Must press power button several times to power on,butwhen turned off again must press button several times to turn on again.
Not helpful. TVs are no more complicated than PCs. There should be simple self help remedies provided, rather than pay $200 for an alcohol wipe, or some such!
Posted on Jul 07, 2008
    President:
  • 2,712 Answers
Could be a loose power button or problem with relay/circuitry. Recommend you get a professional to take a look.
Also try a hard reset:
Unplug from mains, remove all cabling from TV. Wait 10 mins. After 10-15mins, hold down the power button and replug TV to mains. Now redo all cabling and try powering on the TV.
Should it still not work, you'll have to call in a pro..
Posted on May 12, 2008
Pc-8500 how to calibrate touch screen
ADJUSTMENT
1. Turn on the power switch while holding down the start/stop button, backtack button, and
NP button simultaneously.
2. While holding down the start button, press the + positions 1, 2, 3, 4 and 5 on the screen in
order. If the buzzer sounds once when 5 is pressed, the position is okay. If the buzzer
sounds several times, the position is erroneous; therefore, adjust again. (When pressing
the screen, use a pencil (or match) with a round tip.)
3. Turn on the power again, and confirm that the screen display and touch panel positions
match.
Nov 18, 2014 | Brother PC-8500 Pacesetter Embroidery &...
Starts inconsistently. When pressed the start button flames and the the power button needs to be turned off. It often takes several tries to get it started.
Richard, it could be a unresponsive control to reboot the unit unplug power cord from wall a couple of min's and plug back in. I would ask if you are gently holding start button in until you here a click then release the button. as the start button is depressed it is a time process to enable to processor to think... let us know.
Apr 19, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Printer error 5200
I have had this error several times, I always figure it out, but then when it happens again I forget what I did! So, just happened again tonight after my 4 year old went on a toy copying binge, and this time I bookmarked the fix! 1. Turn off the printer . 2. Press the Stop button for 2 second and hold it. 3. Press the On button, hold it and release the Stop button. 4. Press Stop button 5 times then release together, with the On button. 5. LCD display will blank and now reseting. 6. Computer will detect new hardware just ignore it. 7. Turn off the printer then turn it On. I also removed my cartridges and cleaned the heads after powering it back on. Hope this helps you!
Nov 05, 2013 | Canon PIXMA MX340 Wireless Office...
My asus laptop's power button need to press several times to start...plz help
Mabie power buton is broken or else.... but i need to know what is your asus pc model...
Jul 09, 2012 | ASUS Computers & Internet
Error 5200 of canon pixma mx328. i already tried turning it on and off several times and even got the cartridges and returned them back but still when i tried to print a page error 5200 still...
Error no 5200 is caused by its temperature high.. to solve your problem follow the instruction given below::
1. Turn Off printer, cable power still plug in.
2. Press Stop/Reset button, don't release the button.
3. Press Power button by holding without release and than release Stop/Reset Button.
4. Press Stop/Reset button two times (2x) now release the Power Button.
5. Wait until service mode to zero (0).
6. Turn off the Printer, cable power still plug in.
7. Press Stop/Reset button, don't release it.
8. Press Power button don't release & than release Stop/Release button.
9. Press Stop/Reset button four times (4x), wait until service mode to "1"
10. Turn off printer, and loose cable power, wait for one (1) minute.
11. Connect cable power, turn on printer again, now this printer ready to use.
Aug 23, 2011 | Canon MX300 Office All-In-One Printer
Ink absorber full, ip2600
I have a ip2600 that has had the waste ink absorber msg come up twice. After trying several recommended fixes involving pressing the Resume key twice then 4 times, etc., I've found the perfect solution. Start by cleaning the waste pads with tweezers, etc.
1. Press Power Off
2. Disconnect Power Cord
3. At SAME TIME, Press & HOLD Power Key while re-connecting Power cord
4. Release the Power button
5. Press the power button again
This will work!
Nov 18, 2010 | Canon Pixma iP2600 Photo InkJet Printer
What is a service error 5100?
This is a fatal error, and I don't know the exact cause since this is related to several issues, like carriage problem, waste ink tank full, or sometimes paper jam, but the most common solution is as follows:
First, turn off printer
Hold down "Resume" button and press "Power" button to power on the printer.
Now hold down the "Power" button and release the "Resume" button.
Again, press "Resume" button twice then release both the buttons
You'll see green lights flashing and then it'll stop blinking and will remain static.
At the time when green lights remain solid, press the "Resume" button (four) 4 times.
Again, press the "Power" button and the printer should turn off, if it's still On, once again press the "Power" button.
Let me know if it's not helpful, i'll assist you further.
Good luck.
Thanks for using FixYa.
Sep 11, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Black ink ran out and printed one photocopy without producing any black. Change the cartridge several times BUT still does samme thing - no printing in black. Colour is fine, just no black despite changing...
Canon IP 2000 / reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
All the best Pineworks
Feb 09, 2010 | Canon PIXMA iP2000 InkJet Printer
Compaq F572US won't start (led turns on, but nothing happens)
I have been having the same problem. At first I thought that the motherboard was fried and the laptop was a paper weight, but I kept it plugged in and kept pressing the power button several times over the days. It would always seem to start (screen remained off/black) and then it would just go off again in seconds. But persevarence has paid off, finally almost after a week it started up like normal and started working again as normal. I then had the same episode repeat a few weeks later, the computer was useless for a few days and again started up as I kept pressing the power button several times a day.
I believe the problem is with the standby mode. Each time the problem happened, it seems like the computer was going into standby mode and the power button was pressed again before it could competely go into standby or the button was pressed again while it was coming out of standby.
To sum it up, nothing is wrong with the cimputer components, there is some problem with the standby routine. Keep pressing the power button and hopefully you can get lucky in getting the computer to start again. Long term, I am thinking about checking whether there was a new flash update that came out that could fix this problem. I purchased the laptop compaq F72US in 2008 and never updated anything. Also worth noting that I called HP and they didn't stand behind their product.
Sep 28, 2009 | Compaq Presario F572US Notebook PC
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
