Question about Miller SPECTRUM 125C PLASMA CUTTER w/compressor 907149
My 125c arc stops after 2 seconds w/o even coming in contact w metal.
My microwave when turned on starts arcing lights flicker on and off and goes off after about two or three seconds no matter what mode I pick to try to use it
Try contact trusted serv techn for this
Let them assessed the damage. If they quoted u high or costly u judged if u want to retain that unit or buy new
Sep 20, 2014 | Microwave Ovens
SONY MODEL KV-29CL10E WHILE WATCING A :TSAF: HEARD FROM INSIDE AND ON-OFF BATON FLICKERS 2 TIME AND STOPS FOR SECONDS AND THE.FLICKERS AGIAN 2 TIME AND STOP AND CONTINUES TO FLICKER 2 TIME AND STOPS FOR...
mostly it come from the arcing of it`s fly back...if you are a experienced technician or i mean technician,please clean first with kerosine the flyback.let the hv wire out of the flyback away from tube and parts,it has wire holder.arranged it well.clean with rug that having kerosine all the sorrounding of fly back and to the final cathode...
Jan 30, 2014 | Televison & Video
I bought a microsoft arc mouse, wireless, with a USB transmitter, just a month ago and it was working perfectly, then suddenly and i mean SUDDENLY, stopped working, no reason it just happened, the light...
Hello, have you tried changing the batteries in your mouse? They are probably dead or dying and that is why it is not working. Also, try restarting the computer. If you cannot even use a regular wired usb mouse, there may be something going on. Try changing the batteries, restarting the computer, and using a regular usb and a regular PS/2 mouse.
Thanks for using FixYa!
Jul 24, 2011 | Microsoft ARC Mouse
My tig welder wont arc unless I touch the metal with it
my guess would be the type of welding machine you have.usually there is extra switch which says start control also continious cycle , sometimes smaller machines dont have these switches to allow a wider variety of tweeking the welder ,also its ok if you have to touch the base metal cause thats what starts the contact with the work peice ,keep a arc after touching about 1/4 inch away from work peice ,also a good steady hand rest will make a good welder in any situation this should allow the arc to remaim stable with a comntinious weld arc puddle. happy welding
May 22, 2010 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
My little 110 mig welder is arcing without trigger pulled
i believe that the trigger only send out the wire and does not control the arc the tip should be live as long as the welder is on
Feb 28, 2010 | Lincoln Welding Tools
Thermal dynamics cutmaster 50 2004 yr.
Check contacts in tip and be sure it is all lubed correctly. If you have good air pressure and flow it should arc after pulling the trigger for about 2-3 seconds.
Sep 27, 2008 | Welding Tools
Husqvarna string trimmers 125c
Check for a spark. If none, then the coil is bad. Replace it. That should solve your problem.
Sep 10, 2008 | Husqvarna Forest & Garden 125c 17"...
Microwave Arcing
The metal shelf that comes with most microwave ovens must NEVER come in contact with any surface of the cavity wall or arcing will occur. (this is why its is mounted on plastic clips). IF you are not using the shelf to cook multiple items (as most people don't)....Remove the shelf and store somewhere else until needed.
Jun 06, 2008 | KitchenAid KHMS155LSS 1000 Watts Microwave...
GE Profile - One of the igniters continually clicks...
Hi Mike,
The Dial/Swiitch Has A Fault, Or The Igniter Electrode is Touching, or too Close To The Contact Area.
Try Turning the faulty switch, left or right Gently.
Could be grease/dust arcing the Contact.
Broken Or uninsulated Wire Under The Ignitor, arcing against metal surface.
Mike @ Compurepair.
Feb 28, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
Miller SPECTRUM 125C PLASMA CUTTER w/compressor 907149 Logo
78 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Jose Velazquez
Jose Velazquez
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
