Question about Electrolux 31 in. E30EC65E Electric Cooktop
Switch burns within and literally melts. We replaced with a new one and now it is happening again.
  • 15,935 Answers
In this case - you will be looking for a grounded (bare) wire to the chassis metal.
it will take some investigation to find the bare/cracked wire.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 05, 2010
Why Is my cooktop tripping the breaker?
my blower switch shorted out. Could smell the plastic once removed. Liquids dripped into contacts during cleaning. Switch replacement obsolete. Found switch @ Ace. Made modifucation to panel to accept rectangular switch.
Mar 28, 2015 | Jenn-Air Cooktops
4yrs old, blew the house fuse and no longer works
You have a short some where in the cook top,or wire thereto, you need to replace? cost vs Appliance repair service. If it is a cooktop that fits on a counter top you may be able to remove and replace with "lightly used" Check with family or friends who are electrical and safety Literate to take a look. They may find a loose or burned wire.
Mar 12, 2015 | Cooktops
We have a JennAire model CP220W-C01 cooktop. We use the old coil type heating elements. There was a flash and smoke from the right front element. A repairperson replaced the connector, only to have it blow...
Unplug the element from the receptacle and then disconnect the receptacle from the point where it plugs into the stove. Now, carefully, turn on power to this heating element. If nothing happens then you have removed the likelihood of a problem in the large portion of the stove's wiring. Next, plug the receptacle cable back into the stove without connecting the heating element. Again, carefully turn on the power to the heating element in question. If there is no spark then the cable, connector and receptacle are ok. If it does spark, replace the receptacle and cable assembly. No spark, then inspect the heating element where it connects to the receptacle. Look for melting or signs of damaged insulation that would allow for a "dead short". If you see damage to the element then replace the element. No damage, clean the connections with a toothbrush, and plug the element back in and turn on the juice. If it sparks again, replace the element. Good luck and be careful. Don't attempt any of this if you are inexperienced in working with electricity. 220 Volts can cause death or serious injury... just the flash from an arc can cause blindness and burns.
Nov 05, 2013 | Jenn-Air Cooktops
I have intermittent problem with two of the four rings - sometimes they work sometimes they don't
see this causes and proceed for fix it. God bless you
Surface Element Switch If the surface element won't work, and there is another element of the same size on the stove, try switching the elements. If it still won't work, the surface element switch is probably defective. The surface element switch can't be tested or repaired, it will have to be replaced.
Surface Element Board If a surface element won't work the surface element board might be defective. Each burner is switched on and off with the help of a relay on the surface element board. If one or more relays has failed the surface element won't work. If two or more burners fail at the same time, this is likely the problem. If only one surface element won't work and the element itself checks out to be good, the surface element board might be defective.
Coil Surface Element If the surface element won't work, the coil surface element might be burned out. Most coil surface elements can be pulled out of their socket and checked with an Ohm meter for continuity. If the surface element won't work, check to see if there is any visible damage to the coils. Also, check to be sure the element is pushed all the way into the socket.
Radiant Surface Element The most common cause when the surface element won't work is the radiant surface element itself. The radiant surface element - or heating element - can burn out similar to a light bulb. If the surface element won't work and it doesn't have continuity, it will need to be replaced. The radiant surface element is not repairable.
Solid Surface Element If the surface element won't work, and the stove has the solid surface element type of heat, it's likely that the solid surface element itself has burned out. The solid surface element works very similarly to other surface elements - inside there is a heating element that glows when electricity is applied to it. As it gets hotter, the heat is transferred to the solid surface element
Terminal Block If a surface element won't work, there may be a problem at the terminal block. The appliance has a power cord which is attached to a terminal block. Over time, the connections at the terminal block can fail and burn open. When this happens, normally all of the surface elements won't work. The solution is to replace any burned wires and replace the terminal block.
Loose or Burnt Wire Connection If surface element won't work, there might be a burnt wire supplying power to the surface element. Sometimes the wire supplying power to the element burns out right near the element itself. Check for this by just looking at the wires leading to the element. If they're burned out it is usually easy to spot.
