Question about Philips SpeechMike Pro Plus 5276 Handheld Transcriber / Recorder
Can't get the record button to activate - Philips SpeechMike Pro Plus 5276 Handheld Transcriber / Recorder
    Genius:
  • 1,218 Answers
Unless you can open up the unit to clean the contact for the record button it will have to be replaced.
Posted on Sep 05, 2010
ViP211-HD DVR button won't work.....can't record any channels.....also the 'record' button doesn't respond either......
Hello, my name is Matthew Gonzales with DISH Network. I'm sorry about any inconvenience, but the ViP211 is not a DVR receiver. If you have an external hard drive, you can activate the feature on the 211 to allow you to record movies to the external hard drive. It is a one time $40 to activate the external hard drive feature. Also, we can always look at getting a DVR receiver installed to replace the 211. If you have any other questions, feel free to email me at matthew.gonzales@dishnetwork.com.
Dec 02, 2010 | DISH Network ViP 211 DTV Receiver
How do you send an a single record/invoice as an attachment to an email? Many Thanks Nick
Select only the one record that you want to send and make it active. Make sure all the other records are in the background and not active. In the print window, select your email as the printer or click the PDF button and select Mail PDF.
Oct 21, 2009 | FileMaker Pro 7 for Mac, PC
How to turn on Olympus Pearlcorder ''voice activation'' feature?
On my model the Olympus Pearlcorder S909 there is a slide button on the end marked VCVA (variable control voice actuator). Switch it to that position then press record and away you go, voice activated recording!
Hope this helps.
Aug 27, 2009 | Audio Players & Recorders
How do I turn the recorder off or is it automatic?
Your Digital Voice Recorder has no on/off button or switch.
Just make sure you press the Stop button after you finished using it, to stop any activity.
You can download brochures/manuals for your
DS-330 Digital Voice Recorder from here: http://www.olympusamerica.com/CPG_SECTION/cpg_archived_product_details.asp?id=859&fl=8
Jul 29, 2009 | Olympus DS-330 Digital Voice Recorder
Telephone recording won't work
You need to have a telephone record adapter plugged into the back of the 3750. Then you press and hold the Tel Rec button until it begins recording.
Also check to see if the 'Vox' or 'VA' switch is on (voice activation). This will cause the machine to pause if the volume is too low.
Jan 15, 2009 | Dictaphone 3750 Desktop Cassette...
Cannot operate svr-925 digital recorder, need manual
How to Record:
1. Make sure HOLD switch (on side of unit with pocket clip) is set to off position (slide to right is off - to left would be hold)
2. For best results set unit with mic(rophone) which is on top of unit toward sound source and press REC/STOP button (Top button on front of unit just below LCD display). Recording will begin and will be indicated on LCD display.
> Red Record LED will be on and the message number, recording time will be displayed on the LCD.
3. To stop recording, press REC/STOP button one time.
* If no other buttons are pressed within 1 minute at stop position, it will power off automatically.
4. Pause during recording by simply pressing MODE/PAUSE button- press button again to resume.
There is a Voice Operated System (VOS) Recording button on left side also. You can record with voice activation to conserve recording space but I have found that you lose a portion of the recorded sound as it activates and if there is no sound for a very few minutes the unit powers off and you will get nothing further recorded. I recomend just keeping VOS in off position.
5. To erase a recording: Select the message number you want to erase and while it is stopped (the message number will appear in LCD with the length of recording showing also)
Press and hold the ERASE button until the LCD begins blinking "ERASE" then, while it's blinking simply press the erase button again and the recording will be erased.
6. To play back a recorded message find your message by "toggling" the switch on the right side of the unit that says INDEX. That switch is the fast forward/reverse play etc. To Play simply push the switch in. This button/switch takes a little practice to use but the Play portion is straight forward. Use the front buttons to pause and stop during playback.
Hope this helps.
Jan 04, 2009 | Sims SVR-S825 Handheld Digital Voice...
Panasonic Portable Cassette Recorder/Auto Stop
try toggling the Hold button on the back. My question is whether activating the Hold button is the only to turn this puppy off.
Rojelio
Jan 12, 2008 | Panasonic RR-US050 Digital Voice Recorder
Record btton cannot be pressed to record
on the side opposite the tape in each corner is a plastic tab. breaking out this tab disables the record function - it is called the "record lock" use a cassette with the tabs in place.
Dec 31, 2007 | Audio Players & Recorders
Axim Record Button Does Not Work
Try taking off the left black rubber stripping and see if the button underneath is lined up correctly. Perhaps take a look inside to see that all the contacts are good.
This site will help with how to take off rubber part and open the Axim: http://www.gethightech.com/Merchant2/merchant.mv?Screen=CTGY&Store_Code=GHT&Category_Code=_axim_takeapart
Sep 14, 2005 | Dell Axim X5 Pocket PC
Philips SpeechMike Pro Plus 5276 Handheld Transcriber / Recorder Logo
151 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
