Question about Toshiba TheaterWide 46HM94 46" Rear Projection HDTV
I have a toshiba 46hm94p dlp tv. i need to replace the ballast. i pulled the tv apart and got the part number off the ballast, it is RPB-4434ZA . when i look that up by the part number it says its the ballast for my tv but when i search by my tv (46hm94) it gives me the part number of # D4434M-01.they both look the exact same. will either of these ballasts work or do i need to get the one with the same exact part number?
  • Toshiba Master
  • 3,710 Answers
Yes they both the same part number one is board number and other is manufacturer number, board number is what it is and manufacture number is if its in other tvs.
Posted on Jul 15, 2017
  • 146 Answers
SOURCE: Samsung DLP hlp5685w won't come on
Is this 330, 80, 7.5 volts that you are reading, The B+ that is going into the ballast?
Posted on Mar 15, 2008
  • 4234 Answers
SOURCE: Toshiba Ballast part number
Use the following part number: 23122468. The cost is $48.38 from TRITRONICSINC.COM
Dan
Posted on Mar 18, 2008
yambo
  • 230 Answers
SOURCE: Looking for a ballast part number and price Mitsubishi WD-C657
encompass.com or parstore.com is a good store parts.
Just provide model number tv.
Thank you
Posted on Aug 07, 2009
johnnydiode
  • 647 Answers
SOURCE: replacing ballast
To confirm if the ballast is bad check the ballast board to see if the spark gap (on the ballast board) lights when you first turn the set on. If it does than the ballast is ok.
Posted on Sep 20, 2009
axeist
SOURCE: 52HM84 Toshiba DLP with apparent failed lamp (replaced ballast)
I found R3 on the original board to be open, along with reading an open on CR1, D5 and D6. All the other transistors and the transformer check out. The only thing I have to do now is find out the specs of the diodes. The replacement board also had CR1, D5 and D6 open (R3 was OK). There had been some threads on various locations where remanufactured boards had bad components (the transistors were changed but not some of the other components).
Posted on Jan 18, 2010
How does a ballast for a hitachi ultravision dlp tv look
Anon, the bulb/lamp plugs into the ballast, The attached videos shows the ballast and location near the end of the video. Check the attached links. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HITACHI how to replace your enclosure guide
Mitsubishi Toshiba Samsung DLP TV Bulb Won Turn On DIY Easy DLP Ballast...
hitachi ultravision dlp tv replacement ballast Google Search
Apr 20, 2016 | Hitachi Televison & Video
The lights indicated that I needed to replace my lamp. After doing so, the TV still doesn't have picture. What do I have to do to get it to work?
It is possible that the Ballast is not turning on the lamp. In past years it had been difficult to get the Ballast separate from the Optical Block but they seemed have them available. In order to replace it you will need to remove the Optical Block which is in the center. The ballast assembly is mounted on the right side of the OpticaL Block. Once the Optical Block assembly is removed, it is not difficult to replace. To order a Ballast, call 1800-631-3811. You will need the model number.
I hope this helps,
Skyassoc
Dec 10, 2010 | Toshiba 62HM95 62" DLP HDTV
My Toshiba DLP Projection TV (52HM84) will not always power up. It sometiems goes through five of six retries. Is it the paower supply or maybe a related part (capicitor) ?
Pull back make sure Fans are clean ,But if you have never replace Lamp ,Lamp needs to be replace call Mats 1-800-628-1118 Rember also Ballast board is what turns Lamp on For Ballast board call Encompass 1-800-638-3328
Sep 26, 2009 | Televison & Video
My rca tv not working
the lamp which you rteplaced is not seated properly.and also it can be the problem of colour wheel or the ballast.to check out all three just check out this links 1 by 1 for colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
for lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
for ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Feb 09, 2009 | Toshiba 32AF41 32" TV
Toshiba dlp red light green light on and off no image
It was the lamp cover original response was right on point
Nov 29, 2008 | Televison & Video
Dan
Mar 18, 2008 | Televison & Video
Toshiba 52HMX84 Sound no picture.
It's not a 1k Resistor but a 10k...it's the resistor R3 on the Circuit Board Part Number RPB-4434ZA (P/N: 23122468). If you don' replace the resistor you will keep burning your lamp. If you decide to replace the resistor by yourself...you should take the time to look at all the on the back of the board. This Board is made by the company Rubicon Corporation for Toshiba and it's a issue on the Toshiba DLP TV (62-52HMX84). If you don't wanna do the job yourself..bring your TV to a repair and give him the part number of the board and ask him to replace the board for you. If the price is higher than $350.00 go somewhere else...He try to fu....^&*%*%&%.
My email address is sleeper773@hotmail.com
Jan 16, 2008 | Toshiba 52HMX84 52" Rear Projection...
Toshiba TheaterWide 46HM94 46" Rear Projection HDTV Logo
168 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
