Question about Peg Perego John Deere Loader
Can't find my manual and need to get to the battery compartment for the accessories...blinking lights start button etc.
    Genius:
  • Peg Perego Master
  • 1,508 Answers
How do I deactivate my aps57c mobile audiovox alarm
  • Locate the push-button LED switch on the alarm box under the driver's side dash. The small red or black button is used to manually disable the alarm.
  • Put the key in the ignition and turn it to the "on" position. This activates your vehicle's battery, but doesn't start the engine. Press and hold the push-button LED until the LED light stops blinking. Once the LED stops blinking the alarm is disabled until you manually reset the alarm.
  • Start the car. Then, press and release the push-button LED switch once, to reset the alarm.
Apr 01, 2017 | Audiovox Vehicle Parts & Accessories
Tip
How to snychronize a Wii Remote to the Wii console
A lot of people have trouble synchronizing their Wii Remotes to their Wii console. I have written a short tutorial on how to do this.<br /><br />Figure out which scenario is similar to yours and proceed with the solution-<br /><br />1) When you turn on the Wii console and press any button on the remote no lights light up at all. This is because the remote is dead, you must replace the batteries in the battery compartment on the underside of the remote. If the controller is using a charge pack you need to put the controller on its charger.<br /><br />2) When you turn on the Wii console and press a button on the controller all four lights blink a couple times then turn off. This means the controller is not synchronized. If your controller has ever been previously synchronized all you need to do is press the 1 and 2 buttons at the same time and it will sync up.<br /><br />3) If option 2 doesn't work then this means you are preforming a first time synchronization with the remote. While the Wii console is turned on you should open the little compartment that is just below the disc tray. Then you should press the little red button. After pressing the red button you should open your Wii Remotes battery compartment, remove the batteries and press a similar little red button inside of the compartment. Put the batteries back into the controller and the controller should be synchronized! <br /><br />If none of these solutions are working then the problem is a technical issue with either the Wii remote or the Wii system, you should contact technical support for more information.<br /><br />I hope this helped with the synchronization of Wii Remotes!<br />
on May 16, 2011 | Nintendo Wiimote & Nunchuk Controller...
My new wii control only blinks
There is a little red button on the front of the wii by the sd card port. Open the door and push it. Now on the back of the wii controller in the battery compartment there is a red button push it. Now your controller and wii will sync. you could also push the 1&2 buttons at the same time after you push the red button on the front of the wii.
Aug 30, 2014 | Nintendo Wii Remote Controller
I have exactly the same problem as ammcgee What we can do? By ammcgee7 on Apr 20, 2011 My Nyko Wand for Wii will not sync properly. The two bottom lights for stay lit and device won't work at...
1) Open the battery compartment and there should be a small circular red button.
2) Next to the Wii's SD storage area there is a rectangular square button.
3) Hold down the red button on the controller and the red button on the Wii until the light on the controller stops blinking.
Sometimes it can take multiple tries to "sync" the controller with the Wii. Keep trying until the lights stop blinking.
May 07, 2011 | Nyko Wand? for Nintendo Wii
The wii fit game is telling me to push the power button on the balance board with my foot. It blinks blue and that's it. The batteries are fine. So what do I do?
You need to sync the balance board with the Wii. It's easy to do and takes 10 seconds.
1) Start Wii Fit.
2) When it asks you to push the power button as you're describing, open the SD card slot on the front of the Wii and observe the red button.
3) Now, flip over the balance board. Remove the battery cover on the bottom of it, and press the red button beside the batteries, and the blue light should start to blink.
4) While the blue light on the balance board is still blinking, quickly press the red button on the Wii. If they are both blinking at the same time, they should be syncing to each other.
5) Your Wii Fit Balance Board should now be synced with your Wii! If it has been synced successfully, you will no longer need to sync it, and should now automatically connect when the button is pressed with your foot.
Apr 09, 2011 | Nintendo Wii Fit for Wii
When i turn on the wii fit, the blue light just blinks for a few seconds then goes blank. new batteries are in it.
I have never had a wii fit board, but have had a wii accessory. I do know that The board needs to be synced with the wii. In the front of the wii where the sd card slots are there is a tiny red button. Press this button for 2 or 3 seconds. Then right afterward take of take off the cover for the batteries. There should be a similar button like the tiny button in the back of the Battery compartment Press this button.(make sure batteries stay in) you must do this quickly so you might want to take off the cover and locate the button before you do all of this.
Please Rate.
Dec 31, 2010 | Nintendo Wii Fit for Wii
All four lights on bottom blinking
you have to sync the remote with the wii to be able to use is.
procedure should be the same as for the original wiimote
Standard Mode SynchronizationNote: Make sure you have placed batteries in the Wii Remote (how to).
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system
Dec 26, 2010 | Nyko Wand? for Nintendo Wii
I have a wii fit board, when you power it up, it
Had the same problem. It's a sync problem.
First, best to double check you have fresh batteries.
Next, turn the board upside down and remove the cover from the battery compartment.
Open the small hatch cover on the front of your console unit.
Now start wii fit from the disk menu item.
Next, press the small red button inside the balance board battery compartment. The blue lights will blink for approx 3=5 sec.
While they are blinking, press the red button on the console (in the hatch compartment).
This should re-sync your board and the light stays lit.
Good luck.
Apr 07, 2010 | Nintendo CTA Digital WI-BBP Wii Fit...
RCA Universal Remote Programming Instructions RC800L-C 1239
if u do not have the code most universal remotes will allow you do it manually and you will have to follow these steps and insted of putting the code you can turn the tv on then press the on/off button on the remote till the tv shuts off then press enter
Aug 21, 2009 | Technics SA-EX140 Receiver
All lights blink but remote wont work
You may need to resync with your console. Take the battery cover off, and open the little door between the eject and reset buttons on the front of your console.
With the machine started and running, press the red button in your wiimote, then quickly press the same color button in the panel on the console.
Apr 16, 2009 | Nintendo Wii Remote Controller
Peg Perego John Deere Loader Logo
26 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
