Question about Tsurumi Pump s Submersible Trash Pump - 3000 GPH, 1/2 HP, 2in., Model# HS2.4
LOOSE BLACK WIRE GOES WHERE? - Tsurumi Pump s Submersible Trash Pump - 3000 GPH, 1/2 HP, 2in., Model# HS2.4
    Problem Solver:
  • 18 Answers
It should be connected to the red wire, and has to be completely inside the motor, inside the cable and this last, bolted properly on top, that is very important to prevent electrical shock or damage to the pump,
Have a good day,
Posted on Nov 08, 2010
Internal charge port came loose. Which wire goes where--red and black
Google it and then click on and include the make/model of the machine and then click on images.
Apr 28, 2015 | Computers & Internet
Heater fan goes on and off when it wants to no control
My fan did this on my 2000 saturn L 200.
If you are handy with a screwdriver and nut driver , the problem I found was the black power wire coming from the main wiring harness to the plastic wire housing going to the back of the heater control module was loose, due to overheating of the wire . I simply bypassed it, installing a jumper past the harness to the control unit wire, keeping black to black. Works great !!! Good luck !
Oct 16, 2014 | 2002 Saturn L-Series
I hava a protocol-predator sb, after several crashes during practice flights: the rear rotor is no longer working. there is a loose black wire on the circuit board thas came loose on on end but i cant...
the black wire is a ground connection follow the power till you see the -
+ - follow the minus sign till you reach near the red wire that goes to the tail motor and solder it or even next to the power - whtch ts the ground part
Aug 03, 2014 | Protocol Predator SB 3.5-Channel...
Where can I find a wiring diagram or a schematic for this charger
If you can't get the schematic on Google, test between the black wire and the connectors available. One that has continuity with some resistance is a good candidate. One that has no resistance probably is another connector for black....
Nov 24, 2013 | Hardware & Accessories
DeWalt DW708 switch
http://c.searspartsdirect.com/lis_png/PLDM/P0201024-00003.png
This is the newer 744 series, white cord to white motor and black cord wire to black motor.
If your motor needs the mag starter that 5th loose wire, usually red, goes to the start terminal on the mag starter.
Feb 14, 2012 | Dewalt DW744S 10" Portable Table Saw with...
I have a 1991 chevy 1500 and am hooking up stereo system. But there are some wirtes loose that I dont know their place. For instance, the yellow and black one
The yellow wire from the truck attaches to the red wire of the stereo. The black wire goes to the black wire. If the truck doesn't have a black wire, connect the black wire from the stereo to a bolt on the frame of the dash. The orange wire from the truck goes to the yellow wire of the stereo. Please let me know if you have more questions.
1991 Chevrolet Silverado C1500 Car Audio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Oct 27, 2011 | 1991 Chevrolet K1500
Replaced a light switch for a ceiling fan. Switch
On the switch ... one wire goes to thefan or the light and the other wire goes to the power.
All white wires normally go together.
Jun 05, 2010 | Hampton Bay 52 In.Carriage House II in...
I need to switch my three prong power chord to a four prong
your terminal block on the dryer will have three screws in a row and there will be a green screw on the outer skin next to the terminal block cover - your four-wire cord will have a white wire, red, black and green wires - white wire goes on the center screw of the terminal block, red wire goes on one of the other screws of the terminal block, it doesn't matter which, black wire goes on remaining terminal block screw, green wire goes to the green screw
Aug 17, 2009 | Dryers
Ignition coil problem
THE PROBLEM IS RESOLVE, IT WAS THE GROUND WIRE FROM THE FIREWALL TO THE INTAKE MANIFOLD, ITS A BLACK 10 GAUGE BLACK WIRE FOR GROUND, IT WAS LOOSE.
Feb 11, 2009 | 1999 Daewoo Nubira
Black monitor
if you are the technician open you monitor theres something loose wire in horizontal or loose solder
Jul 16, 2008 | Star Logic 17" LCD Monitor
Tsurumi Pump s Submersible Trash Pump - 3000 GPH, 1/2 HP, 2in., Model# HS2.4 Logo
87 people viewed this question
Top Tsurumi Pump Plumbing Experts
Donni Steen
Tom Chichester
Are you a Tsurumi Pump Plumbing Expert? Answer questions, earn points and help others