Incoming Power Problem Although not as common, if the surface element won't work it is possible that the appliance is not receiving proper voltage. Electric ranges require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the surface element won't work. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
Oct 02, 2012 | Neff Cooktops
My cooktop igniter keeps on igniting for no reason
This problem is due to a short to wires contact on the igniter sometimes this happens after a cleaning of the cook top with water so in this case you just use hair dryer and dry out the ingniter.
Other possible reasons are over heating of the ingniter contact so you have to remove it and clean wire contacts.
Finally the igniter contacts are melt together or sometimes full of burned oil and they need to be replaced. Inginter is not expensive part.
Oct 02, 2010 | Baumatic 34 in. B17.5 Gas Cooktop
I was roasting a chicken in my Maytag Cooktop when I heard a loud buzzing and a "pop", all of the power in my house went out. Something had tripped the breaker. My husband reset the breaker but my stove...
there is a short for sure, sometimes when the heating element burns out and melts, it touches the metal inside the housing causing a short. inspect the heating elements in the oven(top and bottom). the loud buzzing sound is what a shorting out heating element makes as it melts like a weldin rod, usually because of using tin foil(not recommended)
Jun 15, 2009 | Maytag MEC5430BDS Electric Cooktop
Burned Copper Bottom Pot on Glass Stove Top. This left a ''melted'' portion of the pot on the glass. Any ideas on how to remove the melted residue?
sorry to say no , if you try to peal it off or scrape ot off you will crack the cooktop . this keeps happening i have seen it at around 4 times for some reason revere ware melts . there should be a warning in the manual ( i know ge does have the warning about copper bottoms ) . replaceing the cooktop or the whole stove is the only "true" answer .... sorry .....Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 02, 2009 | GE Profile JP930 Electric Cooktop
Smeg SA435 - spark and loud sound
hi gud day,much better call an electrician to check ur main power & the outlet of ur unit.if ok i think the problem is inside the unit,open wire or have a ground inside coz of over using the item that may coz of the wire is melting.tnx
Feb 04, 2009 | Smeg 23 in. SA435X Electric Cooktop
Stove not on - but fan comes on automatically -
it sounds as if the thermostat is broke. it could be the two wires off the thermostat are after melting together. ( burning smell). the thermostat stops power going to fan when it sences below a certain degrees. but your one has been cut out of the circuit due to the two cables melting together. this means fan will constantly stay on. you need to find and replace thermostat and make sure no cables melted together. if they are then seperate and use insulating tape to re insulate.make sure circuit breaker is off while doind this
Jan 16, 2009 | Jenn-Air JED8230 Electric Cooktop
Burner fails to ignite
I have this cooktop and it is hands-down the worst. That clicking sound is the spark missing the mark because of a crack or chip in the ceramic igniter. Damage is caused by the ceramic heating too quickly. Especially when the house is cooler in winter, or in air conditioning. I had a Jenn Air repair guy in to replace them before the warranty ran out and he said this happens with every single one of these models with the ceramic igniter. Also, one of the knobs on the front by the medium burner got so hot it melted. He gave us a new one. He had a whole box of them in his truck! He told us the design was inferior and that Jenn Air uses a different igniter for higher end models because of this problem, but won't re-engineer the lower end units because it's cost prohibitive. Even with the repairs they cover for the first year, they recoup in charging for service the second year, than profit on the repair and/or replacement charges for the parts every year after that. All the parts sold are OEM--no after markets, so, at roughly $27 a pop for each igniter, they make out pretty good. Oh, and the burner knob is melted again. What a bunch of scamsters. I will never give them my money again and am shopping for a new cooktop. I left a good review at bizrate for this cooktop.
May 18, 2007 | Jenn-Air JGC8536 Gas Cooktop
Electrolux 31 in. E30EC65E Electric Cooktop Logo
53 people viewed this question
Top Electrolux Cooktops Experts
rugby prop
Paul Carew
Are you an Electrolux Cooktop Expert? Answer questions, earn points and help others
