Question about MTX JackHammer JH1200 Car Amp
The orange and red light blinks and the amp doesn't power on
Green orange then red flashing 3 times light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Dec 04, 2014 | Televison & Video
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
Sep 25, 2013 | Gateway Computers & Internet
Orange light blinking when turned on and doesn't project picture
First check your manual for trouble shooting the lights meaning. I think it is the bulb.
Jan 10, 2013 | Toshiba TDP T1 Multimedia Projector
Panasonic standby light blinks Red/Orange why?
set is trying to move from standby to power supply on and not making it, No model indicated so best advice is take to some shop and get an estimate.
Aug 30, 2012 | Panasonic Televison & Video
Blinking/flashing lights(orange & green) & won;t pring. Have rebooted computer and unpluged printer. still won't print.
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head install both cartridges on ur printer n check ur blinking light on ur printer that will work only if u r too lucky other wise u have to purchase a one cartridge.
May 29, 2011 | HP DeskJet 5550 InkJet Printer
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Blinking orange light
green light mean on
orange light means standby
red light means power failure
no light means the fuse my have blown
good luck
shaun
Jul 31, 2009 | Microsoft Xbox 360 Console
MTX JackHammer JH1200 Car Amp Logo
Top MTX Car Audio & Video Experts
hoyzee1
Mark Skinner
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
