Question about Whirlpool SF362LXTB Range
Whirlpool range does not heat to temperature displayed. Model SF362LXTB
3 Suggested Answers
  • 26 Answers
SOURCE: Our Whirlpool just started showing the following
E2 F1 - UL A/D error(s)
1. Disconnect power longer than 30 seconds.
2. Re-apply power and observe for longer than 1 minute.
3. If failure remains, disconnect power, replace control.
Here's parts diagram for your model:
SF379LEKS2
Diagram#2 Part location#12 is your electronic control that you can order if you need to.
Posted on May 16, 2010
Testimonial: "Sounds great!! I'll give it a try...THANKS!!"
  • 842 Answers
SOURCE: I have a whirlpool gold electric range,accubake
I have look up your unit, I found the thermostat located inside the back panel the would only take out the function to your elements in your oven.
High limit thermostat
This link shows its location and price of the part. Now for you display issue, before continuing, push and hold the clock button on the panel until you hear a beep, if the unit is set to Sabbath mode this will clear that. If not I will continue, by the way missing a version number to model number, like a number (0 or 02). Have you have a power outage recently? I am not locating any line fuses the would take the display out. If the clock doesn't reset then I would think about checking warranty or can your dealer to inquire on your warranty.
Control Unit
Good Luck and I hope this helps.
Posted on Aug 17, 2011
Whirlpool sf362lxt oven sets off carbon monoxide detector randomly yet all flames are blue
This is caused by incomplete combustion of the fuel, DO NOT operate this oven until a qualified repair person look s at this problem. CO gas is a killer and nothing to fool with.
Feb 02, 2012 | Whirlpool SF362LXTB Range
My washer starts lets shuts down with a code of f5
Water Temperature Sensor Error
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
Potential Causes
•Check the Water Temperature Sensor, Heating Element and Element Relay
•Check connections to the Sensor, Heating Element and Relay
Mar 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Get error message F5 about 3 minutes into the cycle, have to reset multiple times to override
F-5 Water temp sensor failure
temperature sensor (NTC) value is out of range, the "F/05" error code
will be displayed. Possible cause/procedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Refer to the
"Water Temperature Sensor" section. Check
connections to the water temperature sensor.
3. Check resistance of heating element, if present on this
model. (abnormal = infinity)
I have a service manual and some repair photos HERE
Feb 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Code error F05
If this is a Whirlpool model the FO5 error code means:
Potential Causes
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
F/H
F/02
Hope this sheds some light on your problem
kcomp1863
Jan 20, 2011 | Washing Machines
Washer will not drain, error f 5 ,
will be displayed. Possible cause/proceedure:
Dec 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F05 error code comes on
Water Temperature Sensor Error - Check the Water Temperature Sensor,Heating Element and Element Relay.
If during the water heating step in wash cycle,the water temperature sensor(NTC) value is out of range,or the heating element circuit has failed,the F05 error code will be displayed - Check connections to
the Sensor,Heating Element and Relay.
Apr 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I HAVE A WHIRLPOOL WASHER GHW9150PW3 FRONT LOAD WASHER AND THE CODE F 05 IS BLINKING
temperature sensor (NTC) value is out of range, the “F/05” error code
will be displayed.
“Water Temperature Sensor” section. Check
Or just call service! (:
Feb 16, 2010 | Whirlpool GHW9150 Front Load Washer
Oven not heating to correct temperature
Replace the oven glowbar ignitor. It is too weak to keep the gas valve open.
Aug 19, 2009 | Whirlpool GS460 Gas Kitchen Range
I have a whirlpool gas oven model # SF395LEEBO
Oven temperature sensor opened Replace oven temperature sensor
Jan 11, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool Gas Range E2 F3
I HAVE A WHIRLPOOL GAS RANGE MODEL NUMBER SF379LEMS.OVEN WILL LIGHT UP BUT AFTER TEN MINUTES IT WILL KICK OFF ANF ON ON ,THEN AFTER AWHILE I WILL JUST SHUT OFF.ANY SUGGSTIONS. ADAM
Nov 23, 2008 | Whirlpool GS470LEM Gas Kitchen Range
Whirlpool SF362LXTB  Range Logo
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
