Question about ViewSonic N3252w 32 in. LCD Television
I need to replace power supply board part # B-00005352
  • 2,318 Answers
The power supply for your LCD can be found here. I would suggest to contact them first before ordering.
Posted on Sep 04, 2010
The indicatir light blinks yellow tv will not come on
If it has a lamp in it it need to be replace, if it is a DLP, if it is a LAD, then you have a couple of eletrolytic caps that need replace on the power supply board, or replace the power supply, go to www.partstore.com
Sep 20, 2011 | Televison & Video
TV is dead. Power light is not illuminated. Checked all plugs and outlets.
It sounds like your power supply has failed. This could be caused by bad capacitors in the power supply itself, or it could be caused by some other circuit board, likely the Y-sustain or Z-sustain board, or both.
This solution assumes you feel comfortable working on the tv yourself - if not, it will need to be fixed by a service technician.
Begin by removing the back cover. You'll need to take out all the screws that have an arrow pointing at them. You'll only need to remove the large cover, not the smaller one where the audio/video connections are located. Put the screws in a plastic sandwich bag so they don't get lost.
The power supply board is in the center top area. Check the tops of all the capacitors. They should all be flat. If any of them are bowed out or deformed then you have a bad power supply board that will need to be replaced, or replace the caps if you're capable. If the caps look ok then check the fuse at the bottom right of the power supply board. Go to the appropriate paragraph below.
1) IF THE FUSE IS GOOD: you likely have a problem with one of the sustain boards. Unplug the connectors on the Y Sustain (Ysus) that sit between the two fuses. Plug in the tv and see if the power supply board comes up. If it does you'll hear a click and see the green light on the front begin flashing. This indicates one or both of the sustain boards has failed.
To determine which board has failed, reconnect the Ysus connector from the power supply and disconnect the connector at the top left of the Zsus board. Try turning on the tv. If the power supply comes up then you have a problem with the Zsus board. If it doesn't come up you have a problem with the Ysus board and/or the Zsus board. The power for the Zsus board is routed through the Ysus board, so if the Ysus board is bad you won't be able to check the Zsus board.
Many blogs recommend replacing both if one is bad because they're both high failure items, and replacing one without the other means you may have to go back and replace the other after a short while.
2) IF THE FUSE IS BAD: You may have a problem with the power supply board. Check the caps for any deformed tops. If so, you'll have to replace the board or the caps, depending on your skill level. After making the replacement, disconnect the power to the Ysus and verify you have a good power supply board.
Jun 23, 2011 | Zenith Z50P3 50 in. Plasma TV
Power supply, where can I get a power supply board.
if you know the compoment parts that need replacing yes if not order the whole replacment power bord from rca call there service parts number give them the tv model and they will be able to send you the entire replacment part
Jun 18, 2010 | RCA D52W19 52" Rear Projection Television
TV went out.
U have a dead power supply board,burn componnents parts on the power supply board.Replaced the power supply board,u will get ur power back as normal function as before.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 02, 2010 | Philips Magnavox 42MF521D/37 Television
Unit is dead I need power supply schematics
U will not find schematic,the tv corporation don't release them.Just take the tv aparts.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.Just compare the power supply board in ur tv and the website that selling the power supply board.The picture look alike,ask the seller questions.Just buy and replaced it.U know how to solders?Just searches around the power supply board for those bulges and puff up capacitors.Replaced these capacitors will get ur power back.Most just reqiure replaced these capacitors to get the power back.
Apr 21, 2010 | RCA L32WD26D HDTV/DVD Combo
I have an Intel D865GBF motherboard in my PC, which stopped working. I replaced the power supply because there was no power to the board. Now I have power, but when I hit the power button nothing happens.
The exact same thing happened to my D815EAA2. In my case an overheating power supply destroyed the board. Do the following:
1. Check the power supply you replaced it with works on another system.
2. If it still doesn't work with your board, the board will need to be replaced.
Nov 20, 2009 | Intel D865GBF Motherboard
No picture
The problem can be in the bcaklight inverter board or the main power supply is not supplying the power to the inverter board. The main power supply gets the turn on signal from the control/main board.
Nov 03, 2009 | LG 42LB1DRA 42 in. LCD Television
Need info on component 3071 on power supply board - burned up.
Its been a while since i worked on that power board. But I believe you are refering to the orange diode that runs into the single connector for the video board next to the power supply. I replaced mine with a 1n914 diode after replacing the 2200uf lytic cap and the tv fired right up.
Jul 23, 2009 | Philips Televison & Video
Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
Apr 02, 2009 | Vizio L32 32 in. LCD HDTV
ViewSonic TV sound but no picture
I have same problem (power light is on, and I have sound, but no picture ) and found that a small capacitor on back of power supply is blown. Seems to be common problem. But viewsonic doesnt stock. Part number is b-00005352 and im trying to find one too
Jul 29, 2008 | ViewSonic N3251w 32 in. LCD HDTV
ViewSonic N3252w 32 in. LCD Television Logo
189 people viewed this question
Top ViewSonic Televison & Video Experts
Jaime Hernandez
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
