Question about Nokia 6270 Cellular Phone
6270 upper keypad not working
My upper keypad for 6270 is not working. Have you got any solution...
  • 3 more comments
  • Vedant18 Jul 05, 2008
    upper key of middle button is not working
    any solution plz??????????
  • almasstz999 Jul 24, 2008
    display and upper keypad not working
  • punit195 Sep 30, 2008
    display shows upside down and sometimes total blank and upper keypad not working
  • sanjay_sharm Nov 12, 2008
    except number keys , no keys are working and when I open the slide screen shows blank , like no power .
  • maknil Nov 20, 2008
    I am also facing the same problem.
Change the Strip of the phone it will work fine
Posted on Feb 05, 2009
The upper keypad four out side buttons and down arrow does not work when the slide is open. However they do work when the slide is closed. Hope some one has a solution. Nokia must have put life in this expensive phone. It is not like the die hard Nokia 3395
Posted on Dec 02, 2008
My upper keypad for 6270 is not working. Have you got any solution...please send me e_mail. HELP MEEEEEEEEEEEE.......
Posted on Sep 29, 2008
Inside belt(cable) problem. Change your cable then it works
Posted on Jul 31, 2008
Button are not working
Change the keypad IC.So, better to contact mobile repairing shop.Good luck
Feb 08, 2012 | Nokia 1100 1101 1108 1110 1112 1200 1208...
My 6270 backlight when it suppose to turn on sometmes it doesn't or sometimes comes on dim. If I tap the side it comes up bright. I am familiar with trouble shooting circuit boards to a component...
Sound like u have loose Fiber Optic cables connections cables somewhere,if u tap the side of it comes back brightter.Take the unit aparts and tries reconnected all the Fiber Optic cables tightly if it work.Tries it out the unit turn it on/off 5 or 6 the backlight go up good and bright.Take hot glue gun glue all the Fiber Optic cables connections together for good.
Aug 11, 2011 | Ademco 6270 Graphic Touchscreen Touch...
Hello I have the 6270 touch screen keypad, however when I tried to armed (clicked into security/then select either AWAY, STAY or NIGHT) nothing happen I just heard a click and that it, do not arm, and...
sounds like the system battery may be low. The system batter is usually located , depending on the system, in the main box in a closet. The system battery powers the system in the event of a power outage.
May 13, 2017 | Ademco 6270 Graphic Touchscreen Touch...
Nokia 1315 lcd and keypad light not working
pour formater nokia 1315 avec code sans pc cabel merce
Mar 30, 2011 | Nokia 1100 1101 1108 1110 1112 1200 1208...
My 5300 keypad not working
the flex or ribbon of your 5300 is not functioning you must replace it or try to clean the interface of the teminal of the flex...
Feb 06, 2009 | Nokia 6270 Cellular Phone
FORMET MY NOKIA 6270
You can format nokia 6270 becuase no codes of symbian operating system mobile works on it.It is a java based mobile..All you can do is Restore to factory settings in settings...But you can update the nokia 6270 firmware by installing nokia software updater and nokia pc suite...
Regards
Dilip
Nov 01, 2008 | Nokia 6270 Cellular Phone
Nokia 6270 some butons do not work
Yes its happen with nokia 6270 that after some time key pad do not work properly. so to solve this problem you should know how to open it.i too have the same and i opened it to work keypad normally.so if you want to open it take a knife and use any corner from top,just insert it and pull it up ,you will see it opening do the same for other corner ,when it is open use a cloth to clean the surface of the keypad .if you are unable to open it please take it to any mobile repairing shop..
for your second issue phone delaye when starting phone..
for this there are many reason ,
1st your mobile is filled with too many sms ,
2nd device memory is full.
3re memory card is of 1gb and it is full
so all this can make your mobile delay when starting .
Solution :
You can use settings > Restore factory setting .type security code and let it restart..
If still you see delay for few seconds
You can update your mobile firmware(software).
Just install nokia pc suite and than instal nokia software updater ,if you dont have nokia software updater you can download it from nokia website ..install nokia software updater .after that use your cable to connect mobile with computer .start nokia pc suite you will see a option "UPDATE PHONE SOFTWARE ".click on this and follow on screen instruction to update your mobile firmware with the latest firmware....this will definitely resolve the issue that you are facing and it your mobile will work faster than before as how my nokia 6270 working ................thanks
_____________________________________________________
Low feed backs hurt my ratings and I tried my level best to resolve the issue. so it will be highly appreciated if you provide your feedback..
Thanks for using fixya support..You have a wonderful day
Jun 06, 2008 | Nokia 6270 Cellular Phone
Nokia 6270 upper key pad
you need to change the connectivity strip(patta) it is available only in 250 rs. when the strap is damaged then bthis issue occurs for more info mail me rahul.srivastav444@gmail.com
May 14, 2008 | Nokia 6270 Cellular Phone
Keypad problem of nokia 6270
upper keypad is not working properly
May 01, 2008 | Nokia 6270 Cellular Phone
Nokia 6270 Cellular Phone Logo
187 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
