Question about Samsung SCX 4521F All-In-One Laser Printer
Open heat prob - Samsung SCX 4521F All-In-One Laser Printer
  • paeezan Jun 03, 2008
    WHILE I WAS WORKING, I CAME ACROSS THIS PROBLEM..ACTUALLY I WAS PRINTING ALOT OF PAPERS TOGETHER
  • sachin gaiki Jun 28, 2008
    Open heat error is come when the fuser is faulry
    chepue lamp ,chepue heating diavod
  • 161 Answers
Bad fuser unit. Samsung part number JC96-03414A. Requires removal of body case to replace.
Be blessed.
Posted on May 28, 2008
Prob error final rinse
Probe Error FnlRns - (Ensure that the supply water valve to the final rinse booster is open.)
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/F44126.pdf
Apr 27, 2015 | Hobart CLPS66E-16 L/R 15KW Tank Heat...
Nutone 9091 - coils heat up and light works but no heat dispersed.
Open the back, check each little part that has wires going to them for continuity. Theres prob about 6 or 7 of these little fuses and parts. When you find the one that has no continuity, replace it with a new one and you will have heat again.
Jan 24, 2015 | Dryers
Oven temp fluctuates
It is normal for the thermal device to turn on and off. Obtaining a steady temp is not always possible. When setting a temperature on some ovens, they have what is called a tolerance point. That means a set temperature has a range of a few degrees up or down. At the Down point, the oven is triggered to energize the coils and bring the interior of the oven back to the settings desired. The other factor is opening the oven and allowing cool air to enter, or in some cases a leaking door seal allows air to enter and heat to escape.
Feb 26, 2014 | Kenmore 30" Slide-In Electric Range...
How to manually open the dampers
I have a 91 deville that never had a working heater. I fixed the prob by unhooking the actuator, or blend door motor. Now i have defroster, and heat comming from floor, but no vents. The actuator is behind the trap door in glove box, its a black box with a rod connecting to the blend door. After unhooking, make sure the blendoor is all the way to the right, i wired my in that position. Heater works good, and have had no probs. Hope this helps
Mar 23, 2013 | 1996 Cadillac DeVille
I have problem in samsung j700 of limited service
hi.u open the cell fone and heated the PA ic.i hope ur prob is cleared insa Allah
Feb 09, 2011 | Samsung J700 Cellular Phone
Toast cooks corrctly on one side and hardly at all on the oher. I have cleared all the crumbs out. It is the same whichever opening I use.
it means the other side has no heat to toast the bread!
The heating element might have been disconnected already, worst of all it is already burned!
try to contact the manufacturer to get the HEATiNG ELEMENT part or repair and replace the said part!
That'll solved ur probs!
Dec 01, 2010 | Prestige Appliances 50973 Toaster
I set the auto on and put on heat but no heat comes out i can hear a noise but no hot air blows out. If i set to aut cool it turns on. but not for heat.
check for 24 volts at w at the furnace when set to heat. prob so. this unit in yur attic? yur prob hearing the induced draft motor. it could be many things. good luck
Nov 22, 2009 | Heating & Cooling
Windows prob.
First check the fans and heat. There is nothing like heat to shut down a cpu.
Apr 11, 2009 | Computers & Internet
Tv shuts off but when i open the covers to let air in it stays on
commen prob solid state equip. heat sen comp prob horiz circuit need tech or insall small fan .
Nov 30, 2008 | Mitsubishi WS-65908 TV
Prob. 1unit shuts off by itself/ prob 2.back is cracking again
IT SOUNDS TO ME LIKE THAT YOUR UNIT IS OVER HEATING WHICH IS VERY COMMON WITH CHEAPER LAP TOPS. YOU CAN GO GET A LAP COOLER FROM STAPLES OR A LOCAL ELECTRONIC STORE THEY ARE NOT VERY MUCH. DID YOU DROP IT?
Nov 17, 2008 | Compaq Presario 700 470024-192 Notebook
Samsung SCX 4521F All-In-One Laser Printer Logo
207 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
