Question about Sony DVP-NS400D DVD Player
We're not getting any sound from the dvd's. I have two cables (green/blue/red) and (red/white). but I'm at a loss how to connect from DVD to TV. Help please!
    Guru:
  • 276 Answers
If your TV has the green, blue, red inputs then connect these 3 cables for the picture. DVD to TV, green to green, blue to blue and red to red. If your TV only has a yellow input, then connect the green cable only from the DVD yellow to the TV yellow. Now for the sound. Connect the DVD white to the TV white. Connect the DVD red to the TV red with the red cable. The white and red inputs will be next to the yellow and the green, blue, red inputs on the TV. Next select the TV input using your TV remote. Select the input for the DVD connection.
Posted on Sep 05, 2010
5 Suggested Answers
SOURCE: No VHS playback between DVD/VCR Unit and LCD TV (Both Samsung)
I am having the exact same problem....can anyone help?
Posted on Mar 22, 2010
  • 63 Answers
SOURCE: dvd won't send picture/audio to tv
for video, 3ways and any of this should work.
Step1, video out of dvd to video in on top at video1 section on tv. or
Step2, svideo out of dvd to svideo in at video1 section on tv. or
Step3. using component video DVD unit component video out to TV unit component video in at video2 Y to Y input of TV Pb to Pb input of TV Pr to Pr input of TV
for audio, connect left/right audio of dvd to left/right input of tv. Input section of TV is in the middle. on tv back panel from left to right is antenna input, IN section - this is it, use this for all your connections. let us know if you have any issues. thanks.
Posted on May 02, 2009
alexander404
  • 276 Answers
SOURCE: Which dvd connection go to which TV connection.On
Connect yellow video from DVD to TV. Connect white audio and red audio from DVD to TV. These will be next to yellow jack. That is all the connections you need for picture and sound. Use RCA cables available at Radio Shack or Wal Mart.
Posted on Aug 12, 2010
AJIN G
  • 6694 Answers
SOURCE: I just purchased a 37"
hi,
Do one thing connect the composite video and enter in to the setup menu of Toshiba DVD/DVR. Browse in the menu for the video output system format (color system). If you are in US then select the setting to NTSC. If there is no such setting in the DVDDVR then it is not compactable with the new tv.
OK
Posted on Sep 02, 2011
How to hook up Cables
Depends on what kind of cables you use. If you use an HDMI cable, then you simply connect one end to the DVD player to an unused HDMI port on the TV. If you are using a 5 cable Hi Def cable then you connect the outputs of the DVD player to the inputs of the TV color for color Red to red, blue to blue, green to green and red and white cables for the audio. If you are only using a cable with 3 connections, then yellow is for video out from the DVD to component in on the TV and then the red and white cables for the audio.
Mar 07, 2016 | Televison & Video
What cables go from my 55 inch hitachi tv to connect on the back of the dvd player . I have two monster cables red and blue together and three cables red blue and green together.
I have never herd of a red and blue combo but, The three, red, blue, and green are "component" cables. Hopefully your DVD player has a red, blue, adn green component out, not to be confused with red composite out. Composite cables are yellow, red and white, and, your tv has componenet in. The component cable will give you the best video quality. When installing make sure they are inserted all the way but twisting and wiggling or you will have a bluish, grenish, etc. picture. The composite cables give you the video only, so you will have to provide the audio. Audio can be achived using composite red and white or digital optical.If you second monster cable is red and white you can probably use those To go from "audio" red and white out on DVD to audio in red and white on tv. You must use the same audio input that corresponds to you video input.
Apr 09, 2011 | LG BD550 Blu-Ray Player
Which dvd connection go to which TV connection.On the dvd I have component(white), video(red),audio(orange), y(green),Pb(blue) and Pr(red)
Aug 11, 2010 | Televison & Video
The picture is green
Make sure that the unit is connected to the tv properly. Be aware that most dvd players have six connections. You can connect the unit to the television using RCA cables (yellow, white, red) or RCA sound with component video (white, red, blue, green, and red). When using the yellow-white-red method, the sound is carried by the white and red cables and the video signal is carried by the yellow cable. If you're using the white-red-blue-green-red method, the white and one of the red cables carries the sound, and the blue-green-red cable carries the video signal. This connection uses one cable for the green component of the picture, one for the blue, and one for the red. Make sure that the cables are connected properly and you don't have the two red ones mixed up. Connect Sound-R to Sound-R, component R to component R, etc. If that doesn't work, you may be able to adjust the picture on the tv. There's still a chance that the machine is defective.
Mar 08, 2010 | Daewoo DVRS04 DVD Recorder/VCR
I Have just bought this reviever (Yamaha Rx-v365)and im just trying to work out how to best connect all my devises. I have Tivo, Lg DVD player with both yellow, red white cables and blue green red cable...
