected that wasn't attached to the caseand place the jumper where in the holes where the is a wire other than green, which is ground. What your doing is bypassing the lid switch. Now with jumper wire in place, plug the machine in, turn to the spin cycle and turn it on. If it works you juist verified the lid switch is bad.
May 10, 2012 | Whirlpool Inglis IP4400 Washer
The far right and left ends of the spacebar do not work. In order to use the spacebar function, the direct middle of the button has to be pushed down.
You need to reposition (clip) the torssion bar under the spacebar key (a steel wire formed in a wide U shape), it is unhooked, call for a professionnal if you'r not sure how to do this as you may brake the plastic hinge if you don't know what you'r dooing...
Aug 09, 2011 | Toshiba 310CDT Keyboard
Schumacher se 4020
Dec 13, 2009 | Schumacher & Fast Charge Starter Charger
WILL NOT RUN (KSM90WW)
theadore something is not connected right or something else got disconnected. there is no reset on these mixers. may i ask why you removed the back housing?
May 01, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Schumacher & Fast Charge Starter Charger  Logo
27 people viewed this question
Top Schumacher Electrical Supplies Experts
D. E. Hev
Lawrence Oravetz
Are you a Schumacher Electrical Supply Expert? Answer questions, earn points and help others
