Question about Uniflame Grilling
I can't seem to get my three burner grill to get hotter than 250 degrees.I have a new bottle of gas, and I don't know what could be the problem.
  • 43,501 Answers
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on Sep 05, 2010
GAS FLOW TO THE B/B/Q BURNERS
Three possibilities come to mind. First, is the propane tank full? Second, is the valve on the tank open all the way? Last, is there any obstruction in the lines such as spider webs. Spider webs can even make a furnace not run. This could easily cause low flow issues.
Jun 22, 2016 | Grilling
On a kenmore 5 burner grill when lighting the fourth burner all of the grill shuts down, regardless of which is the fourth burner?
Sounds like the pressure regulator is malfunctioning. Try disconnecting your gas line. Open/Close all burners then reconnecting gas. If propane, don't turn bottle off before burners. Always turn burners off first, then bottle. then bottle on before burners. This primes the regulator to the proper pressure.
Jan 09, 2012 | Kenmore Grilling
The regulator has a hissing leak when tank is attached to grill Grill is Master Forge 2-burner gas grill, Model # MFA350CNP The leak was noticed because the grill would not heat to beyond 250 degrees....
You will need the replace the grill's Hose/Regulator Assembly. You can pick one up at any hardware store or home center that sells grills and accessories for about $30.00. Take your old one with you for comparison purposes.
After you install the new one, be sure to check it for leaks, as described in the grill's Owner's Manual. Also, and this is very important. When opening the gas tank valve, open it Very, Very Slowly (slow motion, slow). If you don't, the regulator will lock up and no gas will flow to the burners.
Hope this helped you and thanks for choosing FixYa. Happy Grilling!!
Sep 07, 2011 | Grilling
With all three burners on high, the grill only goes to about 300 degrees F. All the burners are burning.
Has it ever burned hotter? I assume this is propane? If so the new safety valves I find are very finicky. Try turning off the gas. disconect hose from tank. Reconnect, turn back on gas and see if it is better. I
I had one that would not give full flame and sometimes I had to do this 3 or 4 times before it would give a full flame.
Good luck
Feb 17, 2011 | Weber Grilling
I thoroughly cleaned my Weber Genesis Silver A and have a full tank of gas. It won't get hotter than 250-300 degrees. Flames are blue.
You might have air block. When turning off the grill, leave one burner on and shut the tank valve.
When grill cools, close the remaining valve. When restarting the grill, open the tank valve, then the start burner, then the igniter. When first burner is going, open remaining two valves to preheat the grill.
This has worked on two different grills.
Dec 30, 2010 | Weber Genesis Silver A Grill
Grill won't heat up above 200 DEGREES with a nearly full tank
Try replacing the regulator and hose, not very expensive and fairly easy to do. If that doesn't help, let me know.
Jul 11, 2010 | Weber Genesis Silver B Grill
Grill does not get hotter than 340 degrees
could be a bad regulator and or check for spider nests in the burner tube
Jun 20, 2010 | Weber Genesis Silver B Grill
My Weber gas grill is less than a year old. The
gas regulator make sure all burners are off when you connect bottle... the units have a leak sensor and will stop the gas coming out because it thinks you have a leak when you connected the bottle. now try hooking up the bottle again with all the burners closed incl. the side burner and the infa red. It will work o.k. then
Apr 07, 2010 | Weber 3820301 Gas Grill
How do I adjust the flame to burn hotter or more.
There are adjustment screw at the end of the burner tubes that allow more or less air to enter the burners. try opening or closing these screws
Jun 01, 2009 | Jenn-Air JLG7130A
Grilling Logo
168 people viewed this question
Top Uniflame Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
limabeenie
Level 1 Expert
Are you an Uniflame Grilling Expert? Answer questions, earn points and help others
