Question about GE 18.0 Cu. Ft. Frost-Free Top-Mount Refrigerator - Bisque-on-Bisque
Water pooling under drawers in main compartment
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 05, 2010
Why is water pooling in bottom of fridge under veggie drawer.? Also freezing ice cubes in back part of cube drawer
Just above the veg drawers at the back is a channel that collects water when the fridge defrosts. It has a hole to drain the water which is blocked and the water is pooling under the drawers. Clear the hole with a drinking straw.
May 15, 2012 | GE Refrigerators
My washing machine won't use soap from the drawer
are you useing the right draw for main wash try putting on a wash and open the draw there should not be any water leaking if you do this and look in the compartment that you put the powder in and see if the water is going into the compartment that you use and see which compartment is filling thats the one to put the powder in
Nov 14, 2011 | Washing Machines
Water does not drain and freezes under freezer draw
I am sending a couple links for the LG manuals but that sounds to me that water is either overflowing into freezer compartment from the fresh food compartment or when the freezer goes into defrost the drain that carries the water out to a condensate pan below refrigerator (Location #105A) has either ice or sludge caught in the drain. Here is the=> LRFD22850 Exploded View then scroll to page 44 where you will see the location number 319A That will be the condensate/drip collection tray where the water from defrost should be going. If the drain location # 105A is the drain assembly, pipe Z coming from under your freezer drawers. Where you say you see the water pooling and freezing. And the Service manual Click Here=> LRFD22850 Service Manual I will try to make this simple but I must try to explain with photos and notes with other links=> Leaking Refrigerators Just What May Be Happening and here=> Leaking Refrigerators! This may take some detective work because as you see any place there is water there may be water flowing down to the area below freezer drawers so look for any water that may be coming even from the water filter area inside fresh food compartment.Even a slight lean will cause the water to pool up and freeze there and close the drain slowly. If you should need parts scroll to page 51 in your Service Manual and on left is the photo location and on right is the part number under the model LRFD22850 then enter the part numbers into search feature here=>
Repair Clinic or Sears Parts Direct Here is the new=> Adobe Reader X
I also will be here to answer any questions you may have, Thanks, Sea Breeze
Jun 05, 2011 | LG LRFD22850 Bottom Freezer Refrigerator...
Water pooling inside of refrigorator
sounds like the drain line for the defrost cycle is plugged. the water is supposedto end up in a pan under the refrig. the drain probably needs to be defrosted and cleaned.located behind the back panel in the freezer compartment
Jan 21, 2010 | Frigidaire Refrigerators
Fabric softener drawer filling with water
lift out the blue part of the conditioner compartment and you'll see attached a tube at the end.
clean this out completely.
also check the tube in the compartment is clear.
poke a cotton bud down it to clear it.
if you want to check to see if its worked take the drawer out(blue button at back of drawer) put the blue grid back in the dispenser and fill the compartment up under the tap ,hold the drawer level.
as it gets full you should see water start to flow out the back ,turn the tap off and if its worked the compartment will slowly empty.
these were a big problem for hotpoint and concentrated conditioners will block it regularly.
Jan 17, 2010 | Samsung Washing Machines
Water in softner compartment
Take out the drawer and clean the compartment and pipe at the end of the drawer with hot soapy water - washing up liquid works well. Clean all around it. Use a pipe cleaner, cotton buds or piece of coiled curtain wire to ensure that the U shaped pipe is clear of obstruction. Pull it back and forward to dislodge any accumulated fabric conditioner. To show this is working OK, put it in the sink and fill up the compartment with water until it is overflowing then stop. The water should drain out of the compartment on its own.
Next, where the drawer fits in the machine clean the water exit above the drawer with a washing up brush. This can appear brown or white depending on your water type. If this is OK then try running the machine. If there is still a problem, remove the drawer again and turn off the power at the mains. Use something like a paper clip to poke all the holes in the water dispenser area above the drawer. There are lots of them so some patience might be required. If you live in a hard water area it could be blocked with limescale in which case an application of a descaling mousse or spray will assist. Once complete, make sure you rinse the drawer area, drawer and put the drawer back in and run the machine on a short cold fill wash cycle. Put some fab con in the drawer to test that the machine drains it correctly. A good idea is to slightly water down fab con concentrate as it will eventually clog up the dispenser. If all is well then there will be no fab con left. If it is still there then you will need to get into the water dispensing area to see what is wrong. Occasionally the mechanism can get jammed, lose a spring or just get broken, in which case it will need replacing.
Nov 13, 2009 | Kenmore HE2 Plus Front Load Washer
Water is forming on the floor. Appears the water is pooling under the crisper drawer, then seeps through the seal. GE TBX 18CI. Any ideas?
You should not have any water at all forming inside the frig compartment unless you have a water dispenser on the frig. The water resevoir is located in the frig compartment at the bottom behind crisper. There may be a small leak or loose water connection on it. Hope this helps.
Jul 24, 2009 | Refrigerators
Leaking water
the water reservoir tank could be your problem, take out the drawers and operate the dispenser and see if water is leaking from it. if so replacement of the tank is very easy
May 21, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Whirlpool has water drip inside fridge
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Oct 25, 2008 | Refrigerators
GE 18.0 Cu. Ft. Frost-Free Top-Mount Refrigerator - Bisque-on-Bisque Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
