Question about Brother IntelliFAX 4100 Laser Fax
Says to replace drum soon, i've bought two, and still can't make copies or receive faxes]
  • 1,110 Answers
Perform the manual drum counter reset. Open the front door cover & keep open. Then press clear. It should say replace drum, press 1 for yes it should then say accepted. Close cover & off you go.
Good Luck and Thank You for using Fixya.
Posted on Sep 04, 2010
Fax will not receive but will send faxes? What could the problem be?
Does it not recieve or just not print? If the drum is low it is possible that the machine will not print faxes.
Jun 26, 2015 | Office Equipment & Supplies
"Replace Drum" error ...HELP!
Drum is only to be replaced when machine says "Replace Drum".
Not "Replace drum soon".
Try Programm, * , * , I(Capital Letter I ), then ENTER.
Should reset it.
Apr 22, 2010 | Muratec F320 Plain Paper LED Fax
I replaced the drum in the fax machine and it still say i have only 14 copys left, how do i reset that? I have muratec fax MFX 1700
You are not supposed to replace the drum until it says"replace drum"
Not when it is saying "replace drum soon."...you have prematurely blown fuse in the cartridge so now it will not reset.
Try the following...
Press...PROGRAM,*,*,I(That is Capital I), then ENTER.(SHOULD RESET IT.)
Nov 16, 2009 | Muratec MFX-1700 Fax
When I get or receive faxes, the right side is blurred.
If your getting blurred copies you may have moisture on your drum. Try cleaning it with alcohol(only) . If the problem persist replace drum.
Jun 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Lines and breaks on docs received by other party.
Hi
If you have lines when faxing out it cant be the drum,If you have lines with copy and receiving faxes then it can be the drum.
I think you problem is a dirty scanner glass.Check the glass and clean.
Nov 18, 2008 | Office Equipment & Supplies
Drum intellifax 4100 Brother
some faxes will shut down if it senses toner low/out
you must replace and maybe reset counter
Jul 30, 2008 | Brother IntelliFAX 4100 Laser Fax
Okifax 4580 oki "change drum soon"
1st replace drum if needs to!than press select function button!counter button,new drum reset select yes than start button should reset!
Jun 17, 2008 | OKIFAX 4580 Plain Paper LED Fax
TX problem
If I understand you right, what you send, people are receiving blank sheets?
When you try to run a copy are those blank also?
If so your problem is with the scanner. The drum should have nothing to do with sent faxes.
Unless your putting the paper in the scanner upside down. And if you ran it enough to need a drum I can't imagine that .
May 15, 2008 | Xerox FaxCentre F116 Plain Paper Laser
Brother IntelliFAX 4100 Laser Fax Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
