Question about Boss Audio CAP10 10 Farad Digital Capacitor w/Blue Illumination
Theres no power going to my amp after I installed my capacitor. Anyone kno why?
There is power going through my technics 1210,but the platter & strobe light still will not work
how do you know theres power to the unit if theirs no strobe light pitch adjuster light & the platter doesn't spin?
the power comes in & to the transformer first,then through the strobe switch, the transformer is what blows when you short the target light out.....i've seen this many a time when people try & change the target lights to blue neon.
Mar 04, 2013 | Technics SL-1210 Turntable
Not turnin on but got sound
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 06, 2012 | Zenith R57W46 57" Rear Projection...
I have a power acoustik ibm12000d amp had it installed to weeks ago wired at one ohm to a 15inch acoustik p3 sub worked good for to weeks hit good and everything but now its cutting off when turned up I...
Sounds like an over current condition. Your sub may be the problem. Does it go into protect mode when it cuts out? remove the sub and turn up the volume and see if it cuts out when you keep increasing the volume. If not, then it may be that the sub shorts out when turned up too much, kicking the amp into protect mode. If it still cuts out, then it may be the amp. Try another sub if you have one or borrow one from a friend.
Aug 06, 2011 | Power Acoustik OVN1-2000D 1-Channel Car...
Hello! in my monitor of intex 17 inches have problem in setting in pincushion,trapezoidparallelogram,pinbalanceand corner can anyone explain or give me solution for that
Try to adjust the menu setting.Theres a pincushion setting, if did not work theres a problem in the board.Maybe theres a deffective capacitor or leak mylar capacitor.
Jul 30, 2011 | Computers & Internet
Manual for mcx-8 reactive controller
Controller and Analyser
Share: zero.gifzero.gif zero.gifzero.gifzero.gif Reactive power controllers MCE and MCX are designed to measure the reactive power of an installation and to give the necessary instructions for connecting & disconnecting capacitors in order to maintain the desired cos ö.
All the controllers are commanded by a microprocessor that ensures an uniform ageing of contractors and capacitors by using a circular connection sequence that takes into account the time that each capacitor has been switched on.
Power factor value to be reached can be adjusted in a continuous way, between 0.85 inductive and 0.95 capacitive.
Standard working programs for controllers are 1:1:1:1, 1:2:2:2, 1:2:4:4, 1:2:4:8 and 1:1:2:2.
*Item Code: MCEzero.gif
Description:
Power factor controllers MCE measures the cos ö of a supply system and control the automatic connection and disconnection of compensation capacitors according to the desired cos ö. They are available in 6 or 12 steps. To see the technical specification and for these steps please go to the attached Pdf file.
*The MCE-12F plus (12 steps) power factor controller measures cos ö in the system and regulates the automatic connection and disconnection of the capacitors depending on the required cos ö. MCE-12F plus is specially designed to control equipments with static switches based on thyristors, which operate through a zero step controller. *
These reactive power controller are designed to measure the reactive power of an installation by giving the necessary instructions for connection and disconnection of capacitors in order to maintain the desired cos ö. Controllers are show in a 3-digit display of the set-up or actual values. They show the cos ö, that the total current & the harmonic distortion.
All controllers are commanded by a microprocessor that ensures an uniform ageing of contactors and capacitors by using a circular connection sequence which takes into account the time that each capacitor has been switched on (FIFO system).
Controllers can include a fully operational alarm relay that acts when the automatic capacitor bank cannot reach the required cos ö in case of high harmonic distortion level, over-current and over voltages. LED indicators show permanently capacitors steps that are connected. To see these steps please open the Pdf file.
May 02, 2011 | Computers & Internet
Installation or a 2 farat for 3 amps
Connect the positive lead close to the amp on the positive lead running to the amp.The ground lead should be grounded to the car chasis.
Jan 29, 2010 | Legacy Lca280sl 2.8 Farad Digital Power...
I didnt get a disc with my LG viewty and now dont kno how to put music or anythin on my fne as i cnt connect to my pc
Go to http://update.lgmobile.com & download the MANUAL & Software Section. This will download & install LG PC Suite. You can transfer music & Movies from that.
Aug 04, 2009 | LG KU990 Viewty
Turned xbox 360 on then it goes off right away
You are getting the rrod because of a 'fault' with the motherboard. the color of the power supply shows if something is 'active' (green) on it or on 'stand by' (yellow). What 'fixing' were you doing?
Jul 26, 2009 | Microsoft Xbox 360 Console
Problem with fuses frying going into amp?
remove main battery fuse, and install new fuse into amplifier. then use a capacitor to slowly charge the amplifier. Some advanced installers use lights that go out when all capacitors are fully charged to avoid instant charge & Discharge of internal capacitors. you may have already damaged amplifier. Also check for loose wire strands making contact with amp chassis or other port in terminal strip.
Dec 21, 2008 | Car Audio & Video
Boss Audio CAP10 10 Farad Digital Capacitor w/Blue Illumination Logo
26 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
