Question about 2wire (1000-400108-001) Router
Lost 2 wire 546 router password ? - 2wire (1000-400108-001) Router
Lost my password .how do i recover it ?
It should be under a cover in the foot of the unit according to the instructions. See page 32 and 33 for a factory reset.
http://cache-www.belkin.com/support/dl/MAN_F9K1105v1_8820-00843_RevB00_N450DB_Router.pdf
Dec 09, 2015 | Belkin Wireless Dual-Band N450 Router
I lost my password how can I change it?
Follow this instructions:1. connect via hard wired connection using your PC (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select save and apply. then you are good to go.
Dec 28, 2011 | NetGear N150 RANGEMAX 150 Wireless Router
I dont have a disk to install my wep key to stop people from stealing my internet
open a web browser window on the connected computer and type http://192.168.1.1 into the address bar and press enter. A window will pop up prompting you for a username and password to access the configuration page for your router. Enter admin for both the username and password.
If it not accept then type user name Admin leave the password box blank and then click ok.
If it still does not accept it that means you have changed your user name and password of linksy.
To get your linksys default settings you will have to reset your linksys router by inserting a paperclip into the small Tiny hole into the back of the Linksys router for 10 sec.
Now you try to access router by user name and password which is mentioned above.
now you will have Linksys router page and now click on Security seetings on top
choose WPA PSK security settings
Now it will as you the security key
Enter any security minimum of 8 Characters anything you like.
click save settings on the bottom.
now try to connect to your Wireless network
it will ask you the security key
Enter your security and your wireless network is secured now.
here is also the Linksys Tech support no. as well. to know your exact user name and password of linksys and other details.
Phone: 800-546-5797
How to reach a live person: Step 1: Press 3
Step 2: Press 0 three times
Hours of Operation: Mon-Fri: 6am-8pm PST
Sat-Sun: 8am-5pm PST
Apr 07, 2011 | Linksys Wireless-G Broadband Router
I forgot my password and need help on how to retrieve it or change it.
There is a reset button on the back of the router; just use a paperclip to poke it. Then the default settings will be restored, and the username/password should both be admin
Mar 02, 2011 | Linksys WRT160N Wireless Router
If I reset my dynex G router using the reset button; 1) What will be my default password? 2) Will resetting the router affect the hard wired connection?
the default ip is 192.168.1.1  username admin password admin or leave the password blank.
hardwired you mean is utp cat 5e cable? known as internet cable, which using switch hub.
well, it will affect if the wire/cable you mean is came from the router you reset.
the wire and the access point  came from the modem is still active.
 do not reset your hardware if it is also your modem. Because when you reset it, all configuration of  your modem will be lost, including your user name and password provided by your ISP.
Feb 04, 2011 | Dynex Wireless-G Broadband Router
Lost password for linksys 2.4 router
Step 1 : Connect - Router - Computer ( Wired )
Step 2 : open Router Setup by typing http://192.168.1.1 on the address bar of internet explorer
Step 3 : Default password is admin
Step 4 : Click wireless
Step 5 : Choose wireless security
Step 6 : Here you can find the Password
Step 7 : Try to connect with this password
let me know if this works
Regards
TOM
Dec 30, 2010 | Linksys Wireless-G Broadband Router
Lost my password
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the Left under wireless Click Security
Step 4 : If it asking for a password leave that blank and click submit
Step 5 : On this Page you can find the WPA Key ( If it is a bunch of dots then Uncheck "OBSCURE PSK " )
If the Security Mode is WEP then the Key one will be your password
Dec 13, 2010 | Belkin (F5D7231-4) Wireless Router
Have replaced my laptop,but lost key-code for my belkin router.
Step 5 : On this Page you can find the WPA or WEP Key ( If it is a bunch of dots then Uncheck "OBSCURE PSK ") If the Security is WEP then The Key 1 Will be your Password )
Nov 27, 2010 | Belkin Computers & Internet
Looking for my password to connect other device (ipod)
It should be the WEP password which shold be located on the bottom of router.
Dec 25, 2008 | 2wire HomePortal® 1800HW Router...
Wireless router
If you have a computer wired to the router, Try this steps.
1.Open a browser and then go to http://192.168.1.1
2. Username admin and password is password
3. You should be able to access the router's utility page then and get the wireless settings of the router.
Once you get the wireless settings of the router, just connect to the name(SSID) you set up and then connect to it.
Apr 25, 2008 | NetGear WGT624 Wireless Router
2wire (1000-400108-001) Router Logo
80 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
