Question about Sony PlayStation 2 Slimline Console
My ps2 slim is not reading any discs why ? - Sony PlayStation 2 Slimline Console
    Genius:
  • 1,035 Answers
Hi. Try to clean the lens by using a qtip and alcohol. Here's the procedure on how to clean the lens.
  • 1 Turn the PlayStation 2 over to remove the screw covers. Use the flat head screwdriver to remove the plugs that cover the screws. This reveals several Philips screws. Do not remove them yet. They must be unscrewed in a certain order so that the PS2 opens up properly.
  • 2 Remove the small screws near the control ports, powerboard and DVD drive using a Phillips screwdriver.
  • 3 Remove the long screws from the upper right section. This enables you to remove the cover.
  • 4 Flip the PlayStation 2 over to open it up. Before opening it, ensure the PS2 has had adequate cooldown time. Wait at least one hour after playing the game station before continuing. You do not want to burn yourself on the hot elements within.
  • 5 Open the PS2 carefully so as not to damage the ribbon inside the console. Lift up the case gently and slide the cover off. Notice the big black box that contains the laser lens and DVD drive unit you need to clean.
  • 6 Locate four black, small screws holding the black box down. Remove the screws using a Philips screwdriver.
  • 7 Lift up gently on the cover of the DVD drive. This fully exposes the laser lens.
  • 8 Dip one cotton swab in rubbing alcohol. Gently rub around the edge of the lens with the swab. Look for any greasy residue that may be there and remove it. Remove any fuzz. Use gentle pressure so you do not damage the PlayStation's lens.
  • 9 Take a dry cotton swab and dry off any liquid left behind. Ensure there are no cotton fibers left behind on the lens.
  • 10 Reassemble the PlayStation 2. Work backwards from the way in which you disassembled it.
  • Posted on Sep 04, 2010
    Cerfer39
    • 709 Answers
    SOURCE: Disc won't spin. Disc doesn't show up in browser
    You got a problem with the lasers data getting back to the Motherboard.
    One of these could be your problem
    1. Laser lens is melted. Look at the lens with a magnifying glass to see if it or its supporting frame is melted. REplace the laser in this case.
    2. The ribbon Cable going from the Laser to the motherboard is damaged or loose.
    3. Your laser is burned out. Press the two interlock to override the door being open, to see if the laser even lights up. 2 switches, one at rear left corner, one behind the On/reset switch.
    4. Your Laser is dirty and needs cleaning look at it with a magnifying Glass to make sure you got it clean. Use Q-tip and window glass cleaner, not alcohol.
    Posted on Nov 25, 2007
    Tech Jenkins
    • 359 Answers
    SOURCE: Disc Read Error ( slim PS2)
    Ah yes the dreaded DRE... time to replace your ps2 dude, this is the easiest and least headache solution.
    Logged too many hours on those poor machines ;)
    Posted on Aug 21, 2008
    • 586 Answers
    SOURCE: ps2
    In both of your Consoles the problem is in lens, It needs to be replaced.
    THanks
    Posted on Oct 09, 2008
    FixMyConsole
    • 174 Answers
    SOURCE: PS2 slim- Disc not spinning
    definately the laser has died.
    Give us a shout if you need any help.
    FixMyConsole
    Posted on May 24, 2009
    Jmizpah777
    • 290 Answers
    SOURCE: God of War 1 and 2(Unable to read disc)!
    Check your cd if it can play in different ps2 consoles. if it can, then theres nothing wrong with the cd.
    probably your game console has problems on disk reading.
    FIX Those Ps2 disk errors.
    You're going to be surprised when you find out how easy this is. Read the instructions all the way through before you attempt the repair just so you'll be familiar with the entire process. First take off the outer cover of you PS2. If you haven't done this before, you will have to remove all the screw covers from the bottom of the unit, both plastic and rubber, these will be the only screws you will have to remove in order to take off the outer cover.
    To remove the outer cover, lift up from the rear of the unit and pull towards the front in order to clear the controller jacks and the eject/close buttons. As you remove the outer cover you will notice a small metallic ribbon cable inside the machine leading to the eject/close and reset buttons on the front of the unit, this cable is usually taped to the top of the disc tray. This cable is not a sensitive as it appears; just remove the tape holding the ribbon cable. Once the outer cover is off you need to remove the cover to the disc tray, this will require a rather small phillips screwdriver (I've seen a few that use a standard slotted screw). Now that the tray cover is off, the first thing to do is to clean the laser eye. All you will need is a Q-Tip dipped in alcohol. Just swab the eye a few times and allow it to dry on its own, making sure that no lint was left behind from the Q-Tip.
