Question about Refrigerators
The freezer has ice built up inside and its dripping down into the lower part of the refrigerator
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 05, 2010
MY ROPER FRIGE IS LEAKING WATER FROM THE FREEZER TO THE TOP SHELF IN THE FRIGE
the drain tube from the freezer to the lower compressor area is plugged with ice or debris,and when it defrosts the water in the drip pan behind the evaporator back cover inside the freezer thaws and cant drain down and overflows down thru the damper vent door to the refrigerator,remove the rear panel inside the freezer shut off unit and let thaw,then take a wire and work it down this drain hole till water comes out at the bottom of this drain tube located in the rear
Mar 19, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
Water dripping into refrigerator from freezer
Drain in freezer is clogged usually with ice. Unplug frige and defrost 6 hours with doors open. Pull lower front grill and check drain pan for water. If no water remove rear panel inside freezer to clear drain hole, below coils in the middle...
Mar 29, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge temperature has suddenly dropped to 15
Check the door gaskets, condenser fan, refrigerator fan and the freezer fan. That should narrow down the problem.
Dec 03, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Ice trails inside freezer
Is this a built-in refrigerator? If so, the cooling section of this unit is located in the machine compartment above the unit. GE has had problems getting this unit to drain the defrost water causing the water to eventually overflow the pan during defrost and come down into the freezer.
This is a serious design problem that would be difficult for a non-tech to correct. There is currently a $400 kit available that attempts to correct the issue. Previous kits have not resolved the issue. Considering the price of the built-in refrigerators having GE factory service repair this may be the option to choose. If you do, be SURE to insist they give you a warranty that will ensure this problem won't return.
Aug 22, 2009 | GE Refrigerators
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
It's likely the door was inadvertently left open, and the cold air passages from the freezer have built up enough ice that the cold air from the freezer has no way to enter the refrigerator. Check the cealing of the refrigerator. If you can see or feel ice in the passages between the freezer and fridge, you can probably solve the problem by finding a safe temporary home for your food, and leaving the refrigerator unplugged overnight.
May 25, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Bottom of freezer has water dripping into it
A bad freezer door seal causes condensation that freezes at the bottom of the unit. I realize you said the drip pan was full of ice, but if the drain is clogged, that will happen. If that unit has the pan at the very bottom, condensation can also contribute to this.
Jun 17, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
