Question about Nintendo DS Lite Console
Fault caised by bad contact and raw disk - unformatted can't found FAT system
The message appears when I insert my Nintendo game.
1. Fault Caused by Bad Contact
2. Raw Disk - Unformatted Can't Found FAT System
  • 2 more comments
  • Anonymous Sep 14, 2008
    same prob, been using a 4 in 1 game on the ds, has worked fine for months but now says: can't find fat system, fault caused by bad contact, raw disk unformatted
    Anyone any clues how to fix? thanks
  • sarahlousasa Jan 02, 2009
    i have same problem, when it first happened my comp told me to reformatt so i did, think this is where my problem is, ive reformatted through the ds and put all the new files on, but when i restart my ds firecard it just goes back to the same message, please advise
    many thanks sarah
  • sarahlousasa May 11, 2010
    THANK FOR THE HELP TRIED LOADS OF HING AND YOURS HAS STARTED IT WORKING AGAIN, IT JUST SAYS NEED UDISK VERTION 1.45! BUT IM SURE I WILL BE ABLE TO SORT THAT MANY THANKS SARAH X X
  • Niels Boehme May 11, 2010
    Are you inserting a real game cartridge or a slot-1 flash card device (such as r4, m3, n5...)?
  • 33 Answers
It appears there's a dault with the data/memory card.
You will need to upgrade the XMenu:
How to upgrade the XMenu:
>>>> Warning! All data on the MK5 will lose after you start the upgrade! Please backup it first!! <<<<
1. Use MK5 USB Linker connect PC , and enter USB data exchange mode , PC will detect one removable disk (MK5) have inserted
2. Copy "MK5_Menu_V1.39_AUTO_Upgrade.nds" to MK5
3. Restart NDS, enter MK5 menu, choose "MK5_Menu_V1.39_AUTO_Upgrade.nds" and run it,and restart NDS.
4. When NDS power on, hold L+R+A+B+DOWN to fast format whole MK5, or you can use A+B+START+SELECT+UP to make a low-level format ,then copy all data (include folder) from this uncompressed file.
5. Now new system is ready ,restart NDS and enjoy it!
Posted on Sep 19, 2008
If a computer boots up and display a fault message such as ..." Insert System Disk"; what is the fault?
Cannot find the hard drive or cannot find a bootable operating system ie. corrupt files/dead drive/cable damaged or not connected.
Apr 06, 2014 | HP Computers & Internet
I got Kingston DTI/64GB, when I insert in my PC - having windows XP- message occurs for FORMAT - I click on OK button, Format window open - Capacity shows 62.4GB, System= Nill, I select Quick format option...
first try to format in command line
Start
go to RUN
Type CMD and press enter key
in command window type format H:/fs:FAT (H: stand for my Pen Drive name change it if you have different)
press enter key
yes to all message appear
now you formatting start
if not so try this: 1000% work
download any low level formatting system and format from that or you need 3rd party formating tools like HP format tool to format RAW to FAT,
if still not work it mean your PEN Drive got Damaged and you have to purchase a new one.
Do vote me if this help you.
Jul 27, 2011 | Computers & Internet
What is a tbc fault on a 2006 ford f350 6.0
That is your trailer brake controller that is built into your dash. If you are hooked up to a trailer it could mean you are losing your connection or ground to the trailer. If you are not connected to a trailer it means there is a problem with your brake controller possibly a short in the wiring caising the fault code.
Feb 02, 2010 | 2006 Ford F 350 Super Duty
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
4gb sandisk will not in my Nintendo DS
please defrag the sony sandisk with windows defrag .
it will load after a defrag, if this doesnt work , check the integrity of the gaming software by nintendo.
also the format of the nintendo system may be fat 16, and your 4gb may be ntfs or fat 32. so this will not work if its fat 32 or ntfs system
check this into my computer ... right click disk managment
it will display the file system format.
datarecoveryfactory
Sep 05, 2009 | SanDisk 2GB microSD Memory Card
Disk reader etches ring in disk.
With the Wii it can either do this when it's moved or it can be a fault (although both uncommon). If it's doing it all the time with every disc then it's a fault with the machine and you need to talk to the store you bought it from, or Nintendo. If it's only done it one time to one disc then chances are it won't happen again
Jun 29, 2009 | Nintendo Wii Console
When a disk is inserted, an error message comes up saying that it is unable to read the disk. We tried a disk cleaner which didn't seem to help. Any suggestions?
I would recommend that you take the console to a game store and get them to have a look at it, it sounds like there might be a fault with the CD drive or the laser not reading the discs properly
Apr 13, 2009 | Nintendo Wii Console
Roland SPD-S Flash card error
The card I have always been using is now also suddenly giving this message. I found an old SanDisk 16MB and a 1GB SanDisk that works perfectly in my Boss 864 and they also give the same message. Trying to go into formatting brings the message "no card!"
May 13, 2008 | Roland Spd-S Sampling Percussion Pad...
Ds lite
When this "freeze" occurs, turn off the DS system and remove and re-insert the game cartridge several times. Turn the system back on and the game should appear. If not, repeat this procedure.
Dec 03, 2007 | Nintendo DS Lite Console
Scratching disks
http://www.nintendo.com/consumer/systems/wii/en_na/ts/gameDiscReplacement.jsp
Dec 02, 2007 | Nintendo Wii Console
Nintendo DS Lite Console Logo
251 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
