Question about Toro Z Master Zero Turn Riding Lawn Mower 19 Hp 34" Cut
How do you install a belt on a Toro Time cutter 14-38Z Riding lawn mower?
  • 148 Answers
SOURCE: Need Parts/Service Manual for Toro HMR1600 mower.
Go to www.managemyhome.com and put in your model # for the manual (You can download to your computer). Also try www.searspartsdirect.com and put in you model # and you should be able to see all the parts for your mower.
Posted on May 19, 2009
  • 17 Answers
SOURCE: My Toro lawn mower won't stay running. It will
You need to check a few things. The spark first, you need to check if it is running correctly, does it have spark, by doing this: take out the spark, put it against a metal surface and pull the pull start if it spark, your good if not you need a new spark plug. Clean out your airfiilter it migth help too. Buy some carb and choke cleaner squirt it up theough the airfilter hole, and start the engine, this will clen the carb. yOU MIGHT NEED TO TAKE OUT THE CARB AND CLENA I OUT THROUGHOULY!!! Try that and it whould work after all these steps!
Posted on Aug 11, 2009
  • 85 Answers
SOURCE: The motion control levers became tight to move and
You may have some bent or out of adjustment linkages, causing the brakes to stay on.
Or the friction nut (one on each transmission) is too tight. These are located just in front of the axel, they go through a slot, the washer behind the nut should turn freely
Posted on Aug 17, 2009
  • 8404 Answers
SOURCE: Toro self propelled mower rear wheel keeps falling off
Are these regular bolt on wheels? Have you changed the nut?
I would expectc to find a "Stover" nut on such an appllication. Stover nuts are similar to "NY-Lock" but without the nylon lock. Rather, Stover (and you have to ask for them at the hardware or auto parts place), are not round and/or have had a certain side portion punched to make the nut hard to put on. Some well meaning back yard mechanics (read me) have 'fixed' the Stover by running a tap through them maning them easier to get onto the threads ... but alas, it didnt stay. That was how I learned about Stover.
Let me know if this helps.
A
Posted on Sep 21, 2009
rwvanlue
  • 486 Answers
SOURCE: Stuck pull cord on Toro 6.5 self-propelled mower
1) Common problem when a mower sits for several weeks at a time between mowing;
check for extra grass debris to be glogged between the blade and the mower shell.
2) If the mower has a 'bail' or 'zone' control handle;
this releases a brake mechanism on the flywheel to allow it to rotate, and after it is running, releasing the lever will 'kill' the engine.
NOTE* when transporting a push mower in the trunk of a car, try to keep the mower as level as possible.
*extra note when mower has been transported in the back of a car;
sometimes the mower is placed in a trunk at such a severe angle that the oil from the crankcase is forced around the rings and sits on top of the piston so that when you try to pull the rope you have a 'hydra' lock. (that is when a liquid is between the piston and the spark plug) You cannot compress a liquid, so the rope appears stuck.
If this happens, remove the spark plug (make sure the loose plug wire is fastened away from any combustable that comes out of the spark plug hole *** AND THERE WILL BE A HUGE STREAM OF OIL AND GASOLINE, SO BE PREPARED TO CLEAN UP A MESS ***
pull as normal until fluid is dispelled from internal engine
clean or replace the spark plug
a few more pulls (no choke required) and you are up and going
Posted on Nov 08, 2009
When i turn the key I hear a ratcheting sound but the engine isn't turning over
clean battery terminals
charge battery
have a load test done on the battery
Apr 16, 2016 | Toro Mowers - Time Cutter SS3200 32""...
Pto will not work on ss4235
could be the switch, pto assy, fuse, broken wire. belt off the pulley. take your pick
Jun 18, 2015 | Toro Mowers - Time Cutter SS4235 42""...
My toro 3200 seems like the transmission is locked
check the brake make sure its disengaged
if it wasnt moved in awhile brake can stick
Feb 07, 2015 | Toro Mowers - Time Cutter SS3200 32""...
What is the torque spec for the lawn more blade
tighten it as tight as you can the turning blade will tightren more
Sep 07, 2014 | Toro Mowers - Time Cutter SS4235 42""...
Time cutter hydro does not move but i can hear it whine
Did you check the could have air in the system, did you check the hydro oil level? In my experience with toro hydro systems is when i change the oil air gets in the system. At low rpm move control handles forward and reverse several times until air works itself out. if this doesn't work more than likely there could be internal pump problems.
Sep 02, 2013 | Toro Riding Lawn Mower. TimeCutter SS4235...
Toro 50" time cutter when engaging blade loud
I would remove the deck and belt, then spin each blade to isolate the loud noise. Also, make sure the blades are not bent hitting the deck. I always balance my blades after sharpening as well. By isolating the bearings spinning them one at a time, this will tell you where your problem lies. Hope this helps!
Aug 10, 2013 | Garden
I only have control of left side of my time cutter
You might want to post this question in the lawnmower section so that the proper expert sees it.
Sep 04, 2012 | Toro Mowers - Time Cutter SS4235 42""...
Lawn mower repair
You might want to post this in the lawnmower section so the proper experts will see it.
Sep 03, 2012 | Toro Mowers - Time Cutter SS4235 42""...
Cant turn toro time cutter to the right
Sep 02, 2012 | Toro Mowers - Time Cutter SS4235 42""...
Toro riding mower stopped cutting but still runs
Check if your drive belt has broken / come off the pulleys.
Also, if it has an electromagnetic cutter engagement, is it engaging the cutter drive?
Jun 17, 2012 | Toro Garden
Toro Z Master Zero Turn Riding Lawn Mower 19 Hp 34" Cut Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