Hi, firstly some terminology:
yellow cable - video composite (worst quality)
white/red - stereo analog audio
blue/green/red - video component (second best quality after HDMI)
You are correct that RX-V365 doesn't do audio over HDMI. Moreover it also doesn't do any video processing, which means composite video input will go only to composite video output (and not to component); compoment input only to component output and HDMI input only to HDMI output.
If you have more devices of same video output (in your example the component blue/green/red), you can connect them to TV via the receiver. But if only one device of same video output, you can connect it directly to TV. There is no reason to go through your receiver for video.
For audio, you can use either the analog stereo white/red cables (rx365 has 5 such inputs) or better use digital SPDIF connection, which is slightly better quality and more importantly supports 5.1 sound. There are 2 types - coaxial (orange RCA plug, can use basic rca cable) and optical (square black connector). Receiver has 1x coax spdif input and 2x optical spdif inputs. Look at your other equipment to decide which cable to use.
For the analog audio inputs, I think you can assign it either to composite video or component video. So for DVD audio white/red plugs, you can choose if either Video composite yellow plug named DVD will be used, or component blue/green/red named DVD will be used.
Jan 03, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Trying to hook up the dvd player to the tv and I figured out how to get the color back on but the sound is terrible it sounds like its echoing. Can't figure out the blue green red combination for white red...
Your TV probably has several different ways of connecting video. One is component, which uses three cables. They are red, green, and blue (RGB). The video output on your DVD player will match this color scheme.
Another scheme for video is composite (because it combines the red, green, and blue into one cable). Composite video is usually a yellow "socket". It is simpler to connect, but the video quality is noticeably poorer than component (RGB).
Another scheme is S-Video. This is one cable (round and black), but you will see four pins inside the connector (and four holes in the "socket"). This accounts for the three cables in the component scheme with the convenience of having only one cable. The picture quality is almost as good as component as well.
In your case, there may be confusion between composite and component. If you have red, green, and blue sockets on both the DVD and TV, then make sure you use them and connect them color for color.
Now for the sound, this is simpler. Red is the right channel, and white is the left. Make sure you connect red to red and white to white. Then, viola, everything will be right.
I hope this helps.
Aug 24, 2009 | Philips Televison & Video
I have a samsung2333hd and want to connect a dvd player using the connections marked pr(red) pb(blue) y (green) when i connect them all i get a redish pink screen then when i connect two of them i get...
OK no problem here. I can help. First reconnect the DVD Player to the tv using the Compoment cables. Match Green to Green,Red to Red and Blue to Blue.. If this is done correctly then you will have normal looking picture. If the picture looks like it is missing the RED color then switch both Red cables. The pix should look normal. Then connect the RED and White audio cables to the audio inputs . Now the Pinkish color is a result of the DVD Player not being set to the "Progressive" setting in the DVD Player Menu. It will help to connect a set of COMPOSITE cables from the DVD Player to the TV's Composite Input. Those are the Yellow,Red and White inputs on both the tv and the DVD Player. This will allow you to see the DVD player menu in case you cannot see the menu while in the Component input. The Pinkish picture should go to a Normal picture.
Jul 04, 2009 | Samsung Televison & Video
Hook up of dvd to tv
hey I think you need to use component cables blue green red from the player to the tv, make sure the blue green red ports are also on the tv, note: red yellow white composite cable will not interchange with blue green red component cable or connection.
simplify- blue green red= component
red white yellow=composite
*wires must match colors on both tv and player inputs.
then set your input on your tv to where you conected the cable.
Jun 15, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
How to connect to TV
The Yellow/Red/White connectors are Composite+Audio
Yellow carries a composite signal and Red and White Carry left and right audio channels.
Red Green Blue Connectors are Component
Each coloured connector carries one 'component' of the picture
So yes, your extra set of red white yellow cables would be fine to use, just make sure you connect the same colors at each end red-red green-green blue-blue
However..... the red green blue only carry the video, you will still need to carry the Audio, this is usually done either by the red and white (L & R stereo) or your DVD may also have an optical or coaxial output to carry the sound. if there is no equivalent connector on the TV then you may be stuck swapping the red/white cables, usually though there would be 2 sets of red/white connectors one set to go with the yellow, one set to go with RGB.
Apr 22, 2009 | Televison & Video
Trying to connect my dvd to the tv plus i have cable
You can use the following:
TV Connections:
  1. Composite (red, white, yellow)
  2. Component (red, blue, green)
  3. HDMI -
DVD Player Connections:
  1. Composite (red, white, yellow) - comes standard.
  2. Component (red, blue, green) if you have it.
  3. HDMI - if you have it
You can use any of those to connect the dvd player to the tv. You can use the remainder to connect the satilite box.
Feb 29, 2008 | Televison & Video
Sony DVP-NS400D DVD Player Logo
457 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
