Question about Daewoo DLT22W4T 22 in. LCD TV
DLT20W2 TV POWER LIGTS FLASH RED GREEN WONT TURN ON OR RESPOND TO REMOTE
Location of the reset button on a wd60737
If the TV does not turn on or off, does not respond to the remote
control or control-panel buttons, or has audio but no video,
Press and hold the POWER button on the control panel for ten seconds.
The TV will turn off. Power on the TV and the green LED will flash
quickly for about one minute. The changes you made most recently,
before using SYSTEM RESET, maybe lost
Jan 18, 2017 | The Computers & Internet
My flat screen Sylvania TV is flashing different colors what's wrong
Better late than never. The problem is that your TV is in the service mode. There are many ways this can happen. But, lets just get down to fixin this! With the original remote and the TV on. If the TV will not shut off, do this. Press the left cursor button on the remote, followed with pressing the right cursor. Power off the TV with remote, or press off button on TV.
Secondly, your TV will power on and off. But you have flashing colors. Do this. With the original remote and TV on. Press the up cursor button, on the remote, followed with pressing the down cursor. Power off TV with remote, or press off power of TV. Thanks for asking me, Matt of Martins TV Repair.
Jan 20, 2016 | Sylvania Televison & Video
Philips LCD TV Red Light Stays On, TV won't turn on or respond in any way
Could be power supply failure or you may not be using the "hospitality" remote.
Aug 13, 2014 | Televison & Video
Palsonic TFTV8157DT won't respond.
Could have an open internal fuse
Nov 17, 2017 | Televison & Video
Philips TV model 34PW9815/17 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt...
Philips TV model 34PW9815 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt respond to controls either on the set or the remote
May 12, 2010 | Philips 32PT81S 32" TV
Havin problem with a1200 class a/b amp it ligts green and red at same time after hooking in remote how doi fixdo i need diagram to fix
Make sure you don't have any shorts on your speaker wires or rca cables. Unplug one at a time, the turn on power until it stays green with no protect light, then you know what input is causing the short. If you remove all speaker wires and rca wires and all you have connected is the ground, power(12volts) and remote and it still lights up red/green(in protect mode) then your problem is the amp.
Mar 09, 2010 | Car Audio & Video
Green and red ligts flash when powerd up also
hello there's a couple of things that could be wrong .the high pitch noise could be the convegance chip shorted out these are 2 big black chips connected to a metal frame called a heatsink the other could be the lamp burn't out
shaun
Oct 21, 2009 | Sony Grand WEGA KF50SX300 50" Television
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
Tv wont turn on
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
May 16, 2008 | Philips 32PF5321 32 in. HD-Ready LCD...
Daewoo DLT22W4T 22 in. LCD TV Logo
122 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
