Question about Freeplay Energy BayGen AM/FM/SW Radio
My freeplay classic radio wind up unit making noise when running. What can I do about this? Thanks, John jdnastasijr@yahoo.com
4 Suggested Answers
  • 883 Answers
SOURCE: crank problem
the drive mechanism has failed. try this. ensure it is fully unwound. then open it. then look for some part of the drive gears or belt that has broken or has slipped off. caution, you MUST ensure it is fully unwound prior to opening it.
Posted on Jun 04, 2007
SOURCE: Original Freeplay windup radio.
it sounds like your drive belt has worn out. Check ebay, there is a guy who sells the belts. it is a thin O ring type drive belt and is simple to fix. Search for "baygen belt".
Posted on Jul 29, 2008
SOURCE: summit freeplay "locked"
If you push the time set and alarm set buttons simultaneously this will lock/unlock the radio
Posted on Aug 26, 2008
When turning the crank, the spring slips, and the crank flies back to original position. Spring will not wind up.
One day while cranking the freeplay PLUS Radio on a job site with no power, something inside snapped, and made a horrid grinding noise. All of my co - workers laughed. From then on I only used the radio with the AC plug in adapter.
After 8 years of keeping the freeplay plugged in to listen to it I finally decided to open it up and take a look.
Low, and behold I found some broken pieces that looked like a belt. HMMM?
After a little more investigating I found the 2 drive wheels that power the generator... with no belt on them. I looked in my junk drawer, and found a small blue rubber band amongst the others that I save from packaging items. It looked suitable to do the task. After stretching it around the generator drive wheels, I cranked it up, and IT WORKED!
I'm still waiting to see how long this fix works, but in a pinch... keep some rubber bands and a phillips head screwdriver around. This may be the same problem your having. I'm now getting the long lost last laugh.
Hope this helps! KMT
KMT
Feb 19, 2011 | Freeplay Energy BayGen AM/FM/SW Radio
Cobra 29 ltd classic will not power up
Hi pig pen, my name is John. Welcome to FixYa. Check that the in line fuse is not blowed. Make sure that you are getting power to the unit, and that it is grounded good. Let me know if you need more help from this point,and I will post the solution here. Thanks for choosing FixYa...John
Dec 03, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
I have a cobra 29 ltd chrome and it making a lot of static noise while driving or idling. it transmits and recieves fine though
Hi, my name is John. Welcome to FixYa. Try running your power strait from the battery, that will bypass a lot of your noise. RED (+) ground (-) . Thanks for choosing FixYa....John
Nov 30, 2010 | Cobra 29 LTD CB Radio
I have had a Cobra 29 BT installed and my reception is nothing but loud static only when moving. It is a 2010 Freightliner and SWR is consistently high at about 3.0. Is this a coax or antenna problem?
Hi,my name is John. Welcome to FixYa. It could be both. Try running your unit direct from or to the battery, bi-passing all ignition noise. Make sure your antenna is getting a good ground, have your SWR checked at a near-by CB shack, or Radio Shack all for free. Thanks for choosing FixYa....John
Nov 16, 2010 | Cobra 29 LTD CB Radio
When the engine is running all i hear is engine noise how do i fix this
Hi, my name is John. Welcome to FixYa. Try running your red and black wires directly to the battery. Then if your radio has a Noise Blank switch or a noise limit switch, turn it to on. Good luck and thanks for choosing FixYa...John
Nov 05, 2010 | Radio Communications
I have an original freeplay clockwork radio which has died. Help!
Hi , you have probably expired the battery life out of the radio [ they have a recharge battery life ] but all you have to do is replace those recharge batteries with new recharge batteries and your as good as new
Jun 12, 2009 | Freeplay Energy BayGen AM/FM/SW Radio
Tony,
Can't help you with the aerial. Mine made the same noise when winding down and I fixed that by pouring talcum powder around the windup section. Let it unwind and allow the talcum to go in,,,, and presto.......no more grinding noises.
Carlo
Jul 07, 2008 | Freeplay Energy BayGen AM/FM/SW Radio
Spring broken?
Solution #2 is correct. My Baygen Freeplay radio was running fast and mine had a broken belt. I could not find a belt on eBay. After hours of searching the internet, I fond a replacement belt at http://www.kenselectronics.com/lists/belts.htm I have the older large Baygen Freeplay radio without solar power and this is the belt that fit my radio... AV-SBS9.5 Replaces SBX9.5 & 1407-36 & SCX9.5 square 9.5 x .047" belt, Baygen Freeplay. Just search the website above... they also have a second size Baygen belt that might fit the newer Baygen Freeplay radios???
Feb 27, 2008 | Freeplay Energy BayGen AM/FM/SW Radio
Summit freeplay "locked"
If you push time set and alarm set buttons simultaneously you can lock/unlock the radio
Oct 12, 2007 | Freeplay Energy Summit AM/FM/SW Radio
Crank problem
Jun 03, 2007 | Freeplay Energy Plus AM/FM/SW Radio
Freeplay Energy BayGen AM/FM/SW Radio Logo
98 people viewed this question
Top Freeplay Energy Audio Players & Recorders Experts
RudeRude
John In Milford
John In Milford
Are you a Freeplay Energy Audio Player and Recorder Expert? Answer questions, earn points and help others