    After the cover is off of the disk tray and the laser has been cleaned you will need to plug the unit back in, (The unit needs to be hooked up to a TV as well to test it while you have it open. You should have a DVD, a game disk with a silver or gold back and one with a purple back in order to fine tune the system to play all three.) It will be necessary to have the unit powered up to perform the repair. Press the eject button so that the tray slides forward exposing the undercarriage. At the back of the unit you should see a small white, geared wheel about the size of a quarter. This little bastard is the cause of all your problems.
    This wheel changes the angle in which the disk is held. You will notice that there is a small metal tab that holds the wheel in place. Take a felt-tip marker and mark the point on the wheel that meets the tab. That way you will always know the original position that the wheel was in. Now that the orig. position has been marked, feel free to spin the wheel for a few full rotations in order to see how it changes the angle. It will only alter the angle a few degrees before it goes back to zero, after it reaches the maximum angle it will go back to flat after each full rotation. Once you've toyed with it to see how it works, put the wheel back to the original position that you have marked. Then advance the wheel about 1/8 of a turn and place the disk tray cover back on top of the disk tray. (You will not need to screw the tray cover back down in order to test the machine; you will only need to hold down the cover with your fingers while trying to load/test a disk) Now place a DVD in the tray and press the eject/close button in order to close the tray and load the DVD (hold down the cover as explained above). Wait to see if the DVD loads, you may have to use the browser in order to load each disk you test. If the DVD loads, eject it and load a silver backed disk, if that loads try a purple backed disk. If all three loaded successfully, congratulations you're finished. If not, remove the tray cover, eject the disk and advance the wheel another 1/8 turn and repeat the process. It just a matter of finding an angle that will facilitate the operation of all three types of disks. Once you've found the proper angle and the system is operating to its full potential, close it up and let'er rip. I also do not recommend placing the PS2 on its side once you have fixed it. Although Sony says they recommend it in the owner manual, I have since seen internal Sony documents retracting the statement and attributing many malfunctions to storing and operating the unit on its side. Keep it flat at all times.
    well. i hope this works.
    pm me if problems continue.
    Posted on Aug 08, 2009
    My ps2 slim wont read god of war II disc but it reads all my other games just fine so please i need a solution
    God of War II being one of the few Dual-Layer discs on the PS2, it is possible that your problem originates from your PS2 lens being unable to read it correctly. The PS2 Slim is supposed to be able to read Dual-Layer, thus you should try cleaning your lens, it may be dirty, leading to this kind of error while still able to read Single-Layer discs.
    -Organicbeing
    May 14, 2011 | Sony PlayStation 2 (PS2) Console
    On my ps2 after reading its disc, message will appear "disc read error"
    Hello, you are most probably using a PS2 Slim, they have a very sensitive Lens Radiance. If the CD is a little scratched, a CD lens cleaner could help. Or if it is not a PS2 Slim, it must just require a CD lens Cleaner :)
    Jan 29, 2010 | Sony PlayStation 2 (PS2) Console
    FixMyConsole
    May 13, 2009 | Sony PlayStation 2 (PS2) Console
    Ps2 slim not reading discs
    You can buy new DVD pickups online for about 15-20 It will take a very small phillips screwdriver and needlenose pliers to change out the old one
    Mar 22, 2009 | Sony PlayStation 2 Slimline Console
    Please insert ps2 format disc?
    Try inserting the disc in your computer. If it reads its fine. Then look if the Slus...... is compatible.maybe thats why it doesn't play. your ps2 must have an old bios system even if slim.
    Mar 05, 2009 | Sony PlayStation 2 (PS2) Console
    Guitar Hero World Tour PS2
    If you have old ps2(fat one) or some of the older slim models they are unable to read the new dual layer discs like GHWT. You can send your ps2 back to sony to reformat it to be able to read these new discs for about $50. There is currently a class action lawsuit against sony and activision for not being upfront about this problem.
    Dec 28, 2008 | Sony PlayStation 2 (PS2) Console
    Ps2 slim problems reading disc
    After countless hours of tying to figure this out I went to the basics. This ps2 slim has 3 sensors and after all sensors are the key to making the machine work properly. After testing everything known to man I decided to go around the sensors by taping them all down. Low and behold when I cranked the ps2 slim up the disc now reads and plays perfectly.
    Aug 27, 2008 | Sony PlayStation 2 Slimline Console
    Aug 18, 2008 | Sony PlayStation 2 (PS2) Console
    Read Error (With FFX game)
    Hi Raven, Its sounds like you have a PS2 Slim with a melted Laser. What you will find is that the Slim will only read CD's, CDR's, PS1 Games, Blue back PS2 games and DVD's. I can repair this for $35 plus shipping to and from The Playstation Clinic in Fountain Inn, SC. The webpage is www.playstationclinic.com If you do not have a Slim, you either have dirty disc, or Lens. You may have left some fibers from the Q-tip across or around the lens.
    Sep 10, 2007 | Sony PlayStation 2 (PS2) Console
    Sony PlayStation 2 Slimline Console Logo
    178 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
