Question about Acer AL1714 17" LCD Monitor
Acer 1717 Hi ... I have a problem with a Acer 1717 ... noisy vertical bars in the video
    Brigadier General:
  • 6,966 Answers
"noisy vertical bars in the video" is indicative of 60 Hz AC component riding in with the video signal. Pls check that all connectors are snug and fit to where they are connected. It would do no harm to try to remove and reinstall/reconnect all cables. Additionally, try plugging in the monitor into a different socket/AC mains. Further, you may want to try and check your cable for any stray shielding or anything out of the ordinary.
Other than the above, could not suggest more easy user action. The alternatives are to try a different monitor to determine if it is the computer video card or the Acer 1717 that is in question; or try the Acer 1717 in another PC. It should be mentioned that some household appliances can also cause AC interference such as florescent lamps, wireless phones or even an electric clock.
Of course you can also try increasing your PC's Screen refresh Rate to anything other than 60Hz.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 12, 2008
Is Acer 1717 Display board and Acer 1716 board are the same? I need a replace ro my Acer 1717.. But there are no boards available.. But Acer 1716 boards are available.. Someone help.. Thanks a lot...
There are more than one version of the AL1717, also more than one version of the AL1716.
See my pictures here:
http://s807.photobucket.com/albums/yy352/budm/ACER/
See if they match your monitor.
Best thing to do is to get the numbers as printed on the board and Google it.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 19, 2011 | Acer AL1717 17" LCD Monitor
Hi! I have an ACER LCD MODEL 1717 F but no sound. Kindly solve this problem.
First right click my computer then click properties then hardware then device manager and expand the sound video and game controller and see if the driver is marked with yellow question mark or marked with red X then you will have to reload the drivers and if you dont see any audio drivers then switch of the computer press del and enter bios and enable the audio device then click the volume control in theoolbar and check wether mute is clicked if clicked remove them and adjust volume slider to high
Jun 02, 2011 | Acer AL1717 (Silver) 17 inch LCD Monitor
My acer (aspire one) note book keeps flickering, any advices?
Hi, if you have encountered vertical or horizontal lines on your screen and at the same time you have an imbalance color of your screen. Please call your acer tech support for possible repair.
Probable cause is video card not functioning and needs to be replaced immediately...
Jun 06, 2010 | Acer Aspire One PC Notebook
Color bars only on KWorld PC to TV - Composite and SVideo
found this reference it may be of help
This product appears to be defective. I connected it to a working video camera that produces an excellent picture on a standard monitor. I looped the video from the camera through the monitor to the converter which is connected to a new ACER LCD display. The LCD display workes perfectly when connected to my computer. Using the converter, the results are poor. You can see the desired picture in the background but in the foreground there are horizontal bars that scroll vertically through the picture. I'm returning it for an exchange - will try again.
Jul 26, 2009 | KWorld PC to TV (0872880887527) Video...
ACER AL 1717 (Dispaly massage INPUT NOT SUPPORTED) ? OS: WIN XP sp2
i think the probelem is monitor resolution out of range . connecte the system other moniter and chage resolution then try .80% problem is fixed or other probelem is monitor hardware falier
Jul 18, 2009 | Acer AL1717 17" LCD Monitor
Vertical bar about 3/4" from top to bottom of monitor
panel is done. economical to repair. new panel is about 90 percent the cost of the tv new
Jun 03, 2009 | Fujitsu Plasmavision PDS-4233 42 in....
Dark Grey Vertical Bar
1. try connecting laptop to an external monitor and check if this vertical dark gray bar appears. if yes it means video is the problem. you need to boot in safe mode then uninstall the video driver. boot to notmal mode then download and install the latest video driver. if still same problem then replace video card. if video is built in with motherboard you need to replace motherboard.
2. when the vertical dark gray bar did not appear in the external monitor then it means issue is with the LCD panel. Do this turn off laptop. press and hold D key then press Power button at the same time or Press and hold on the Fn key then Power button check if the test will run. Color displays full screen when you keep pressing on N key when the colors appears check the vertical dark gray bar if still exist in the test, this means LCD panel and LCD cable needs to be replaced.
Oct 31, 2008 | Computers & Internet
Acer 2410 display having 3inches wide black vertical line at the right end
Hi...there,
The problems.. your panel are damaged. Don't bother to replaced...will cost you a lots of $$$.... It's time for retired...
Oct 14, 2008 | Acer Refurbished 11 3 STN LCD DISPLAY **...
ACER 3023 SCREEN PIXELATING
Try uninstalling and reinstalling the video drivers. If this doesn't work, it's likely that the LCD control board or cable is damaged.
Feb 13, 2008 | Acer Aspire 3000 Notebook
Acer AL1714 17" LCD Monitor Logo
69 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
