Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint WF640
Hi, could you please help our washing machine is coming up with a F-01 error message, is there a reset button to try and get rid of the message, The problem arose when my wife did a was and left the outlet hose hanging and not in the wall so the water flooded our kitchen floor, thn this error message appered, thanks in advance!
  • Buckster123 May 12, 2008
    Is there no way to reset it, maybe a red button hidden near the motor?
  • Buckster123 May 14, 2008
    Thanks for you very quick reply!!!
  • 84 Answers
The f-01 error code on your hotpoint all in 1 washer/dryer is a short circuit code for the motor. the only way to clear the code is to have a service tech come and inspect the reason for the error.
Posted on May 12, 2008
  • SCOTT NELSON
    SCOTT NELSON May 13, 2008
    All the tech sheets i've seen for this item dosn't list a rest button anywhere on the motor. or in the wiring scramatic. sorry
SOURCE:
Error code on washing machine wf640
have you checked you have turned on the water back on???? check but red and blue, or just blue it must be 90degree left or right.
Mar 08, 2010 | Hotpoint Ultima WF860 Front Load Washer
Test light
Press and hold "on/off" and "start" buttons together for five seconds.
Apr 25, 2009 | Hotpoint Aquarius WD640 Front Load...
Error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Dec 15, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint wf640 washer says 'test' on digital display. what does this mean?
hold down start button untill unit comes out of test. Then hold start and on/off button untill it gives you test end message.
Jun 29, 2008 | Hotpoint Washing Machines
Wf640 test
This has happend to me today! this is the fix
  1. Press and hold the Start/Cancel button until message clears
  2. Now press both Start/Cancel and On/Off buttons together until you get a dOFF message
  3. now your machine should work OK
Mar 17, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WF640
check your water supply to the machine is of adequate pressure . this is the sign when the machine is not getting enough water
Dec 16, 2007 | Hotpoint Aquarius WD640 Front Load...
Error message
Hotpoint’s are designed to go into test mode when the start button and the on/off button are pressed at the same time. If you are stuck in Test mode, simply hold the start button down until it comes out of test mode, then hold both the start buttons and the on/off button down until you see ‘D:end’ (or similar message)."
Nov 03, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
457 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
