Question about NetGear FS108 8-Port Ethernet Switch
I just moved to Memphis TN and got a new DSL account with ATT. When I try to use my laptop via the Netgear laptop shows "Another computer is using your IP address" and will not connect to Internet. I tried calling ATT tech, but they won't help without adding another account service cost. Please advise
  • Rhonda Powers Sep 04, 2010
    Stelios,
    I tried rebooting both the laptop and the PC. Both continue to try to use the same IP address with only one being successful--if laptop works, PC doesn't, if PC does, no dice on the laptop. Can I change one IP address manually, and if so, how? Thanks for your prompt attention. Memphian
    President:
  • 1,851 Answers
Your problem has nothing to do with ATT, it's internal's network problem. The message you get means that another computer uses the same ip address with your laptop and you can not connect. There are various ways to solve this problem. First of all reboot your laptop; most of the times it gets new ip address so the problem will be solved. If not check if it's able to reboot the other pc; the pc with the conflicted ip will get a message of error too so it is not difficult to locate which one needs to be rebooted. If neither of the above work, or if the problem come up again after some days, we have to change some settings but let's try the easy way first.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on Sep 04, 2010
  • Stelios
    Stelios Sep 05, 2010
    First of all let's check the ip address that each computer use. With one of the computer in power off state in order to be the other one connected, go at start and click on run of the working and connected computer. At the white line type "cmd" without the quotes and hit enter. At the new black window type "ip config" without the quotes and hit enter. The system will reply with the ip adresses for the local machine connection at the fist line (indicated as IP adress) and the ip addresses for subnet mask (at the second line) and for the gateway (at the third line). Write down on a paper these numbers. Shut down the computer. Start the other one. After finished and connected do the same as before. Write down the new results. The first line for the ip address that each computer uses in order to connect at the network is the same, that's why both of the computers can not connect at the same time. Let's fix the problem.
    Assuming that you use Windows XP, go to start - settings - control panel - network connections - local connection. At the new window you will see some kind of protocols for network connections. Near the top down at the list is "Internet Protocol TCP/IP". Click on it (not at the box with the check-mark in front of it, just on it). Click on the "properties" button (just bellow). The upcoming screen will show in ip address format details for the connection. At each one of the 2 sets it's an auto setting and a manual one. I suggest that your systems are now in the manual mode. Write down the 5 numbers of this screen (we will need these in case of bad luck) and change the settings to auto (both of them). Click OK, close all the windows and restart the system. Now one of the computers uses auto settings and the case of conflict is minimized. My suggestion is to do the same procedure at the the other computer too in order to get both the computers auto ip settings.
    Thanks and regards
    Stelios
    direct fixya link:http://www.fixya.com/users/technical114
Have 2 computers connected to Netgear WGT624NA router via ethernet connectors and have operated well for over a year. Now have gotten DSL and have run phone line to modem and via ethernet cable have...
Have you tried to reset router. It has to be done in order.
1. unplug router
2. unplug modem
3. shut down computer and restart after waiting 1 min
4. after restarting computer plug power back into modem and wait for all the lights to start blinking
5. after the modem is working plug power back to router and plug in the computer with ethernet cable and make sure you have internet,
6. try to link up with wireless,
If this does not work you will have to setup the router for wireless if it is att wireless you will have to call them to give you the password to set it up.
Jan 10, 2011 | NetGear WGT624 Wireless Router
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    Trying to connect a netgear router for at&t company. att only uses 2wire or motorola and works on dsl. can i use a netgear with att
    Yes, just make sure you have all your authentication codes ( username and password) when already setting up the router for the first time for PPPoE...
    Apr 07, 2010 | Computers & Internet
    Running install disc, says does not support operating system
    Are you trying to set up router ?
    You can set up your router manually, without the CD.
    Make sure that your computer is able to go online directly through the modem.
    If your computer is able to go online through the modem, that means the modem is working fine.
    You will need to connect the computer to the router and the modem to the router.
    open the set up page of the router and change the settings of the router according to the ISP.
    Click Here for more information about the routers and network
    Mar 03, 2010 | NetGear WGR614 Wireless Router
    Att dsl internet on deskop and want wireless for my laptop
    Yes you can buy a different DSL modem and that should not be a problem , then once you have the new DSL you just contact ATT and they will set up the settings on it...
    Oct 09, 2009 | 2wire 2700HG-B Router (2700HGB)
    I have a NetGear Wireless Router which wont connect to internet.
    Verify that you can connect to the internet without the router by hooking the cable from the dsl modem to your computers NIC.
    If you can connect to the internet that way the problem is with the router. press and hold the reset button on the back of the router to reset it to the factory settings. (this just makes it easy to determine the problem) if this corrects the problem you can setup your security again
    Aug 30, 2009 | NetGear RangeMax WPN824 Router
    Wireless system strength on laptop away from router
    I don't beleive it's your dsl, It seems to be a problem with your router, since it sounds like it is not broadcasting well. Consider a new router before ridding of your ATT DSL.
    Apr 28, 2009 | 2wire 2700HG-B Router (2700HGB)
    How to add a netgear wgr614 router to dsl modem
    The NETGEAR router needs to be configured. Call NETGEAR. Try this also http://technicalsupport.blog.friendster.com
    Jan 05, 2009 | NetGear WGR614 Router
    Netgear DG834PN ADSL ROUTER AND HUB - PC dial-up connection
    so your trying to use a dsl router as just a router -dsl with dialup?
    Aug 06, 2008 | NetGear Computers & Internet
    Help please
    you can go to any wi-fi locations near your area and access the internet on your laptop. I think AT&T offers wi-fi access to its members on any of its designated hotspot /wifi locations (nearly 15,000 company-owned & roaming) e.g. McDonald's, Barnes & Noble bookstores, leading airports, coffee shops, etc. you can visit att.com and login to your account to find more details.
    or call them at: 1-888-888-7520
    you don't need to install any software/ dsl installation on your laptop when you are using a public wi-fi connection, just ensure that your computer firewall is on and take precautions when sending out any personal info online.
    Apr 30, 2008 | AT&T High Speed DSL Modem
    NetGear FS108 8-Port Ethernet Switch Logo
    262 people viewed this question
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
